OFNA LD3 pro
#1277
You're right
sorry bout that, I like that thing....pro version looks good.
havy
ps: Blaze, Ld3 is an awsome car
havy
#1278
bulldog, have the same understeer problem too.. running diffs all around so ill be trying thicker oil in the rear (current oil is 100K in front and 30K in the rear, and it still understeers! hehe!). please share your set-up when you get back!!!
#1279
sup
sure thing bro,actually Im just learning the car now...there are lotsa things about this car I still dont know,but help is always at hand...
#1280
You can get some of that understeer out with a bit of setup help. I don't have the heavy oil yet, but I get a much better turn in with the setup some of the track guys helped me with. When I take it down tomorrow, I will see what I have it as.
I'm waiting for the guy with the Nova to e-mail me so I can get the engine. I plan on sending it to get modded. Maybe then I will be able to keep up with some of the mid to upper speed guys. My CVR will work for my class, but I will have no chance if I move up. I'm also going to send the OS out a little later and get the new turbo head they have. I'll have a Frankenstein OS that should puzzle the crap out of people. I can hear it now...'A TR shouldn't be that fast...wait, that's SIDE exhaust...whatinthe...?'
#1281
ey guys what does a solid diff do?if installed in the front, what is its characteristics?any one tried it?.....
#1282
By solid diff do you mean a spool? If it is totally solid with zero diff action then it will act like a one-way except you will still have 4 wheel brakes...
#1283
is there an available solid diff/spool for the LD3? i know there are some manufacturers that do some for the tc3 but i doubt that it will fit the ld3 (spurs are not interchangeable and the tc3 uses english not metric). has anyone tried it here?
#1284
Yes there is, I forget part number, its in the LS33 - LS36 range I think. I did post the # earlier..
ahh here it is
HNLS34 Solid Rear Axle
ahh here it is
#1285
Where can you pick that part number up?
#1286
ahh here it is
ahh here it is
#1288
pull start repair
I busted my pullstart this weekend dose anybody know how to fix them or a link on the net ???
#1289
kevink2, just wondering.. the ntc3 sure shift 2speed is sold as a set (springs, shoes and screws). will the whole sureshift fit the ld3? thanks in advance!
#1290
