Old 06-05-2008, 10:25 PM   #1
Default ntc3 plus 2 speed problem
i bought a used ntc3 off of ebay and the guy before me switch out the 2 speed bell for a 1 speed. i put back the 2 speed and i push the car forward and when the spur gear does one complete rotation it stalls. i look as if it skip a tooth but the guy i bought it off of said he didnt change the gears. also when i roll it back it stops. any help please.
i read the install guide but it was no help
Vi3tPhantom is offline   Reply With Quote
Old 06-05-2008, 11:27 PM   #2
Trader Rating: 65 (100%+)
Send a message via ICQ to Barneys Racing Send a message via AIM to Barneys Racing
Default check the 2 speed clutch
there are clutch shoes inside the 2 speed, make sure they are free or that the adjustment on the 2 speed isn't out of whack. you can download the manual at www.rc10.com. it will help you solve the problem. take the trans apart and make sure it's all clean and free. it only costs a few dollars to get new shoes and hardware for the 2 speed.
hope that helps.
Barneys Racing is offline   Reply With Quote
Old 06-05-2008, 11:28 PM   #3
oh...and by the way, the driveline on a NTC3 is one way. that's why you can roll it backwards.
Old 06-06-2008, 06:39 AM   #4
i tryed adjusting the 2 speed but it kept skipping tooth. i probably pick up a new one
Old 06-06-2008, 06:48 AM   #5
if you downloaded the manual, theres a list of pinion vs spur chart that gives approved ratios. If the first and second gear pinion to spur teeth count is off, you will have issues.
Baedarlboo is offline   Reply With Quote
Old 06-06-2008, 06:58 AM   #6
the owner before me said he didnt switch out the spur gears. he only put in a 1 speed bell and left every as it was.
Old 06-06-2008, 07:06 AM   #7
So you would rather go off his word then to double check in the manual? If thats the case, you should have bought a new car from a local hobby shop.
Old 06-06-2008, 07:28 AM   #8
It seems here, he used a single speed pinion on a 2 speed tranny. The only way i can see that working, is if he locked down the second gear. That pinion isn't even on the 1st gear. So yes, if he locked down that second gear, then you will have mesh issues. An advise i can give you is, break the car down, check for wear, and put it back together according to the manual. Some one who locked down second gear to use with a single speed pinion is something that hints this guy does things half @ssed. I'm sure it's not something you want to hear, but it's the truth. Also, when you break things down, you learn how the car operates. If I were you, i'd break down all the driveline parts, and inspect it, like diff's, and rebuild it. There's no telling what this guy did, and didn't do to the car seeing that he rigged the car up. I also hope that you make holes in the body to allow air flow, if not, you motor WILL over heat.
http://cgi.ebay.com/ws/eBayISAPI.dll...ayphotohosting
Old 06-06-2008, 07:35 AM   #9
i check the manual and the gear fit fine.
Old 06-06-2008, 07:38 AM   #10
yea he lock the 2 speed. he had the silver screw in the 2 speed half out. how do i tell if the diff is damage.
Old 06-06-2008, 08:17 AM   #11
is the 3 screw on the 2nd spur gear suppose to touch the 1st spur gear?
Old 06-06-2008, 09:28 AM   #12
pull the 2 speed out and inspect it, make sure it's not deformed or anything.
As far as the diff, the front should be screwed in all the way and then back off 1/8th of a turn, should feel nice and smooth when you turn one wheel with the brakes on, if it feels gritty, it needs a rebuild. The rear should be screwed in all the way and back off 1/4 turn, should also feel nice and smooth when you turn one wheel with the brakes on. If not, it also would need a rebuild. All of this info is in the manual. Shows every bit of how to pull things apart and put it back together. Follow the manual, and you'll be good.
Old 06-06-2008, 09:28 AM   #13
NO
Old 06-06-2008, 09:30 AM   #14
Originally Posted by Baedarlboo View Post
NO
ok problem solve. the guy had the screw to long to lock the 1st spur gear. thanks alot baedarlboo
Old 06-06-2008, 09:36 AM   #15
OS Speed 21 Low Speed Needle Problem chrisv Nitro Off-Road 2 07-13-2008 08:47 PM
ntc3+ rtr problem spaceman spiff Nitro On-Road 5 11-25-2005 05:03 PM
just another NTC3 2 speed problem.......HELP! GeeTee Nitro On-Road 16 06-28-2004 06:18 PM
NTC3 problem hashini Nitro On-Road 9 02-19-2003 08:33 AM
NTC3 problem hashini Rookie Zone 1 02-16-2003 09:32 PM
