Old 12-31-2003, 08:38 PM   #331
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by Manticore
the 0.8 gear module. alloy arm mounting brace, 4D clutch
I'd rather have the alloy mounts instead of the optional brake pads. Kinda strange that the brakes can lock like hell but running with a front one way you have to turn the braking effect down anyway..........
dtm is offline   Reply With Quote
Old 12-31-2003, 08:42 PM   #332
dtm
dtm's Avatar
Originally posted by spenzalii
Now if only I can find the US price for it, I may just save up and get it. If it's under us$350, I'm sold
HKD2580 = USD330.........go buy one!!
Old 01-01-2004, 02:15 AM   #333
Manticore's Avatar
R/C Tech Charter Subscriber
buy 2, just like what you did !
Manticore is offline   Reply With Quote
Old 01-01-2004, 01:05 PM   #334
Registered User
Default Warpspeed Helicoils diff case
Hey guys, Warpspeed can insall helicoils to LD3 diff case to prevent screws stripping. I just send my to them. $20 + shipping.
I have their tc3 blueprint diff case. They work very good.
Aku-Man is offline   Reply With Quote
Old 01-01-2004, 06:51 PM   #335
dtm
dtm's Avatar
$20 buys you a lot of diff cases....
I have had no problems with mine yet. Probably taken apart 5-6 times. I find the art of not stripping the thread is to screw the screw in about 3/4 the way in. Wait about 20-30 seconds (or put in another screw), Then screw the remainder of the screw in "just as you feel it go tight...stop"
The plastic gets pretty warm when you first put the screw in, by waiting a little while the plastic cools down and then end point becomes more obvious. Something I picked up during my thread striping Tamiya days!
Also, having threaded the plastic... when you put the screw back into the threaded hole.....back thread the screw until you feel a slight "click" then forward thread the screw...you would have picked up on the original thread you made...rather than cutting a second thread. I still strip threads occasionally...but it is less frequent rather than more frequent.
Old 01-01-2004, 06:53 PM   #336
Manticore's Avatar
i let you do my diff next time, will you?
Old 01-01-2004, 06:56 PM   #337
dtm
dtm's Avatar
only if you clean out the old gunk first!!!
Old 01-01-2004, 07:06 PM   #338
Manticore's Avatar
I want you to do the hardest part actually !
Old 01-01-2004, 07:35 PM   #339
sup
sup's Avatar
i tried out the associated springs and they fit. they are slightly longer. i tried the gold ones from my electric and it seems the gold springs are harder than the black ones that came with the kit!? i think i will be going for the kyosho springs (hope the length is the same with the ld3 springs).. thanks guys!
sup is offline   Reply With Quote
Old 01-01-2004, 08:12 PM   #340
dtm
dtm's Avatar
The spring length is not that important...providing you can get all the adjustment you need as your foam tires wear out. You can use the Kyosho front and rear springs...I found that using the Kyosho front springs at the back of the LD3 will not give you enough adjustment.
Old 01-01-2004, 08:13 PM   #341
dtm
dtm's Avatar
I know...thats why I said you clean the crap out first!!!
Old 01-01-2004, 08:13 PM   #342
dtm
dtm's Avatar
Default New Tangerine
Some build pictures of my new Tangerine!
Old 01-01-2004, 08:14 PM   #343
dtm
dtm's Avatar
Not much to look at initially..but it gets better.......
Old 01-01-2004, 08:15 PM   #344
dtm
dtm's Avatar
If you are a cheat...then you can always start from the back......
Old 01-01-2004, 08:16 PM   #345
dtm
dtm's Avatar
If you like them plump round the waist...you can start from the middle.....
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
