Old 02-25-2004, 07:27 PM   #826
kevink2's Avatar
I'll have it done by this weekend. Hopefully it won't rain.
kevink2 is offline   Reply With Quote
Old 02-25-2004, 09:04 PM   #827
C Verano's Avatar
Originally posted by kevink2
Hyper looks nice Chris.
Yeah it's pretty nice...You won't be disappointed with your LD3. Just get it together and get it on the track this weekend. I'll be there with Steve just in case you need anything.
RC Target, Capricorn RC, Matrix Tires, KO PROPO America, PowerMaster Fuel, Absolute Hobbyz, Bellybutton Paint
C Verano is offline   Reply With Quote
Old 02-26-2004, 03:42 AM   #828
Thumbs up au_nightmare
Thanks. I knew you would be the one to ask. What springs are you using? I find the yellow too soft.
Still a great car though.
Browny is offline   Reply With Quote
Old 02-26-2004, 04:22 AM   #829
Team-RTR's Avatar
hi, the SNR spring set is a must buy item if you own a LD3 and you are going to race it. the kit springs are way too soft, somethgin harder is definately needed
SERPENT | NOVAROSSI | XRAY | TEKIN | FUTABA
Team-RTR is offline   Reply With Quote
Old 02-26-2004, 05:08 AM   #830
Yes the Hong Nor spring set rocks... (come on team RTR your not in the USA, whats this SNR garbage hehehehe) even if you dont have a LD3 they fit other cars
au_Nightmare is offline   Reply With Quote
Old 02-26-2004, 08:07 PM   #831
kevink2's Avatar
Default Hyper prototype video
Paul Coleman driving the Hyper prototype at Crystal Park, posted in video gallery at the OFNA website:
http://www.ofna.com/videogallery.html
quicktime video
Old 02-26-2004, 08:16 PM   #832
C Verano's Avatar
Default Re: Hyper prototype video
quicktime video
Kev,
How's the build coming along?
Chris
Old 02-26-2004, 08:35 PM   #833
kevink2's Avatar
Aw man you caught me taking a break... it's going fine. I'll probably have some questions for you later...
Old 02-27-2004, 02:24 PM   #834
spenzalii's Avatar
Send a message via AIM to spenzalii
hey nightmare, if you don't get a crank for that sirio, you think you'll part with the carb? I have an idea for next parking lot season, if it would work....
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-27-2004, 02:29 PM   #835
Quite possible , whats the idea?
(umm better reply in PM as not to go too far off topic hehehe)
Old 02-27-2004, 03:27 PM   #836
hey hey, don't keep the secrets in the dark......I wanna learn the trick to make the Ld3 blazing fast....show up my Mugen Serpent friends at the local races
I had troouble at the qualifiers do to the oneway tranny slipping and the STS engine break down but I didn't do to bad for not having too much setup time w/ the repaired parts....
_______ -- TOURING SEDAN - H MAIN --
pos car laps___time_____name __________ _________id___avg.mph
1 9___25___10:21.78 MICHAEL HERNANDEZ___191___22.47
2 3___24___10:12.91 GILBERTO GONZALEZ___139___21.89
3 6___22___10:00.54 HAVY RAMOS__________10_&n bsp;_20.48
_______ -- TOURING OUTLAW - D MAIN --
1 4___27___10:01.06 ALFRED AESCHLIMANN___32___25.11
2 2___24___10:07.73 HAVY RAMOS_________& nbsp;156___22.07
___3 7___20___10:09.98 RADAMES VAZQUEZ_____129___18 .33
4 9___20___10:14.62 PAPOLIN DEL TORO_____49___18.19
5 5___10____4:28.57 LUIS J RODRIGUEZ_____64___2 0.81
6 8____8___10:03.73 EMILIO CRUZ_______ 124____7.40
-- 3___--- DNS ---____JORGE SERRANO_______ 60
-- 6___--- DNS ---____ROLO CRUZ_________&n bsp;_126
-- 1___--- DNS ---____JERALD ORONA_______ 170
-- 0___--- DNS ---____ANGEL TORRES_______ 199
....had a little more setup time for the Outlaw main...same car.
Could have done better, but it was a fun raceanyway...
The track:
http://www.mytsn.com/tracks/track.as...061&cm=1&adr=1
Gona be a latinamerican invitational race in June...will have more details later on if you guys want to come down to Puerto Rico
Thanks for your help so far
havy
havy is offline   Reply With Quote
Old 02-27-2004, 03:37 PM   #837
Keep one-way clean, maybe its where we race but It seems for me good idea to clean out before every meeting. Also clean up 2 speed shoes/bell, so it grabs nice and stays in 2nd.
What setup are you running now? post that (go through the setup sheet items) and maybe some ppl can have some input.
Also what is your current problem? not enough punch out of corners? steering? etc..
Old 02-27-2004, 08:28 PM   #838
spenzalii's Avatar
Let me ask you something...What servo are you running? I vagely remember my tranny slipping, but it stopped. I think it may have been when I swapped to a stronger servo. It seems the wheels were bouncing powering out the corners, sounding like it was bouncing in and outof gear. I have to go thru the other thread and see whether that was it or not...
Old 02-27-2004, 09:00 PM   #839
Well i got to thinking about the trans, and I omitted that the 2 gear housing got a little bent out of shape when my power cltch came loose from the threaded shaft. this may have cause the car to star off in second and maybe that's why the thing slipped so much, its wierd though, because when I would clean the thing wi some nitro fuel, it would run good for a couple of laps, then it would start to act up again. I just switched out the whole transmission for this race for a new one I bought off ebay(good deal- something like 65 dollars for the whole thing). On the race day, I only had time to put it all togeher and them race it, so I didn't get to tune it.
I'll sit down and review the set-up and post as per set-up sheet tomorrow, maybe there are somethings that you guys can help me out with...
From what I can remember,
Camber front:2deg, rear:3deg
...0 toe up front, 2deg toe in rear...
spings front:white, rear:kyosho blck progressive rear w 2 mm shim(softer)...
shock wght front 60,rear 50....
diff oil front Ofna 50,000wght, rear 30,000wght.
jaco foams 40shore 0 offset.
Stock RTR pinion/spurs...
STS MT12rs engine, 30% nitro
servos: JR metal gear 590 steering, standard throttle.
ride hieght is up there about 7-8mm front and back.
ohh, and floating rear body mount rear
RTR arms....I would like to get the pro upgraded arms soon.
Let me know if you need more details...
Thanks,
havy
Old 02-28-2004, 10:19 AM   #840
ok... whats left
front mounting blocks: 1.5 front of diff case and 0 rear, same in the back
Shock mounting positions, 2 hole up top both front and rear: on the front arms: outer hole, and in read 2nd middle hole.
ohh, and I exchanged the pistons to the 3 hole pistons from assiciated..
My main prob right now is I get alot of push under acceleration in the curves. I see all the guys running faster in the corners than I can. If I throttle too much(not fully puching it, but lets say I quarter trottle) I still can't hold my line well in the corners. I think I loose alot of time due to this.
Thanks agian, if you see anything wrong w/ this setup let me know.
havy
here is a shot of the infield of our track:
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
