Old 05-11-2004, 08:14 AM   #1336
Hey I was out running my car this weekend and I was doing some laps at the track. The car went out of control due to a heavy throtle finger, smacked up the left side of the car. I bent the front and rear cva's, bent up the stinger, and broke a lower control arm.....SWEEEETTTTT ... But thats not the real problem, After the crash broke out the hammer and crazy glue fixed it right back together for the time.....But my main issue is I can't get the car to shift any more. I think it's stuck in second gear any feed back on how to get it out of this gear will help...
Blaze1 is offline   Reply With Quote
Old 05-12-2004, 11:08 AM   #1337
spenzalii's Avatar
Send a message via AIM to spenzalii
Pull the transmission down and check to see if anything is broken, Check the clutch shoes in the tranny, the one way bearing and the adjustment screws. See if anything is bent in there and get it replaced.
How fast were you going and did you yun into a wall?
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 05-12-2004, 01:37 PM   #1338
Almost top speed when I hit the wall, I didn't run head on into the wall most of the impact was on the left side of vehicle. Also the gears 1st and 2nd have seemed to have a little play in them as far as spacing goes. ig they use to sit close now their about an 1/8th of spacing between them.
Hey I got a question will this mill drop right in with out any mod. I think it should but just want a second oppinion on this matter. https://www.ssl-stormerhobbies.com/c...pn=FAN01017er. Thanks for the input spenzalii............
Old 05-12-2004, 07:18 PM   #1339
Default Comparing the LD3 to others????
How many of you have raced something else? Such as the Mugen or Associated NTC3? How does the LD3 compare? What do you like and don't you like about it?
Where is the best place to buy one? (Mail Order)
Thanks!!!
elmar66 is offline   Reply With Quote
Old 05-12-2004, 10:19 PM   #1340
C Verano's Avatar
Default Re: Comparing the LD3 to others????
Thanks!!!
www.nitrohouse.com
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 05-12-2004, 11:02 PM   #1341
Default Re: Re: Comparing the LD3 to others????
hehe no, http://RC-Mushroom.com is the best place
Originally posted by C Verano
www.nitrohouse.com
au_Nightmare is offline   Reply With Quote
Old 05-13-2004, 07:07 AM   #1342
Default Re: Re: Re: Comparing the LD3 to others????
Got to second that one
havy
havy is offline   Reply With Quote
Old 05-13-2004, 08:01 AM   #1343
spenzalii's Avatar
Default Re: Re: Re: Re: Comparing the LD3 to others????
havy
Depends on where you are in the world and how patient you are. RC Mushroom and RC Model (another place that's quite good) both ship from overseas. While the products may cost more at Nitrohouse, that cost may be lessened once shipping is figured in. Plus, in the contanintal US, it will get there much quicker than waiting for international air mail.
Old 05-13-2004, 09:31 AM   #1344
Angel727's Avatar
Default set ups
Originally posted by Blaze1
Hey I just copped a set of foamies today 26mm in front and 37mm in the rear. Has anyone tried using ENNETI brand tires, their Italian made. Just wondering...Also who has aluminum shock towers for the LD3 and cva joints besides nitohouse...?
those tires are execellent. Havy and I are race buddies and he recommended me that tires. Solve my problem.
Angel.
Angel727 is offline   Reply With Quote
Old 05-14-2004, 10:14 AM   #1345
IDrinkNitro's Avatar
Default steering servo mounts
Has anybody that is using the aluminum steering servo mounts had to grind them down in order to fit the servo correctly? My KO servo is not even close so looks like the mounts will need some trimming
IDrinkNitro is offline   Reply With Quote
Old 05-14-2004, 10:18 AM   #1346
spenzalii's Avatar
Grind where? I have them on my Futaba servo. It went on with no problems. I had to chose between mounting the servo on the radio plate or the chasis, since there was a 1.5mm (give or take) space between the chasis and the mount when mounted on the tray and I didn't have any shims
Old 05-14-2004, 10:21 AM   #1347
Grind the ends that the servo screws into. My KO servo comes to far forward and gets in the way of the steering. Are you using a low profile futuba servo?
Old 05-14-2004, 09:28 PM   #1348
I figured out the problem. I had built the steering wrong. I am going through all the normal first build problems it appears
Old 05-15-2004, 07:58 PM   #1349
Default LD3 Versus GP4
Has anyone seen additional information on the GP4? What are the major differences?
Old 05-15-2004, 08:08 PM   #1350
kevink2's Avatar
Default Re: LD3 Versus GP4
Everything!
kevink2 is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
