Old 04-11-2004, 07:42 PM   #1156
Thanks havy!
jay272 is offline   Reply With Quote
Old 04-11-2004, 09:51 PM   #1157
spenzalii's Avatar
Send a message via AIM to spenzalii
on that OS, it depends. They usually have a drive washer (for lack of a better word) that usually goes on before the collet or flywheel do on. if you don't use that, you may have to cut it. I have that drive washer on my CVR and haven't had a problem with it. That said, if you have no problem cutting the crank, then go for it that way
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 04-12-2004, 05:59 AM   #1158
Registered User
Angry Eyes's Avatar
Hi De Ho All,
Well i finaly got the new ld on the track today, thanks for all the advise on build and setup tips. The little os powers this like nothing i have driven b4 , and pretty easy to drive to, just a little little fiddle here and they and we be rockin, hey nightmare.
Just for the information pool.
The power plant is OS TR12(P), centax clutch runnin std gearing
Pipe is ths
Radio gear is JR, std servos for now, a high speed metal job for the steering on the way
Six Gear Rear diff with 30K Mugen oil, Front one way.
Single Hole piston up front with 70W and HongNor purple springs
Double Hole at rear with 55W, and hong nor copper.
!.5 Deg camber all round, 2 deg toe in on rear, 0 on front, 5.5mm ride height.
Get enthusiastic with the fast finger out of slow turns and its a happy car but is driveable
Thanks Again
just gotta fix the LH rear had a little incident without a body on my bad
Angry Eyes is offline   Reply With Quote
Old 04-12-2004, 07:59 AM   #1159
spenzalii's Avatar
Sounds good. I may look into a similar setup this weekend. Speaking of which...
I need another US shop that sells LD3 parts. Nitrohouse is moving this week and the orders will be delayed, and I need to pick up a few things (15t and 19t pinion, rear floating body mount) before Saturday. Any ideas?
Oh yeah, and I can't remember, but will the NTC3 springs fit teh shocks of teh LD3? I want to get the whole set, but a lot of shops carry the TC3 springs.
Old 04-12-2004, 12:30 PM   #1160
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Hi guys,
Im thinking seriously on buying an LD3 Pro kit (the one that comes with no engine, my ide its throw a NS3 on it).
Now, Can someone here with experience on this kit tell me the pros and cons of it ? ... its really competitive v/s MTX3's, 710's, GT4's, G4's, TC3's, etc ? ... how its the durability of it ?, do i have to buy the kit with a good stock of extra parts ? ...
Just as extra info, i will be runing the car on rubber-based races and foam-based ones ... right now im runing a Yokomo GT4W2L and its competitive against anything out there ... but i dont know nothing about the LD3 Pro kit ... any online store to buy parts ?
Thanks in advance guys ...
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-12-2004, 01:18 PM   #1161
spenzalii's Avatar
OK, here we go...
The car is as competetive with anything out there :AE, HPI, Mugen, Serpent, etc. Some think it is much better than the TC3 because it fixed a few of the problems that design has (shock tower, toe, tank etc). The biggest problem with the LD3 is PUBLIC PERCEPTION. In this part of the world, Ofna has no factory presence on any major races. That and the fact that some of their earlier cars weren't the greatest hurt them. But rest assured, it can and will compete.
The car is quite durable. I've flipped it a few times and no major breakage there. For parts, if you keep the usual stuff on hand (arms, knuckles, etc) you will be good. I try to keep a set regardless. Depending on your area, you an order from places like Nitrohouse, RC Mushroom, and a few others off the top of my head. If you can set up a car, you can run the LD3.
You can't beat the value of the car if you tried, though...
Old 04-12-2004, 02:46 PM   #1162
Tabushi's Avatar
Thanks a lot for the info ...
Now, about hte shaft system, it needs so much maintenance or not ? ... i can see Nitro TC3 guys replacing the shaft cause after using high power engines (.12 as NS3 or other turbo ones) the shaft start to have a little play and all ... andother problems as the diffs not suporting the effort and have to buy the entire internal set every 2 or 3 races ...
Thanks for any other info you can give me ...
cya !
Old 04-12-2004, 02:50 PM   #1163
spenzalii's Avatar
TC3 uses ball diff, LD3 uses gear diff. It will handle the abuse.
Haven't had a problem with the shaft (except when I landed it upside down on a curb...), but you can get one to make yourself feel better
Old 04-12-2004, 03:15 PM   #1164
Tabushi, I think of a electric cars when I think of ball diffs I don't know why they are on the NTC3 heheeh The LD3 gear diffs will last don't worry.
Angry Eyes, yeah the LD3 is a weapon. I think I am going to lift my game a bit or all I'll see is ur ass end As long as we are in front of the FW05 boys thats all that matters hehehehe
au_Nightmare is offline   Reply With Quote
Old 04-12-2004, 05:32 PM   #1165
Nitrohouse.com has the LD3 pro for $199.00!! I have no choice but to order it. Thanks for answering my questions fellas!!
Old 04-12-2004, 05:37 PM   #1166
If you want the version with centax clutch etc its $245.00USD @ rc-mushroom.com
Postage will be more but if you are inside the USA compard to nitrohouse.
Old 04-12-2004, 08:21 PM   #1167
sup
sup's Avatar
spez, tc3 springs will fit the ld3 but will bind (affects handling, trust me, i tried it). youre better off getting the hongnor spring set. in my case, i use mugen springs (white in front and blue in the rear) but have filed the inner part of the spring that has contact with the retainers and the collars so that there is no bind.
sup is offline   Reply With Quote
Old 04-12-2004, 11:57 PM   #1168
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by Tabushi
Hi guys,
PM me first if you do decide to get the Pro kit......I have an "almost" Champion edition looking for a new home. Just missing the carbon/alloy shock towers.........
Just rebuilt.....Lots of new bits like 7075 chassis.....roll bar mounts etc...etc..etc will save you a lot of money....
dtm is offline   Reply With Quote
Old 04-13-2004, 12:46 AM   #1169
luketob's Avatar
Does anyone knows the difference in weight between LD3 pro and the champ edition?
luketob is offline   Reply With Quote
Old 04-13-2004, 02:13 AM   #1170
How much? post some pictures please
Icung is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
