Old 03-12-2004, 02:24 PM   #916
kevink2's Avatar
Originally posted by spenzalii
there is about a 1-2mm space in between the chasis and the bottom of the servo. I didn't want to rusk it and crack anything
Yeah I'm not sure about yours because I'm still learning about all these different versions. If there's only a small space inbetween, you can probably just add washers to take up the space.
kevink2 is offline   Reply With Quote
Old 03-12-2004, 06:13 PM   #917
just after some info on the differences between the ld3 pro and champion edition any help greatly appreciated
onto greener pastures
stuff for sale associated 12r5 $175, team magic 1/10 pit bag $40, top racing pit bag $30, KO helios with spektrum module and 3 receivers $200, CEN CT5 $100 all are plus post
dangles is offline   Reply With Quote
Old 03-12-2004, 06:27 PM   #918
Manticore's Avatar
R/C Tech Charter Subscriber
the champ version is a full option version but without alloy a-arm brace. graphite here and there and the alloy is in orange color. dtm calls it tangerine.
Manticore is offline   Reply With Quote
Old 03-12-2004, 06:32 PM   #919
There is a full list of the differences earlier on in this (or another?) thread...
au_Nightmare is offline   Reply With Quote
Old 03-12-2004, 08:28 PM   #920
spenzalii's Avatar
Send a message via AIM to spenzalii
BTW...Shock Bladders:Mugen ones work well too. My shop doesn't stock Kyosho, so he gave me some for a Mugen. No problems with the fit, no leaking at all
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 03-12-2004, 09:17 PM   #921
Got a part # plz?
Old 03-12-2004, 09:33 PM   #922
spenzalii's Avatar
Mugen Seiki D0508
Fits MSX/MTX/MRX
Old 03-12-2004, 10:51 PM   #923
Thanks..
Old 03-13-2004, 03:56 AM   #924
Angel727's Avatar
You can also use AE NTC-3 parts they fit perfectly.
Angel727 is offline   Reply With Quote
Old 03-13-2004, 09:55 AM   #925
spenzalii's Avatar
Finished the shock rebuild. I think I figured out why the car was tweaked so bad last season. I took one of the shocks apart to flush the oil. While cycling the shock shaft up and down, I took a look at the piston, which looked like it was moving. So I pushed it up, and the piston slid to the bottom of the shaft! One of the e-clips fell off the bottom, so the shock worked when it wanted to. how nice...
Now to check the wheel bearings
Old 03-15-2004, 08:34 PM   #926
sup
sup's Avatar
practically read the whole thread again to search tips.. question is regarding diff oil up front. for the rear, its really 100,000wt, but for the front, there is little info? any ideas what oil thickness should i use up front? thanks in advance!
sup is offline   Reply With Quote
Old 03-15-2004, 10:44 PM   #927
kevink2's Avatar
100,000 for the rear in conjunction with a front one way. Usually using two diffs, softer all around, with the front a bit heavier than the rear.
Old 03-15-2004, 10:53 PM   #928
Manticore's Avatar
with 100K diff oil, it just feels like 10K when compare with kyosho or mugen. go with something really nasty and sticky for the front, or solid/oneway?
Old 03-15-2004, 10:59 PM   #929
sup
sup's Avatar
so, if its diff all the way, the front should be thicker? would a 30K rear and 50K front do the trick? or should i go way thicker (like 100K rear 120K front?) just a note, with the previous set up (stock grease), LD3 "like a pig" (quoting DTM's post way back) and really sloppy at hairpins. would be redcing droop hoping to have more steering response without oversteering next time i hit the tracks.
Old 03-15-2004, 11:01 PM   #930
Manticore's Avatar
mentioned earlier, you need at least 100K for rear diff and you need something much thicker if you use front diff.
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
