Old 05-26-2004, 01:01 PM   #1396
kevink2's Avatar
Originally posted by C Verano
The sedan is getting pretty good. I built a new car with a new motor and pipe and didn't run into any problems over the weekend. Handling wise the car was pretty good with a set up close to Darin Ishitani's. I tried running with Jeffery Lin but he's got his CD3 on rails. He had a 16.1 in qualifying Sunday.
The Evolva is good. I managed some 14.5's with it. I'm sure I'll get better with it when I get some more track time. I need to change a little in the set-up and get a little more comfortable with the car.
Are you getting caught with painting? I'm in need. The silver in black paint jobs are killing me.
Good deal! I'm starting to feel better about my setup as well. Look forward to running again!
I'll get to the new shells as soon as I can.
kevink2 is offline   Reply With Quote
Old 05-26-2004, 01:03 PM   #1397
kevink2's Avatar
Default Re: Mugen clutch
Originally posted by IDrinkNitro
Does anybody know if the mugen mtx 3 "centax" clutch system will work with my ld3 pro?
Yes. You can even use they're lightened flyweights and gray or red shoes. Mugen pinion gears will also fit the OFNA clutch bell and vice versa.
Old 05-26-2004, 01:37 PM   #1398
IDrinkNitro's Avatar
Default Re: Re: Mugen clutch
Nice..thanks for the info
IDrinkNitro is offline   Reply With Quote
Old 05-26-2004, 08:33 PM   #1399
sup
sup's Avatar
just want to ask, what gears do you guys use for the pinion and spur (1.0 module)? as of the moment, am using the stock ones that came with the standard kit (1st: 15-43, 2nd: 19-39). also want to know the internal ratio of the gears, anyone know? is it different for the 4 and 6 gear diffs? thanks in advance!
sup is offline   Reply With Quote
Old 05-27-2004, 06:07 AM   #1400
spenzalii's Avatar
Send a message via AIM to spenzalii
Huh. Stock on mine was 16/20 clutch bell, 42/38 tranny. 15 and 19 were only offered in aluminum. Currently I'm trying 15/20 and 44/39 with that SX12, and it peels out.
I think the IR is 2.5:1. Read it somewhere and can't remember. Since I don't have the manual, not sure on the tooth count to calculate it either. Anyone else know 4 sure?
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 05-27-2004, 07:09 AM   #1401
huh? Only offered in aluminium?
Steel gears:
0234U 13t 1st Gear
0234V 14t 1st Gear
0234L 15t 1st Gear
0234T 17t 2nd Gear
0234W 18t 2nd Gear
0234M 19t 2nd Gear
I see a 15 and 19 there
At least ur right on the IR, it is 2.5 : 1
au_Nightmare is offline   Reply With Quote
Old 05-27-2004, 08:30 PM   #1402
sup
sup's Avatar
but the internal ratio you guys are mentioning is for the ntc3 which has ball diffs? will it still be the same for gear diffs? just asking guys, am getting a little confused about this.
Old 05-27-2004, 08:43 PM   #1403
dtm
dtm's Avatar
Send a message via ICQ to dtm
The internal ratio is not affected whether it is ball diff or gear diff....it is only calculated at the bevel gears going into the gearbox and the crown wheel. Both LD3 and NTC3....and TC3 share the same 2.5 internal ratio....
dtm is offline   Reply With Quote
Old 05-27-2004, 08:50 PM   #1404
sup
sup's Avatar
ok. clear now. thanks!
Old 05-27-2004, 11:33 PM   #1405
sup
sup's Avatar
with that in mind, what gearing do you guys use? all around gearing? using the 3 shoe clutch with sirio 3 port (abc). thanks in advance!
Old 05-28-2004, 08:13 AM   #1406
spenzalii's Avatar
You forget, I'm using US spec LD3. The smallest steel pinion they offered was a 16T. Now, I think they make one, but the part number didn't match anything on the LD3 parts list. That's why I have the aluminum 15T on mine now.
And gearing really depends on your track. The stock gear is pretty middle of the road for speed and acceleration. I'd get the biggest spur you could find in the tiith spread you're going to run and adjust the pinions from there
Old 05-28-2004, 02:35 PM   #1407
They are not listed as LD3 parts for me either, I had to go digging on the HN website to find them but they are there and I assume available From the part number they have been around a long time, maybe from OB4 days as stock gearing on OB4 I think was 14T and 18T.
Old 05-28-2004, 07:18 PM   #1408
Default Joining the club
Will my new LD3 Pro with Picco .12 is on it's way!
Thanks! to a great price from NitroHouse.com
$299.95
now that's a great deal!
The sad part, won't be here until friday.
Looks like I'll be asking for some advise pretty soon on
how to make the car hook up.
VRF201
VRF201 is offline   Reply With Quote
Old 05-28-2004, 11:09 PM   #1409
spenzalii's Avatar
On the Hong Nor site, yes. At the time, I was dealing strictly with Ofna/Nitrohouse. The parts list for the LD3 never mentioned anything steel smaller than the 16T. Even in the expanded list, it didn't. And while I thought the gears from the OB4 should fit, I never bothered to check. This was before I thought about ordering from overseas. Besides, I didn't want to order just a gear from HK when someone had an extra green 15T at the LHS...
Ah well, the main point is I have it now NOw to get it on the track and see how this NovaMega runs
Old 05-28-2004, 11:19 PM   #1410
Novamega! NICE ! Yeah ley me know. I got a friend who can't stop thinking about one.
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
