Old 02-08-2004, 08:27 PM   #661
Trader Rating: 36 (100%+)
Default .08 Centax
Ok, I know this subject has been gone over before, but I am still confused a bit...
I know Nitrohouse has this "new" clutch available...they have
PART# 38620 Power Clutch 0.8 Gearing (LD3,MTX3,TC3)
and
PART# 38640 Trans, 0.8 Gearing LD3
Both, I understand are needed...however, I have seen some say that the Mugen offering is cheaper...NitroHouse has the Ofna version roughly $180 for both together...What I am looking for is a part number or perhaps a direct link where both "sides", or the clutch and trans of the Mugen are sold.Or should I simply get the Ofna version from NitroHouse.Better still, is there an aftermarket company version available.Any help is greatly appreciated.
NitroOB4You is offline   Reply With Quote
Old 02-08-2004, 10:04 PM   #662
Default Diff Screws
I lost my rear diff (but still won club meet so thats cool)
see photo here:
http://www.serverdoc.com/personal/pi...e_reardiff.jpg
I broke one diff screw (2mm x 6mm) in half but still ran the diff :O as you can see the rest of them pulled out..
And thoughts on why I would break a screw??
au_Nightmare is offline   Reply With Quote
Old 02-08-2004, 10:36 PM   #663
sup
sup's Avatar
Default Re: Diff Screws
see photo here:
what the heck are you doing with your LD3 nightmare?!?! i guess that is your "war car"! kidding aside, i think the diff lube dried up.
sup is offline   Reply With Quote
Old 02-08-2004, 10:43 PM   #664
Silicone oil does not dry up in less then 24hrs
Got issue with screws coming out (= loosing oil)..
Can't find part number for the small screws.. might put in M2x6 flat hex head screws.. hmm
Old 02-08-2004, 11:10 PM   #665
What a mess
SteveG is offline   Reply With Quote
Old 02-08-2004, 11:19 PM   #666
Manticore's Avatar
R/C Tech Charter Subscriber
you might need to use 2x8mm instead. 6mm is a bit too short.
Manticore is offline   Reply With Quote
Old 02-09-2004, 12:28 AM   #667
Yeah its a mess but not as bad as I expected when I first opened gear case (mind you it was melted shut! lol), I am surprised the gears are not totally mashed, the gears where DRY so it must of come apart in the qualifiers or very early in the 20min final
Manticore, Ill do just that. Thanks for your input
BTW on closer inspection, it looks like worn bearings that caused it. ill be sure to keep a better eye on things, and use the longer screws
Old 02-09-2004, 03:32 AM   #668
Set up!!
That diff looks painful!! Good to get the win though.
I was able to pull out a club win too. Beat a Trinity Reflex, V1RR and a MTX3.
My problem is set up. My rear tyres were absolutely wrecked. Can anyone point me in the right direction regarding set up? I know there was talk about it before but I've lost where that was. I'm looking at springs, tyre shore, camber etc.
I love my LD3.
Browny is offline   Reply With Quote
Old 02-09-2004, 07:27 AM   #669
C Verano's Avatar
see photo here:
Use the machine screws that are used on the one way...Never had issues with screws coming lose after switching to those.
C Verano is offline   Reply With Quote
Old 02-09-2004, 07:30 AM   #670
C Verano's Avatar
Default Re: .08 Centax
and
I don't think the mugen 2-speed will fit on the LD3. You might just want to go with the the complete OFNA set just so you don't have to worry about fit.
Old 02-09-2004, 08:37 AM   #671
dtm
dtm's Avatar
Send a message via ICQ to dtm
and
I have been using the Mugen and Kyosho centax with Kyosho old style gears (1.0 pitch) without any problems. For the spurs gears you can stick with the HN 1.0 pitch gears that comes with the car.
dtm is offline   Reply With Quote
Old 02-09-2004, 08:40 AM   #672
dtm
dtm's Avatar
Default Re: Set up!!
I love my LD3.
Keep adding camber until your tires wear flat.....I think I have about 4-5 deg in the back of my LD3......and around 2 deg up front......
I try to run the same shore front and back (40). If need be I will go no more than 3 shores different between F/R if you need anymore you should look at the settings on the car.
Old 02-09-2004, 02:56 PM   #673
Talking Thanks
Thanks DTM.
My camber was 0 degrees, but that is obviously way out. I will adjust for the next meet.
Happy racing
Old 02-09-2004, 03:00 PM   #674
Default Re: Re: Diff Screws
thanks, I knew I delayed my order for some reason. Ill get some 2mx 8mm machine screws (2mm longer then one-way ones) Should be stronger then the self taping ones also.
Old 02-09-2004, 05:32 PM   #675
I'm speechless....my champ arrived today 7 days from HK is incredible
Gonna get some chow and then go through the boxes
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
