OFNA LD3 pro
Old 01-26-2004, 05:24 PM
  #571
Registered User
I also have that question too. Don't know is it for front or rear? If it can use on both, how to change rear toe? I don't see they come with different degree.
Aku-Man is offline
Old 01-26-2004, 05:43 PM
  #572
Manticore's Avatar
Originally posted by au_Nightmare
My arm holders where just # LS-17, but thats a Hong Nor number. (Why OFNA renumber stuff, they should keep it the same like when XTM rebage the Rex-x they keep all the same MV part #'s)
I assume "Aluminum CNC Lower Arm, Holder PART# 38446" comes with the pivot balls.
they come as in different parts
Manticore is offline
Old 01-26-2004, 05:44 PM
  #573
Manticore's Avatar
they are for both front and rear. same thing.
you adjust toe in/out from the pivot suspension.
Old 01-26-2004, 06:49 PM
  #574
They fit both front and rear so you need 2 sets of them.
BTW - when you put in the 1, 1.5 ect degree arms you are setting the anti-squat, not toe in/out.
au_Nightmare is offline
Old 01-26-2004, 06:51 PM
  #575
Manticore's Avatar
i dont see a need for antisquat for on-road racer unless you have a bumpy track.
Old 01-26-2004, 07:18 PM
  #576
Registered User
Default .8 gear is out in U.S.
Power Clutch 0.8 Gearing - $89.65
Trans, 0.8 Gearing - $79.96
at Nitrohouse.
They are quite expensive.
Aku-Man is offline
Old 01-26-2004, 07:21 PM
  #577
Manticore's Avatar
Default Re: .8 gear is out in U.S.
at Nitrohouse.
get the price list from hobbyplayer site, they are relatively cheap inside taiwan.
Old 01-26-2004, 07:31 PM
  #578
Anyone know if the threads (for gears) on the "old" power clutch can take the new 0.8 gears?
I am gussing the threads would be the same so you can use say new 2 speed with old clutch (with new gears fitted)
Old 01-26-2004, 07:33 PM
  #579
Trader Rating: 36 (100%+)
Default HobbyPlayer
What is this Hobby Player site??? Can you post a link please?
NitroOB4You is offline
Old 01-26-2004, 07:38 PM
  #580
http://www.hobbyplayer.com/
My language skills suck though, I can read the url and that's it...
Old 01-26-2004, 07:45 PM
  #581
Manticore's Avatar
just use a mugen clutch with 0.8 pinion. the mugen mtx3 clutch set is damn cheap but you need to shim the engine mount a little bit taller.
Old 01-26-2004, 07:51 PM
  #582
But ive already got the HN Power clutch thats why im wondering if the new gears fit old clutch.. Might ask later once a few more ppl have the 0.8
Old 01-26-2004, 08:12 PM
  #583
sup
sup's Avatar
manticore, what if i use the engine mounts from the standard kit (i think its taller), would it be a direct fit or would it be too tall? am considering on getting the mtx clutch. thanks!
sup is offline
Old 01-26-2004, 08:13 PM
  #584
Manticore's Avatar
i have the pro kit which comes with the power clutch. i am not sure about the stand engine mount height. but it should work !!
Old 01-26-2004, 08:39 PM
  #585
CL
CL's Avatar
Trader Rating: 33 (100%+)
The new gears will not fit the old clutch.
CL is offline
