Old 02-28-2004, 11:47 AM   #841
spenzalii's Avatar
Send a message via AIM to spenzalii
MAN!! All you guys running on permanent tracks, just know I hate you all!!!!
Just kidding
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-28-2004, 01:06 PM   #842
Havy, Looks like you have a mega smooth track (and I agree with spenzalii, I you too hehehe )
OK I am only a backyard club racer so one of u pro guys pull me up here if I am wrong
3 hole pistons on such a smooth track would be a bit soft?, I am running the 2 hole ones of 60f/40r oil on netball courts.
Right height seems too high, I run with 5mmF / 5.5mmR
This is from a 1/8 buggy chat but you get idea on how OFNA oil compares to Kyosho..
If you are using Kyosho oils you can try 7 or 10K in the middle, 5k in the front, and 3 or 1k in the rear.
If you are using Ofna oils you can try 50 or 120k in the middle, 30-50k in the front and 10 or 20 in the rear
You could try very very thick oil in rear so on power rear is a bit looser you just have to hold on to it
Also read:
http://users.pandora.be/elvo/
It will tell you how the Caster/camber etc is effecting you etc.
au_Nightmare is offline   Reply With Quote
Old 02-28-2004, 04:17 PM   #843
Thanks for the replys.... he he, about the track. It was only finished about three weeks ago. Before then we were strickly parckinh lot racing. If you guys are ever up for a visit, there will be a big 3 day LatinAmerican race to be held in early June so you guys are inveted . If interested I can give further details.
Things are just starting to get good down here. We've started a RC racing associacion and hopefully in a couple more years will have a couple more permanent tracks. Last race hosted approx 180 cars in cat of Touring Sedan, Outlaw 200mm, and Touring electric, as well as 1/8.
Will keep working with the setup to see if I can get better times...also lots of practice
Will give updates as I go, Thanks Guys
havy
havy is offline   Reply With Quote
Old 02-28-2004, 08:52 PM   #844
dtm
dtm's Avatar
Send a message via ICQ to dtm
Try heavier diff oil in the rear (Kyosho 100,000wt).
Take your front droop down (or up if you are reading from the droop scales). So that with your car sat down you can only lift the front end a couple of mm before the front wheels lift.
Less rear toe in.
Heavier rear anti roll bar
All the above will give you more on power steering......the last 2 may make your car more twichy...but than depends whether your fingers can follow!!
dtm is offline   Reply With Quote
Old 02-29-2004, 06:18 AM   #845
Trader Rating: 36 (100%+)
Default 8. Junk the original yellow springs...too soft.
DTM:
In Tower Hobbies website they describe the yellow springs as being almost the firmest set...is this a mistake, or is the HN set different?
http://www2.towerhobbies.com/cgi-bin...?&I=LXFES3&P=7
In the set up sheet, as done by Jeffrey Lin posted here a couple pages back, he suggests using the red (F) and copper (R) springs.
Anyone know of equivalent springs from another make?
NitroOB4You is offline   Reply With Quote
Old 02-29-2004, 08:23 AM   #846
dtm
dtm's Avatar
Must be a mistake because those yellow things are so soft i wouldn't even put them into my EP........
I have run Kyosho black up front and Golds in the rear for a while.....still not urgency to change this combination.....
Old 02-29-2004, 09:05 AM   #847
Less rear toe in.
*Will the OFN 50000 wt do?*
Don't have anit roll bars but try one, then add the other (etc) to let my fingers get accustomed to the changes
Thanks,
havy
Old 02-29-2004, 09:40 AM   #848
dtm
dtm's Avatar
Thanks,
havy
I've never used OFNA oil...but I know with Kyosho 100,000wt you have to "spoon" it out of the bottle!!
Old 02-29-2004, 09:44 AM   #849
Manticore's Avatar
R/C Tech Charter Subscriber
squeeze it just like how you use your toothpaste !
Manticore is offline   Reply With Quote
Old 02-29-2004, 09:48 AM   #850
OK, I'll try the 50000 wt I got already
If not I'll buy the Kyosho 100000 wt and get a spoon
Havy
Old 02-29-2004, 09:49 AM   #851
Manticore's Avatar
Havy
forget the 50K! even with 100K, it feels like 10K
Old 02-29-2004, 11:21 AM   #852
Manticore,
So you think it wont make much of a difference???
now you got me al confused
My car was an RTR I have slowly been adding mods to....I saw the pro version has an upper arm in the rear, should been thinking about getting this,....later I'm just going to get a pro vesion and run this my current car in outlaw.
I was aso wondering about the sway bars, I don't have any on my car. What do you think, I imagine I should get some too.
He he, got to get this thig gonig a little faster in te truns(I kow prctice has alot to do with this too )
Any more thoughts???
Havy
Old 02-29-2004, 06:23 PM   #853
sup
sup's Avatar
guys, ill be getting some hex drivers. just want to ask which ones are used most of the time? i have a 3mm one already (used for the countersunk screws). thanks!
sup is offline   Reply With Quote
Old 02-29-2004, 07:16 PM   #854
2.0mm for almost everything
havy
Old 02-29-2004, 08:47 PM   #855
spenzalii's Avatar
Usually you can just pick up a set. I got the 3 pc. Dynamite metreic set which does everything but the pivot ball retainers (so keep a hex key in the box just in case you break a knuckle). Beat and cheapest way to go, really. Just about everyone makes a set, so pick up whichever you like
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
