Old 06-04-2008, 09:44 AM   #1
asw7576's Avatar
Default Fuel line length for 1/8 and 1/10 GP cars
Hello people,
I want to know the length of fuel line you guys are running in 1/8 and 1/10 GP cars. Do you people also use a fuel filter in between ?
I have fuel starvation problem in the past with my MRX4-R. I cannot use a fuel filter and fuel line length greater than 10cm ( 3 inches ). I have to keep the fuel line very short, and voila..... suddenly my engine can run perfect. But, one time I loss a brand new p/s/r due to particles entering into combustion chamber.
Thanks.
Old 06-04-2008, 09:53 AM   #2
Suspended
The gas tank has a built in filter, so you don't need to use one. For the fuel line, just use enough to get from the gas tank to the carburator, you don't need any extra. For the pressure line from the pipe to gas tank, use a pressure chamber (by mugen) between the two pieces of line.
As for your fuel starving problem, if it continues after you change the fuel lines then your carburator needs adjustment.
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 06-04-2008, 10:13 AM   #3
Loveless's Avatar
What does the pressure chamber do anyways?. i have them installed on sedan and my 1/8th scale?.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 06-04-2008, 11:06 AM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
I calms the violent pressure changes coming for the pipe. It's the same thing as using a longer piece of fuel tubing from pipe to tank. It also can give better midrange response due to the decrease in tank pressure a mid throttle.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 06-04-2008, 11:15 AM   #5
lil-bump's Avatar
Originally Posted by asw7576 View Post
Hello people,
Thanks.
Not sure what you mean by fuel starvation. If your engine runs too lean when you use a longer piece of fuel line I would look for a leaky fuel tank (up high). Also how long is your pressure line. I've had problems in the past if the pressure line is too short to much air enters my tank which cause my fuel to froth real bad. This added air mixed with my fuel caused my engine to run really lean from 1/2 tank to empty.
Good luck. Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 06-04-2008, 11:20 AM   #6
duneland's Avatar
Use of the chamber keeps pressure up to the same level as pressure line of the same length. Longer line drops pressure. Both dampen out the pulses. Chamber good.
duneland is offline   Reply With Quote
Old 06-04-2008, 11:24 AM   #7
lil-bump's Avatar
Hey Duneland,
That LS1 really sucks; it off to get modified.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Old 06-04-2008, 12:34 PM   #8
duneland's Avatar
Thought you would get that result! I might remove a bunch of metal from the inside of mine and give it another go. It's going to require MAJOR mods to be competetive.
Old 06-04-2008, 01:42 PM   #9
Roelof's Avatar
Send a message via ICQ to Roelof
Mods.......
A simple balloon can replace the Team Orion Constant Pressure Device....
Fuel line length for 1/8 and 1/10 GP cars-balloon.jpg
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-04-2008, 05:00 PM   #10
Hello people,
Thanks.
Asw I thought I was doing something wrong when I added the Mugen pressure chamber the engine seems to run lean, and this happened on every time I tried the chamber with new and old lines eventually I took it off and voila engine perfect just as you experienced, now the pressure chamber just sits there
Guys should I richen up when added a pressure chamber ??
jelayne is offline   Reply With Quote
Old 06-07-2008, 03:54 PM   #11
asw7576's Avatar
Yes, I guess so.
Make sure the pressure chamber is air tight and sealed correctly, otherwise it has less pressure going into the tank, or worse a pressure leak.
Mine is sitting in drawer too.
Old 06-07-2008, 03:55 PM   #12
asw7576's Avatar
What fuel length do you people use ?
Old 06-07-2008, 04:41 PM   #13
duneland's Avatar
I have never had a problem with the Mugen pressure chamber. Never had to richen to use it. Run the min fuel line length and the min pressure line length.
Old 06-07-2008, 05:59 PM   #14
Tommy Bergfeldt's Avatar
Send a message via ICQ to Tommy Bergfeldt
I've always used a short as possible pressure line, since i had some oil clogs many years ago when using long lines which messed up the engine tuning..
fuel line can be a little longer if i really need the runtime.
JMI Motorsport / Red Bull Racing
HB Cyclone TC - Schumacher CAT SX & Cougar SV
Advanced Electronics - Autopartner.se - Sav÷x - NorthTQ
Tommy Bergfeldt is offline   Reply With Quote
Old 06-13-2008, 09:02 AM   #15
asw7576's Avatar
Mods.......
Interesting mod.
Does it inflate when you give a full throttle ?
Return fuel tubing length - how to lower pressure in tank charlesd Onroad Nitro Engine Zone 3 06-13-2008 11:32 PM
Fuel Line Length Captpete Rookie Zone 2 05-29-2008 12:16 AM
whats the recommended length for the pressure line ? mrgsr Nitro On-Road 1 05-09-2005 12:42 PM
Pressure Line Length SteveG Nitro On-Road 15 01-09-2004 04:07 PM
Fuel Line Gundam Singapore R/C Racers 4 01-02-2003 11:28 PM
