Old 02-18-2004, 06:08 AM   #736
Nightmare, thanks...got to buy the lube for the one way. I did use nitro to clean it at the track, temp fix though, lasted a few laps, then went back to doing what it was doing.... I'll give it a shot.
havy
havy is offline   Reply With Quote
Old 02-18-2004, 06:12 AM   #737
I believe small bit of ATF fluid also works, but yeah also clean the shoes/bell, just as important while cleaning one-way and easy cause u got it apart anyway..
au_Nightmare is offline   Reply With Quote
Old 02-18-2004, 06:26 AM   #738
yeah, i might have some trouble taking the 2nd gear clutch apart. I bought an STS mt12rs for it since I was using the 3 shoe clutch, the I tried the power clutch and worked well until the adapter for it came loose, the whole thing pushed into the 2nd gear clutch bell and now the rim on the outside is bent in all the way around to the point that I can't remove it.
Going to have to get creative w/ that part.
I have a friend that put grooves on the 2nd gear clutches and the thing kicks when it goes into second. That's my next mod......once I get the oneway working
Is lubing the trans oneway a regular maintenace thing, how often should it be lubed?
havy
Old 02-18-2004, 07:02 AM   #739
IDrinkNitro's Avatar
Originally posted by SteveG
Biggest advantage is that you can adjust the point of engagement ie: early in the powerband or later in the powerband. Also there is probably 20%-30% more contact area in terms of clutch shoe meets clutch bell and that helps to provide a more positive engagment as compared to a 2- or 3 shoe clutch system.
Once you use a Centax type clutch you'll never want to use anything else
Many thanks Seeing I am new to this onroad thing and have never raced before the 3 shoe clutch should probably be good enough for a year or so right? I have a brand new Sirio with threaded crankshaft, this motor won't allow me to use centax style clutch correct?
IDrinkNitro is offline   Reply With Quote
Old 02-18-2004, 07:44 AM   #740
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by au_Nightmare
Dremel? Everyone in this small scale hobby always seems to use small scale tools (the dremel) I always bust out a decent rough file or even the 4" angle grinder when there is a bit of meat that needs removing.. Much faster then the dremel.
I'm lazy....I prefer to use electric power rather than muscle power!!!
dtm is offline   Reply With Quote
Old 02-18-2004, 07:46 AM   #741
dtm
dtm's Avatar
havy
I put a drop of Serpent One way oil in when I build it new........then leave it! If it ain't broke don't touch it. I've never had problems with the 2 speed one way.....
Old 02-18-2004, 07:52 AM   #742
dtm
dtm's Avatar
There is nothing really wrong with the 3 shoe. The centax gives you more adjustment....but to be honest...who adjusts their centax every week??? I know I don't!
In fact for a shaft car because the initial acceleration can be really strong...even with a centax running loose....it may even be better to run with a 3 shoe clutch. You will find you get less understeer coming out of a corner...especially if you are running a NR engine.
The handling of my LD3 is totally different when I put an OS TR engine in compared to a NR NS3 (both with centax) ...the NS3 has too much low end kick...I can run much better lines with the OS....only losing out on the straight.......
Old 02-18-2004, 07:54 AM   #743
My STS MT12rs is threaded shaft, there exists an adapter that will accomodate the power clutch. But be carefull, that is what cme loose one my car and ruined the 2nd gear clutch bell.
DTM, Nightmare,... thanks, lets see if I can keep my oneway working from now on, I hate to have a bad qualify due to this.
havy
Old 02-18-2004, 10:22 AM   #744
Thumbs up
Thanks guys, this forum has got to be the best around It sure is helpful to a newbie like myself
Old 02-18-2004, 10:28 AM   #745
spenzalii's Avatar
Send a message via AIM to spenzalii
I wish I could remember what I ended up doing when I had the same problem. The car would sound like it was slipping in and out of second gear, mainly when I was accelerating in a corner. When I changed the gears and checked the shoes, I haven't noticed it since. Go figure.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 02-18-2004, 03:09 PM   #746
Thats where the 4" angle grinder comes in.. 650W Grinder Vs 125W dremmel, see I'm lazier !!
Old 02-18-2004, 04:49 PM   #747
Would I be classed as the laziest or most motivated in this group I have a vertical milling machine
I think thats what I'm going to work on tonight if the kids stay outa my hair long enough....steering servo mounts...might not be as pretty as Ofna's optional CNC'd aluminum jobbies but hey if they do the job all is good.
SteveG is offline   Reply With Quote
Old 02-18-2004, 06:59 PM   #748
dtm
dtm's Avatar
OK you win the laziest competition!!!
It may be worth ordering the alloy mounts anyway because they are tapped at both ends to allow you to secure to upper deck and chassis.
Old 02-18-2004, 07:35 PM   #749
sup
sup's Avatar
i have made my decision not to go for the centax type clutch idrinknitro. it wouldnt last you a year though. the thing that wears the most are the springs, the part of the spring that has contact with the crank. you will notice this when the engine dies when you put the car on the ground and engage the trigger. happened to me after running-in the engine (about 3/4 gallon). just check the springs regularly and have spares with you all the time (springs and shoes). be sure to remove the glaze (shoes and bell) too every time you open up the clutch.. ill send you info on tuning the shoe type clutch, a fellow LD3 racer gave me some tips on fine tuning it!
sup is offline   Reply With Quote
Old 02-18-2004, 07:44 PM   #750
Sup thank you very much. I will make sure I have extra springs and shoes in my pit box for sure. I look forward to receiving that information on tuning the clutch Many thanks!
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
