break in bench noise solution
I read on a thread to put a exhaust pipe silicone extender onto the tip of the pipe and put that into a bucket of water to lower the noise level of the break in bench. Does anyone see an issue that this would cause? It sounds like a good idea and If there is no issue there then I will probably try it.
It is done a lot on toyfairs but with a brake in stand and a proppellor it is the prop making noise......
I sure wish their was a quiter way to break engines in.. i love using my prop stand but my neighbors aren't overly fond !
Suspended
possible moisture in engine? try a plumbers vacume breaker or your engine could sound like its a yamaha ha ha cheers!
you ain't kidding about the noise i had to do two motors over two days i thought somebody was going to kill me with all the noise i was making....
Suspended
noise
i have seen chamebers used after the pipe that reduce noise and no water nesasary i believe they are in all jet ski personal water craft made out of pvc and fiber glass whithout added back pressure! cheers
I've seen this done at wintrnats!
get every thing ready to break in start the motor and get things running
pipe and all !
Then place a two liter plastic coke bottle up to the pipe mark for a hole for the pipe to insert into the coke bottle and remove the lid to the coke bottle and this quiet's it down greatly !
later
Jeff E
I guess it works like a ext to the pipe!
pipe and all !
later
Jeff E
pipe and all !
later
Jeff E
pipe and all !
later
Jeff E
You got my curiousty!
Do you mean insert the stinger from the pipe into the coke bottle? I want to try this!
pipe and all !
later
Jeff E
pipe and all !
later
Jeff E
curious, i had assumed the primary noise source was intake roar. So did you notice what they did for the intake side? was there an INS box or?
it occurs to me an added benefit of the coke bottle is it collects the large amount fuel and oil that spews from the exhaust.
intake
I dont believe there is much that can be done on the intake side, due to the propeller coming so close to the carb. I was concerned about that with regards to debris getting into the engine, but I have been using the break-in bench for about 3 years and never had any problems.
I use an air filter off of my 2.5 Tmaxx it has just enogh clearence not to hit the prop. I had to cut a notch in the prop cover . I just can't run an 500.00 engine with no filter. The 2.5 tmaxx filter has a very short 45 degree angle
