Old 06-16-2008, 05:06 PM   #1
poochy's Avatar
Default NTC3 engine mount screws stripped-help!
I went upgrade the flywheel and engine brackets to bump start version on my ntc3 but I ended up stripping 3 of the 4 engine mount screws. the screw distractors I have aren't strong enough for the engine mount screws.
Can anybody help please? How do I get these screws out now? This hurts.
poochy is offline   Reply With Quote
Old 06-16-2008, 05:18 PM   #2
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
are you talking about the motor mount or the four on the bottom that hold it in place
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 06-16-2008, 05:56 PM   #3
Seisick's Avatar
dremel with cutting disc
just make sure dont cut too much
and then use philips driver to loose the screws
use proper allen wrench in standard size or inches
as used in the ntc3
HobbymaniA
GoT MuGeN?
Seisick is offline   Reply With Quote
Old 06-16-2008, 06:10 PM   #4
wingracer's Avatar
Trader Rating: 24 (100%+)
What he said. Use a cut off wheel in a dremel tool to cut a slot in the screws then just pull them out with a screw driver.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-16-2008, 06:26 PM   #5
poochy's Avatar
Thanks I will try it. The screws I stripped were the 4 under the chassis.
Old 06-16-2008, 06:29 PM   #6
poochy's Avatar
can I use a powerdrill instead of a dremel? sorry I never used a dremel before. also -any particular cutter disc you guys recommend?
Old 06-16-2008, 06:32 PM   #7
wingracer's Avatar
The fiberglass reinforced ones last a whole lot longer. The cheap un-reinforced ones that come with most dremel's will do the job and cut a more narrow slot, just be careful and wear glasses, they will blow apart.
Team Shepherd USA
Old 06-16-2008, 06:33 PM   #8
wingracer's Avatar
Oh, and a drill just won't be fast enough.
Team Shepherd USA
Old 06-16-2008, 06:38 PM   #9
poochy's Avatar
i got one of these super high torque power drills that plugs into the wall. it saids it can do 12,000 rpm. will that work?
Old 06-16-2008, 06:49 PM   #10
poochy's Avatar
coworker has a dremel-doesn't look easy but will try.
Old 06-17-2008, 11:36 AM   #11
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
wear protection for your eyes + face if you've never done this
those discs explode when hot and used at non perpendicular angles.
i got lucky my first time when it exploded - if those pieces hit me it wouldve been brutal.
cut the slots in a well ventilated area too, the metal cut out will be airborne for a while.
R3VoLuTiOn is offline   Reply With Quote
Old 06-17-2008, 11:40 AM   #12
poochy's Avatar
I have strong eyeballs-I dont need goggles!!!
sike-i got the screws out-put goggles on and dremel those son of a bit**es right out with ease-thanks for the great tip everybody
Stripped screws pinky2252s Nitro Off-Road 2 05-30-2008 01:30 PM
Stripped motor mount screws DriveToLive Nitro On-Road 5 11-26-2005 01:17 PM
stripped out screws onnetz Electric On-Road 9 02-18-2005 07:01 AM
Stripped screws ........ how do you take them off ? asw7576 Electric On-Road 11 10-31-2004 05:48 PM
Stripped Screws Horse Singapore R/C Racers 4 10-16-2002 08:28 PM
