Old 06-22-2004, 05:13 PM   #1516
Yep, I had the old 12RS hand mod because I use the standard clutch bell. had to hold off on the .8 gears for a little bit, will be my next mod.
Nightmare, I have a question about the servo saver. There are only 2 bearings. Are you supposed to use the bushings too? And which one do I use on which part, there is a flanged type and the normal type.
Thanks, I got my upgrade on hold right now.
havy
havy is offline   Reply With Quote
Old 06-22-2004, 05:28 PM   #1517
Your missing bearings
Alloy Servo Saver photo
Im too tired ATM to think how I put mine together.. lol.. :(
au_Nightmare is offline   Reply With Quote
Old 06-22-2004, 05:39 PM   #1518
yep, missing bearings
Well, going to have to use bushings.
havy
Old 06-22-2004, 05:53 PM   #1519
No way, go get ur bearings - did paid for'em.. Bushings will just wear into the alloy :P
Old 06-23-2004, 08:27 AM   #1520
Thanks for the support guys ... I've calmed down some since my Monday Rant, lol. Spare parts ... I had "one" of about everything but that doesn't seem to be enough. The aluminum hinge pin holders sound like a good item to pick up. For the moment I'm "punishing" my LD3 by putting it in the closet for a week a so until it learns to behave itself ... well, maybe until I'm not so eager to drop kick it into the next county.
"It's not cursed, it's not a lemon, it's just a string of bad luck."
(repeat this mantra as needed, not to exceed 13 times a day)
And maybe, just maybe, I need to slow down some til I've got it dialed in.
-John
Luckyman4 is offline   Reply With Quote
Old 06-23-2004, 08:36 AM   #1521
HEy guys I got a ? that needs a little clarifying here. When you screw the trans screw in the car shits faster and out it takes longr right. If this is correct then my problem is solved. I had the screw in to far so the car would hit 2nd like that booom w/oout even hearing or seeing it.The car moves man, now that its being leaned it acting like another car WOWOWOW....
Blaze1 is offline   Reply With Quote
Old 06-23-2004, 08:47 AM   #1522
IDrinkNitro's Avatar
-John
Bad LD3 Bad LD3 learn to hold yourself together Bad Bad LD3
IDrinkNitro is offline   Reply With Quote
Old 06-23-2004, 09:16 AM   #1523
spenzalii's Avatar
Send a message via AIM to spenzalii
I think you have that backwards. The tighter the screw is, the later it will shift. It will take more centrifugal force to spread teh shoes to engage second gear. Whereas if the screw is loose, it won't take as much force and it will shift into second faster. Regardless, glad to hear you got it working.
This episode is brought to you by the letters M, T, X and the number 4....
spenzalii is offline   Reply With Quote
Old 06-23-2004, 11:13 AM   #1524
IDrinkNitro,
ROTFLMAO!!
It helps to about it, otherwise I'd be
-John
Old 06-23-2004, 02:59 PM   #1525
Blaze, just be careful where the car shits and you should be OK. Don't run over it on the next lap LOL
As spenazi said... tighter shifts later, looser shifts earlier.
Sa far as me and my steering servo, don't know how it happened but not sure if I opened the ad and lost them so not going to rant, just be more carefull next time. I got 2 of the four missing bearings from spares I had lying around, but the small bearing are no where and no LHS has them, so bushings go ack in .
I have a car I'm building that I bought on ebay, it has every hop-up, got a STS D3 to put in there . It's almost full option, doesn't have 6 gear diff and only has one sway bar, other than that It's full option. I haven't run w/ sway bars yet but don't know if I want the sway ar up front. Maybe in ack to keep the steering up. I'm putting the 6 gear diff 120 OFNA wght silicone oil up front and leaving 50 wght in back, what do you guys think?
Also doing the same in the RTR, but it has STS RS5port (pre dragon but new) and no sway bars. Was my Sedan, now my outlaw
havy
Old 06-23-2004, 04:58 PM   #1526
spenzalii's Avatar
300K front, 100K rear....
Old 06-23-2004, 04:59 PM   #1527
Yes they are this is the ass end of my Ld3 pro...
Old 06-23-2004, 05:10 PM   #1528
Man, I don't have 300k, but I think I'll go 120 6 gear diff up front and 120 4 gear diff rear.
I tried 4 gear diff 120k up front and 4 gear 50k rear and rearly liked the fact the car went where I pointed the front tires w/o getting fishtail. Awsome new feeling for me w/ the car, could power out of turns like never before. I give the aove combo a shot. Thanks.
Now, should I leave the sway bar up front or move it back and put harder springs/oil up front? Any guesses . Kind of limited on what I can do. Want to keep the 2 cars as similar as possible so I don't have to adjust to much for each category.
havy
Old 06-23-2004, 06:06 PM   #1529
Default Interesting body post holders
Say au_Nightmare
Where did you get the cool body post holders for
the rear of your LD3?
Thanks!
VRF201
VRF201 is offline   Reply With Quote
Old 06-23-2004, 07:22 PM   #1530
sup
sup's Avatar
thats the floating rear body mount.
nightmare, what are those blue rings in your shock body? hope everythings well down under. been almost a month now since i fired up my ld3. rain rain go away! i hate 2 seasoned country's
sup is offline   Reply With Quote
ofna mbx comp with hyper 21 8 port and ofna true start box. smokinu R/C Items: For Sale/Trade 8 07-20-2008 12:37 PM
OFNA MBX Ultra Competition Buggy and OFNA Starter Box 4 Sale or TRADE!!! gunlocators R/C Items: For Sale/Trade 14 03-20-2007 10:01 PM
Ofna micro fail safe, jr z650m 650 servo, and rtr ofna radio set cappa R/C Items: For Sale/Trade 13 02-03-2005 11:35 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 12 06-29-2003 06:30 PM
Ofna Ob4 rolling chasis, Ofna .12, Trinity pipe, K&n filter chongp R/C Items: For Sale/Trade 0 05-31-2002 03:19 PM
