Old 06-16-2008, 06:44 PM   #16
MugenDrew's Avatar
Trader Rating: 30 (100%+)
Well check this thread out. Old slot car trick with the oil-lite/sintered bronze bushing, boil it or all 50 of them in Mobil-One. Much better lubricant and a thicker body than what they will be supplied with in my own experience.
Direction; no doubt balls out; flat face of the cage to-wards the flywheel/engine. I use Mugen B0330 Super joint grease and have never lost a thrust bearing. I have seen a whole bunch of stuff work really well and it all seams to be based on its ability to adhere some sort of film at high RPM.
Whatever it is your using can be applied into a syringe for much easier application. I use syringe's from www.westsystem.com #807 three pack and there cheap. You can order or get them at any boat place.
Keeping this bearing lubed and maintained seems to be the most important things.
Next up when should it and the outer clutch bell bearing lock-up?
Mugen Seiki Racing Desoto Racing Race AKA Byron Original Fuels Arrowmax Sanwa RC America
MugenDrew is offline   Reply With Quote
Old 06-16-2008, 11:53 PM   #17
Roelof's Avatar
Send a message via ICQ to Roelof
Originally Posted by Loveless View Post
Roelof, where did you get this brass from and what are the dementions to it if you dont mind me asking?. looks kewl...
As I did mention you can get them at every hardware store as washers for M5 bolts, these rings are 5x10 ast the most 1/8 thrust bearings are.
Indeed the right bronze is better and I am still waiting for ceramic rings.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-17-2008, 04:27 AM   #18
LOSI123's Avatar
Trader Rating: 63 (100%+)
so with wheel bearing greese, does it stay in there?
or is it still advisable to re-greese before each race meet
LOSI123 is offline   Reply With Quote
Old 06-17-2008, 06:05 AM   #19
MugenDrew's Avatar
At bare minimum I would recommend cleaning/greasing it at the start of each race day and before the main when your going thru everything else. If its apart for whatever reason while your there grease it.
Old 06-17-2008, 08:25 AM   #20
mcsquish's Avatar
double post
mcsquish is offline   Reply With Quote
Old 06-17-2008, 08:25 AM   #21
mcsquish's Avatar
I have used Ronny Grease (I think that's how it's spelled) but since it isn't sold anymore I'm not sure what to use when I run out. That stuff is awesome for all sorts of things..........
Old 06-17-2008, 09:38 AM   #22
jameslow's Avatar
sorry to ask, what really does the thrust bearing helps? i once try using the normal ball bearing to replace the thrust and i dun find much different! Can anyone help? Thanks!
jameslow is offline   Reply With Quote
Old 06-17-2008, 10:23 AM   #23
Roelof's Avatar
When the clutch engages it will create an axial force on the end of your crankshaft. Becaus the slip while engaging there is a rpm difference between the crankshaft and the clutchbell and that needs a some kind of bearing.
A normal bearing can not stand the axial forces.....
Old 06-17-2008, 10:25 AM   #24
asw7576's Avatar
Thrust bearing is the proper bearing to be use for lateral axis movement, in this case, lateral movement of clutch bell. During clutch engage, the centax clutch will expand and push out the clutch bell outward. The trust bearing will keep the clutch bell intact.
In off road cars, they use regular bearing because there are no lateral axis movement in clutch bell.
Old 06-17-2008, 10:44 AM   #25
asw7576's Avatar
Wanna bet ?
In electric / gas cars, the wheel bearings position in steering knuckles and rear uprights, .... those bearings are holding the wheel axle from lateral movement : The steering knuckle / rear upright is holding the outer ring while the inner ring is holding the wheel axle. Consider tire side impact, Side cornering Grip, those bearings are holding the wheel axle from side collapsing.
I use normal bearing 5x10 as thrust bearing in my NT1. Only NT1 clutchbell can accept normal bearing. No problemo with axial movement.
Old 06-19-2008, 07:23 AM   #26
Roelof's Avatar
Originally Posted by asw7576 View Post
Wanna bet ?
Then you do use 2 bearings as axial. Yes, they can stand some axial forces but if it will create play it will affect the clutchgap.
By the way the bearing will be pushed to the end tip which holds the hole bearing. Now I think about that you only did fill up the space and only the outer ring of your bearing is picking up the forces.
Old 06-22-2008, 12:05 AM   #27
freestyles's Avatar
Trader Rating: 14 (100%+)
Arrow GREASE?
I have never put grease on my thrust bearings and have never had a problem since i have done it this way. When i put them in i always have the open side facing the front or out. I have molybdenum grease by tamiya would that be ok to use. Also wouldn't that brass bushing create friction?
Kewl bro i like the balless thrust bearing, i will look into this set up, if my cage ever gives.
freestyles is offline   Reply With Quote
Thrust Bearing HulkNT1 Nitro On-Road 2 06-27-2008 08:06 AM
wanted. Slapmaster thrust bearing or Axiom thrust bearing... Tron 101 R/C Items: Wanted to Buy 1 03-24-2008 10:34 PM
Thrust bearing 20 SMOKE R/C Items: Wanted to Buy 1 10-28-2007 07:02 AM
thrust bearing Fuzzy Electric On-Road 5 08-17-2005 07:55 AM
thrust bearing peahbeez Electric Off-Road 3 04-27-2005 03:08 PM
