Old 09-03-2003, 03:17 PM   #151
Corse-R's Avatar
Originally posted by Top Gun 777
Doesn't sound perfect for me. Coompression has to be much less under this temperature and brack in suppose to be easier then rocket since. But it is my opinion and can be mistaken.
Haven't said that those P/S didn't lose compression at those temps (who certainly loses some compression), but is their particular strenght to whitstand high temperatures without damaging the piston and the sleeve.
Measured the taper of the sleeve and found that curiously has slightly less taper than Novarrosi usually put on their sleeves. Is the piston the one that makes the difference.
Cheers,
Corse-R
[quote=MugenDrew;2684554]BATTERIES are for FLASH LIGHTS, gasoline is for cleanin parts, alcohol is for me to drink and well NITRO...everybody know thats for racing.[/quote] :D:D:D
Corse-R is offline   Reply With Quote
Old 09-03-2003, 03:29 PM   #152
EdwardN's Avatar
It is possible they got material with smaller temp expention coeficient, so they went with smaller tappering ( how smaller, it alread was too small).
About Aluminium alloys-they can withstand much higher load (temp and force) then we have on combustion chamber, it is not a point.
DISCLAIMER: Since 90% of my posts may be BS, and since my posts may be either insanely idiotic, incoherent, and/or not even close to a rational thought, please accord my posts no more than 10% of credibility.
EdwardN is offline   Reply With Quote
Old 09-03-2003, 03:30 PM   #153
EdwardN's Avatar
Originally posted by Speed De
Or does it???
Old 09-03-2003, 03:34 PM   #154
EdwardN's Avatar
I made a lot of chemical analizes and found all novas pistons are from different alloysl, with different SILICON content. Want to check from NS3 too, but don't have broken piston yet.
Old 09-03-2003, 06:30 PM   #155
Corse-R's Avatar
We're talking about 0.04mm of taper, enough small considering that previous S3 P/S sleeved that I've had ranged from 0.07 to 0.09. Considered it too small and lapped slightly the piston (very slight lapping).
Cheers,
Corse-R
Old 09-03-2003, 06:33 PM   #156
Corse-R's Avatar
Originally posted by ziggy12345
What happens when you use a non tubo plub in a turbo engine?
Simply you cannot, shapes are phisically different and you cannot completely insert an non-turbo plug into a turbo plug head. In the inverse case I think that's possible, but the fail in the sealing will harm the combustion chamber seal.
Better to use the intended plugs in your engine head.
Cheers,
Corse-R
Old 09-03-2003, 07:19 PM   #157
EdwardN's Avatar
Now, I want to test for chemical analizes that piston! Are they going to CMB case?
Old 09-04-2003, 02:25 AM   #158
Corse-R's Avatar
Uhm... really, don't know what are doing actually CMB, mine days of bitching with CMB's, Cipollas and Piccos are very very deep in the past. Except the Sirios I actually have, Last Non Nova based engine was a Picco KSR who was somewhat crappy in performance (for not saying that was a POS).
Cheers,
Corse-R
Old 09-04-2003, 06:36 AM   #159
ziggy12345's Avatar
I just checked my NS3 race and the slug (bit at the top of the head) doesnt have a tapered hole so will only accept normal plugs. The crank is still a turbo crank
I also checked my Rossi Pixy Black and this is the same!! Do you have to specify that you want a full turbo engine when you buy it or are they supposed to come wth a turbo slug?
Whats the difference in power between the normal head and the turbo on the same engine?
ziggy12345 is offline   Reply With Quote
Old 09-04-2003, 07:43 AM   #160
ziggy12345's Avatar
I have just been on to Novarossi and the NS3 race sold in the USA is the ROAR legal version with a normal head and normal plug and with a different crank.
To bring the engine to top powere you need to fit a turbo slug and plug and a new crankshaft part no 15615
Has anybody got any experiance with this crank shaft?
Cheers
Old 09-04-2003, 09:45 AM   #161
EdwardN's Avatar
I am playing with any engines around. worse engine so far from top line is Picco ( it has never been good sonce came on market 15 or so years ago). I tryed that brand 15 years ago, was the same-crap. I know some tether cars guys got some good results out of it, but most likely they use their P/S sets and conrods. On our track I saw .21 Collary two engines, where sleeve was broken on two pices on the ports area, with no reason at all.
About the CMB, I played with one of new version, actualy it is running pretty good, but they make this Mikkey mouse ears scoops on both side -it is mistake on my opinion, also materials and geometry set ups on P/S sts are totaly new and I can't tell you yet how long it will run, actual temp is very low-190-195 deg, and it is peforming pretty good. As soon As I got life lenght result I will let know. It is very easy to tune, But any way CMB isn't top of the line engine by design and if anybody considering to use as engine # 1 needs to be very carefull ( I am not going to use , unless I will change P/S set to mine). Also backplate with that labirinth-looks just sweet, but I am not sure if designer knew why he was doing it. If he thinks mixture shoot to the crankcase? Just sweet.
Old 09-04-2003, 10:49 AM   #162
Corse-R's Avatar
Probably you're referring to the 'wide timing' crank that was used in the 5port versions. It really raises the power, but at the cost of losing a tad of low-end.
Cheers,
Corse-R
Old 09-05-2003, 10:24 AM   #163
EdwardN's Avatar
Hi guys.
Yesterday I was working on JP .21 P/S set (was lapping it) and have noticed something weird. You know the wriste pin has hole inside, so it was full of metall debries there. If that set will install like that on engine-it will be dead in second. Have check yours new P/S sets, you might have the same problem. It is just advice for everybody.
Old 09-06-2003, 10:36 PM   #164
EVOLUTION's Avatar
Top Gun,
What's this i read about a MPP777 mod motor?
EVOLUTION is offline   Reply With Quote
Old 09-07-2003, 12:25 AM   #165
Data's Avatar
Originally posted by EVOLUTION
Top Gun,
there is maximum performance project, there is maximun performance parts, i guess this one must be maximum performance porting
Data is offline   Reply With Quote
RB Engine Thread snowboardgeek1 Onroad Nitro Engine Zone 515 06-16-2017 11:28 AM
GRP... Engine... Thread... xlgraphicspro Offroad Nitro Engine Forum 2135 09-10-2013 09:46 AM
OS TR engine thread compaq888 Onroad Nitro Engine Zone 612 03-25-2006 05:55 AM
REX engine thread? factory racer Onroad Nitro Engine Zone 1 06-05-2005 10:42 AM
SH Engine thread ziggy12345 Onroad Nitro Engine Zone 12 02-14-2005 01:48 AM
