Old 08-11-2004, 01:38 AM   #1696
LD3, but ask in the NTC3 forum and im sure they will say NTC3
au_Nightmare is offline   Reply With Quote
Old 08-11-2004, 04:18 AM   #1697
dtm
dtm's Avatar
Send a message via ICQ to dtm
Originally posted by macnkitty2002
all i know is that .8 is better than 1.0
not necessarily....0.8 gives you much ratio options and is "supposed" to be more efficent. However, in terms of durability and criticality of gear meshing.... 1.0 pitch wins hands down.
dtm is offline   Reply With Quote
Old 08-11-2004, 04:19 AM   #1698
dtm
dtm's Avatar
Originally posted by adsl
the frame structures of LD3 and NTC3 are similar,
Which is better?
LN4..........
That question deserved that answer!!!!!!
Old 08-11-2004, 07:11 AM   #1699
Macnkitty2002,No I'm not the only one w/an rc out here,we got 2 lhs out here. They mostly drag race over here w/funny cars and stuff.one of the local dragers took second place in the winter finaly in s.florida last year so we get around.The parts I can't get here I order them from tower H & NH.
Also Havy I got peeps in bayamon & cauguas & vieques so next time i'm out that way i'll link up w/you to check out the tracks over their. I got a backyard setup track,it's two full and a half tennis courts that setup for circuit race.It's got aprox.135ft of straight and like 80ft wide. The car hooks pretty well for howit's setup I wanna try it on a bigger track and see how it dose... more fire
Blaze1 is offline   Reply With Quote
Old 08-11-2004, 09:28 AM   #1700
macnkitty2002's Avatar
hopefuly you took the tennis nets down before you established the track. but you are lucky to have one too. i use my electric 1/10 on the tennis courts near my house in the winter since nobody uses them. and you are right, they do hook up well.
macnkitty2002 is offline   Reply With Quote
Old 08-11-2004, 02:38 PM   #1701
yea its what ever they use on the top it what makes it so good. on some corners i'll just rip right thru no brakes to test the susp. and it stays planted. rubber or foam she stays put, a lil drift here & there but not squaking just want to run on a bigger track to see how i do.... more fire
Old 08-11-2004, 02:47 PM   #1702
does anybody else use your private track?
Old 08-11-2004, 10:31 PM   #1703
Default SETUP
I am having trouble setting up my two LD3... Just a little back ground. I have a Tangerine pro and the reg 2sp ld3 with a CD3 conversion on the way. I also have a rs4 3 for bashing..
my ld3 have a mills os .12 tr and RB .12.
need help selecting gearing on the pinon and two speed spur gear. Also setting up the Camber, caster and toe for front and read. I recenlty purchased a setup station... Prior to this I was eyeballing.. and way off.
ALL help would be appreciated....
zleader is offline   Reply With Quote
Old 08-12-2004, 05:34 PM   #1704
Hey check back a couple of pages,
But my basic rundown:
front:
Caster: I have the upper arms all the way forward, no shims in front.
0 toe
2 deg camber
Rear:
1-1.5 deg toe
4 deg camber R, 4.5 deg L
Front diff, 120,000 Ofna wght, 6 gear
Rear diff, 50,000 Ofna wght, 4 gear
Front king pin mount 0 and 0
Rear 1.5 and 0 antisquat
Gearing stock
Fun, yes, handles loose but holds well when asked too
havy
havy is offline   Reply With Quote
Old 08-12-2004, 06:59 PM   #1705
Default Thanks
I have read most of the thread... Just trying to get a feel for the tuning. I picked up a setup system. I tell you, my eye it method was sad.
Over the past few months I have just been practicing with the car, I was finding I was fighting it all over the track. So I tried some basic chassis setup and things got better.
I appreciate your response.
Hey the stock 3 shoe clutch is good for beginers like me. However my Tangerine LD3 with the centax is going to be a blast to drive.
Is it worth changing the 3 shoe on my rtr ld3 to a centax. I read back a little the mugen will fit. If I read this correct which versions will accept the ld3 gearing.
Old 08-12-2004, 09:36 PM   #1706
I plan to upgrade to 0.8 gearing so centax will be needed. I got to learn to set it up correctly though. The three shoe clutch has been reliable, I just set the idel on the motor to get the response I would like out of the turns (within reasonable limits, don't want to keep the revs up too long in idle).
Soo, I let someone esle tell you about the mugen centax.
Havy
Old 08-12-2004, 09:49 PM   #1707
I tell you... I have searched HI an LO for a good forum on LD3's. I have been out of RC for about 10 years and was bitten by the buy. Now I own three nitros and 2 ld3 with a cd3 conversion kit on the way and a bashing rs4 ss...
I have read most of the forum mail and have learned a lot without having to sift through a lot of junk...
MY RTR now has a os .12 tr and the tangerine a RB x12. My next major upgrade will be a decent radio system.. Looking at a KO mars R gold edition...
Old 08-13-2004, 07:00 AM   #1708
macnkitty2002 I get together w/some friends on the weekend to race, but i'm always bashing the car around in front of my house my son gets a kick out of it.When he gets older he's gonna be my pit man. more fire
Old 08-13-2004, 07:45 AM   #1709
IDrinkNitro's Avatar
The KO Mars R is awesome
IDrinkNitro is offline   Reply With Quote
Old 08-13-2004, 02:58 PM   #1710
spenzalii's Avatar
Send a message via AIM to spenzalii
I want that XS3 Pro. Really kooooool......
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
