Old 04-21-2004, 07:17 PM   #1231
kevink2's Avatar
Originally posted by Team-RTR
surely with a new layout the car should some differences in weight transfer etc. therefore making it handle diferent?
kevink2 is offline   Reply With Quote
Old 04-21-2004, 07:22 PM   #1232
Team-RTR's Avatar
i heard that there will be an LD3-CD3 conversion kit.. is this true?
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 04-21-2004, 11:15 PM   #1233
C Verano's Avatar
I haven't heard any plans for a conversion. But I would not count it out.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 04-22-2004, 11:21 AM   #1234
spenzalii's Avatar
Send a message via AIM to spenzalii
A conversion kit sounds expensive, especially since you have to get a new chasis, upper deck and transmission anyway. Using the same suspension and gear box will help, especially since they aren't that hard to get (beat that Kyosho!). I only hope it comes stock with the .08 module gears. If it does, I'll pick one up.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 04-23-2004, 11:27 AM   #1235
IDrinkNitro's Avatar
Talking On/off switch yay or nay?
Another newbie question for you racer types. I am building a ld3 pro, first question, do you guys run on/off switches or do you bypass them completely for racing? If you use one do you have a recomendation or link to a good one? Is the KO switch any good or is it too big? Help the newbie
IDrinkNitro is offline   Reply With Quote
Old 04-23-2004, 11:40 AM   #1236
spenzalii's Avatar
I run a standard, 3 lead switch on mine. it makes it easier to make sure the receiver is off and with the charge lead, it cuts down in wear and tear on teh battery leads.
Well, mine isn't exatly standard. I ended up swapping the charge lead for a micro rc plug. The only flat pack I had at the time came from my X-Ray M18, so I figured I better use what I had...
Haven't tried that KO switch, but seen it on a few cars. Seems ok. a little bigger, but you can find space on the chasis for it.
Old 04-23-2004, 11:55 AM   #1237
thanks, do you know if that KO switch is a 3 lead? Do most guys use a switch? Just curious.
Old 04-23-2004, 01:48 PM   #1238
spenzalii's Avatar
around here they use the switch
Old 04-23-2004, 02:53 PM   #1239
C Verano's Avatar
I don't use one...
Old 04-24-2004, 08:26 PM   #1240
spenzalii's Avatar
I had to take the rear diff out today. After the run Sunday, I turned the rear wheels and they spun the same way. Not good. Looking in the diff, the oil was black muck. Fortunately, cleaning them out and replacing the oil seemed to do the trick. I put the diff gaskets on there (the RTR didn't seem to have any) and hopefully that will keep the oil in the diff. I'll try to get the 300,000 and 100,000 weight oil this week.
Toying around with an idea for the motor. I have a line on a side exhaust NovaRossi (hope I get it!). I may send it out to get modded and drop it in the car by race 3. Then I may get the CV-R modded and ass the turbo head on it. Either way, I hope to het some more ponies for cheap. The back straight is a lot longer than the gearing (or motor) can handle right now. We're talking about 200-250 feet to roll down. That 16/21 to 44/39 needs to be changed up a bit.
Old 04-25-2004, 10:21 PM   #1241
bulldog's Avatar
Arrow kevink
nice meeting you dude!learned alot from ur car.wish my ld3 run as good as yours.
bulldog is offline   Reply With Quote
Old 04-25-2004, 10:43 PM   #1242
kevink2's Avatar
Default Re: kevink
Nice to meet you too! My car still need lots of work though! Don't worry we'll get 'em working better.
Old 04-26-2004, 06:55 AM   #1243
BaxterC's Avatar
Default Re: Re: kevink
Hi guys... I am looking for some info, what is the quality like on the components of the LD3? Is it as bad as the old Z10? Do you have to sand anything, cut anything, file anything?
BaxterC is offline   Reply With Quote
Old 04-26-2004, 07:00 AM   #1244
Team-RTR's Avatar
the LD3 parts quality is very high, i have been in some very bad crashes with it and have not broken one single part. the suspension arms are easily one of the thickest ive ever seen
Old 04-26-2004, 10:27 AM   #1245
Registered User
OB42TC3's Avatar
I have a modded SG crank that will fit in that engine and give you 90% of the full mod job for sale.
OB42TC3 is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
