Old 07-14-2004, 10:53 PM   #1621
yep, 2 deg over here too in front.
Shore ratings, 37 front and 40 rear. I use Enneti at the moment, also used nitro shoes and mono tuning. I like then all about the same. I've found Elegi to wear a little faster than the others I mentioned.
havy
havy is offline   Reply With Quote
Old 07-14-2004, 10:58 PM   #1622
Nightmare, thanks...
got the PM. Think I'll wait for the kit to come out, 0.8 gearing sounds good to me.
havy
Old 07-15-2004, 12:02 AM   #1623
I like the features of the .8 gears but on my track I need a high 2nd gear ratio and tight 1st & 2nd gear spreads...our straight is about '100 and the infield is pretty tight.
Here's a comparison screenshot of the highest ratios and tightest spreads for the stock gears and the 0.8 gears...
Click me
With the gearing I'm using and a 12TR mated to the kit pipe my setup is most certainly a stump pulling combination I think
SteveG is offline   Reply With Quote
Old 07-15-2004, 03:59 AM   #1624
hello from France,
Camber isn't a problem.
Set it at -3° at home all around (check it when you got your ground clearance 4mm front and 5 mm rear front tyre diameter 61mm and rear 63mm).
Then , at your track, make 1 run , and check the real camber on each wheel.
And now you can adjust the cone of each tyre.
Maybee 4° front left and 2° rear right, but no problem if the tyre wear at the same speed left ou right , front ar rear, always have -2°cone.
I use .8 gear since 6 month and it's much better : bigger ratio and no broken gears because the plastic is more reliable.
see you
romuald
romuald31 is offline   Reply With Quote
Old 07-15-2004, 07:11 AM   #1625
spenzalii's Avatar
Send a message via AIM to spenzalii
Alright, 3 to 4 degree it is. I'll set it up tonight when I swap the springs over. I'm running 40 shore Fast Tires all around. Wear is pretty good; just the coning. Front seems to be cool with 1.5. I may go to 2 to even it up a bit more, but that should do it.
Never knew how much that floating rear would affect things. I guess that explains teh rear skipping instead of turning.
I also wish I could figure out what was up with that pipe. I wonder if it was worth trying to tune the engine to the longer pipe or just keep on with the ripple pipe, which seems to still work just fine. Can't keep frying plugs like that
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 07-17-2004, 06:02 PM   #1626
Default Loose, spinning rear
Here is my question for the masses:
My LD3, once the car has been driven a few laps starts to spin almost 360's when I exit turn and add throhte.
Any ideas as to what might be causing this?
Track conditions med - high traction, large track, temp 70 - 90 degs.
Current setup
Front:
Toe 0 deg
Camber -2 deg
Springs Copper
Oil 55 (what I had)
Top shock position 1
Bottom shock position 2
Antiroll bar flat
Using Front one-way
Tires 42 shore
Rear:
Toe -2 deg
Camber -3 deg
Springs Red
Oil 55 (what I had)
Bottom shock position 3
Antiroll bar flat
Using def with 100,000 oil
Tires 40 shore (tried 37 same problem)
Thanks! for any and all help.
VRF201
VRF201 is offline   Reply With Quote
Old 07-17-2004, 06:10 PM   #1627
Try 0 to -1.5 rear toe.
My car doesn't respond well to -2 toe in. Spins similar to what you mention. Softer springs in the rear.
I use 120,000 wght up front and 50,000 rear.
havy
Old 07-17-2004, 06:37 PM   #1628
Thanks! Havy
One more question:
What would changing the rear diff to 50,000 due for me?
Thanks!
VRF201
Old 07-17-2004, 06:46 PM   #1629
Makes the front pull the car keeping the rear to follow so to speak. I don't know if anyone can explain that better for me, but give it a try, you may like it. I did.
havy
Old 07-17-2004, 06:56 PM   #1630
Thanks for the quick response.
Should the change work with the front one-way?
Thanks!
VRF201
Old 07-17-2004, 07:00 PM   #1631
It should work well.
havy
Old 07-17-2004, 07:01 PM   #1632
Thumbs up
Great!
VRF201
Old 07-17-2004, 10:47 PM   #1633
Have any of you LD3 tuners ever experienced what I got happening here ?? After trying various things over the last week and today trying another engine I'm running out of things to try...
Old 07-17-2004, 11:37 PM   #1634
kevink2's Avatar
VRF201: You didn't mention which pistons you are using. You can try stiffening the front sway bar, stiffening the front shocks, adding front toe (+1 deg.). Also you could try more rear toe (-2 to 3), softening rear shocks, get rid of rear sway bar altogether, etc.
SteveG: Try drilling more holes in your tank cap lid.
kevink2 is offline   Reply With Quote
Old 07-17-2004, 11:45 PM   #1635
Uh huh...I was just getting my drill bits and pin vise Kevin
Geesh my wife is gonna kick my *** if I fire this thing up one more time down here tonight Gotta get it going though....wanna go play sunday afternoon !
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
