Old 12-28-2003, 12:50 PM   #271
I used some small pliers to grab the spring tail and twist so it would align correctly, its pretty easy with the pliers..
BTW - I did notice my new tank had a different seal I dont think I had problems with old one though but I did put more tension on the lid..
au_Nightmare is offline   Reply With Quote
Old 12-28-2003, 08:53 PM   #272
dtm
dtm's Avatar
Send a message via ICQ to dtm
The first batch tanks had felt seals...the latest has rubber seals which do not leak. HN sent out replacement caps to the distributers when they found the problem (at least in HK they did).....whether the distributer handed them out to the shops was another matter!!
dtm is offline   Reply With Quote
Old 12-28-2003, 09:16 PM   #273
Just checked, my LD3 Standard (only new) has a rubber seal, my LD3 pro (I think its a very early one as it also had the faulty one-way in the 2speed) has felt.
BTW Where do you people mount the transponder on the LD3? (pic?)
Old 12-28-2003, 10:19 PM   #274
Onetrip's Avatar
Default LD3 Pro break rod length?
I'm setting up the throttle servo and got the linkage setup up
ok going to the throttle but the rod going to the break lever
seems to be too short. My radio has end point adjustments
and break trim but i can't seem to get the break set up right.
when i give it full throttle the break rod pulls out too far from the
lever and just dangles. The break rod is 54mm long but i think it
needs to be at least 15mm longer.
It is the stock one that came with the kit. Anyone got any ideas.
How long is everyone's break rod?
If i need to get another one from the shop, is it 1.5mm thick?
THX
Onetrip is offline   Reply With Quote
Old 12-28-2003, 11:29 PM   #275
dtm
dtm's Avatar
I had the same problem with my brake rod...I simply made up a new one at 80mm...plenty of length...
Old 12-28-2003, 11:54 PM   #276
Manticore's Avatar
R/C Tech Charter Subscriber
same here !
Manticore is offline   Reply With Quote
Old 12-29-2003, 12:06 AM   #277
I had same problem also, I thought I was doing something wrong lol.. I didn't have any longer rods so this is what I have done with both my LD3's...
Old 12-29-2003, 12:07 AM   #278
Onetrip's Avatar
Default Thanks...
I thought it was just my building skills or lack or reading
directions...
THX!!
Old 12-29-2003, 05:57 AM   #279
sup
sup's Avatar
nightmare! thats a bit drastic!? hehe! to each his own. anyway, i replaced mine with a longer one.. anyone know what is the spring load of the black shock springs that came with the standard kit? i guess its really that soft.. any good spring combination for a medium sized, high traction track? how about for a medium-low traction track? thanks! happy new year to all!
sup is offline   Reply With Quote
Old 12-29-2003, 06:40 AM   #280
hello from France,
here's some pics of my T2M Venom XTR (same as the champ edition).
Happy New Year to everybody and Make modelism not War...
My personnal pages (3 pages of LD3 champ car)
romuald31 is offline   Reply With Quote
Old 12-29-2003, 07:06 AM   #281
dtm
dtm's Avatar
The yellow ones that came with the Pro and Champ are also really soft.....I junked those and am using some Kawada springs for the Sigma....had them lying around. Although for this next car I will probably use some Kyosho front springs....Will be trying the 3x1.7mm in black......
Old 12-29-2003, 07:19 AM   #282
sup
sup's Avatar
thanks dtm! ill try the kyosho ones too.. hope they fit.
Old 12-29-2003, 07:25 AM   #283
dtm
dtm's Avatar
NP..the Kyosho springs will fit fine. I imagine that the car will like the silver (softer) or the black Kyosho springs.... going by the Kawada springs I run...which are in between these two.
Old 12-29-2003, 07:30 AM   #284
Manticore's Avatar
the stock yellow spring should be rated at 1.3 and this is way softer then silver or black kyosho springs.
Old 12-29-2003, 07:32 AM   #285
dtm
dtm's Avatar
The stock yellow springs are even softer than the springs I run on my Xray EP......
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
