Old 03-25-2004, 07:21 AM   #1021
spenzalii's Avatar
Send a message via AIM to spenzalii
The failsafe plugs in between the throttle servo and the receiver. In the event of loss of signal (either due to radio interference or loss of voltage) the failsafe will move the throttle servo to a preset position and hold it. Some people, like myself, have it set to go to full brake. Others have the servo go to neutral, so they can coast and steer out of trouble. Once the interference is taken care of, servo operation goes back to normal.
Hope that helps
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 03-25-2004, 07:32 AM   #1022
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by havy
Keeps your car from going crazy when someone else w/ the same frequency turns on their radio. I highly recommend it, and over here for racing it's mandatory
best investment I've made.
havy
Not entirely true.....if you have interference the failsafe will go to a set position for the servo. If someone switches on using exactly the same frequency and the same brand TX as you....your car still goes crazy because it is recieving a valid signal...just slightly messed up..........
dtm is offline   Reply With Quote
Old 03-25-2004, 08:21 AM   #1023
spenzalii's Avatar
Hey guys, gotta get a new body for the ride. I really don't want to use the AudiTT just yet, and the Eclipse is now officially done. Any suggestions? I've had my eye on the new Mazda6....
Old 03-25-2004, 08:43 AM   #1024
Manticore's Avatar
R/C Tech Charter Subscriber
Stratus or stratus 2.1 the MG looks good too !
Manticore is offline   Reply With Quote
Old 03-25-2004, 08:47 AM   #1025
kevink2's Avatar
Default Re: thank you
Originally posted by Randy G
thank you for the info on the fail safe does it shut your car down or what
It just closes the throttle back down in case it gets stuck wide open, so you don't blow a motor or hurt someone. A mechanical throttle return spring (or rubber band/oring on carb) is the best solution IMO.
kevink2 is offline   Reply With Quote
Old 03-25-2004, 08:50 AM   #1026
kevink2's Avatar
The new Mazda 6 is the best handling body I've tried so far.
Old 03-25-2004, 09:01 AM   #1027
spenzalii's Avatar
Good deal. I'm trying to stay away from the Stratus and Alfa. Yes they work, but too many of them out there! So I've eyed said Mazda, MG and Altima (painted one, never ran it)
I'll have to post pics of theEclipse. Looks like a cut away...
Old 03-25-2004, 09:06 AM   #1028
IDrinkNitro's Avatar
Originally posted by dtm
Even if you convert the shaft to SG...you will still need to change the engine nut...but this may be an eaiser option!!
I do have a nut for sg shaft. It came with the pro kit. I will look into this and see what I can do. Thanks again
IDrinkNitro is offline   Reply With Quote
Old 03-25-2004, 09:14 AM   #1029
kevink2's Avatar
LOL seems like everyone here (in L.A.) is using the 6 now. Incredible steering with amazing overall downforce and stability. Being a true believer in the good old standard Stratus, I was totally blown away by the Mazda 6.
Old 03-25-2004, 09:24 AM   #1030
Local racer's Avatar
Default Ld3 pro
Hey let me guys ask you somthing do you have a problem with your oneways blowing out.
Local racer is offline   Reply With Quote
Old 03-25-2004, 09:35 AM   #1031
dtm
dtm's Avatar
Default Re: Ld3 pro
Nop!
Old 03-25-2004, 09:45 AM   #1032
dtm
dtm's Avatar
If you want to be different try the Kawahara TC shell.........
Old 03-25-2004, 09:46 AM   #1033
dtm
dtm's Avatar
The front of the car is definately for downforce!!!!
Old 03-25-2004, 09:53 AM   #1034
spenzalii's Avatar
Interesting. Must have a good paint job on it though...
Notice how this thread really is moving today?
Old 03-25-2004, 10:40 AM   #1035
Nope, it's connected to the throttle servo, it causes the servo to brake and not accelerate, giving you time to make it to the car and not have it run off on a wild rampage .
havy
havy is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
