Old 05-30-2008, 03:12 PM   #1
charlesd's Avatar
Default question on lipo pack for a receiver
Hi,
I have a spektrum dx3 with a nimh pack. I'm thinking of switching over to lipo. I found a 1300mah pack that fits my car. Now my question is on the regulator.
It has to be 6 volts but how many amps? I found a 6v 2 amp regulator by the same company. Is this ok for one high torque servo up front and a regular servo at throttle?
thanks
charlesd is offline   Reply With Quote
Old 05-30-2008, 03:19 PM   #2
ESWLFSE's Avatar
Send a message via Yahoo to ESWLFSE
It would probably be OK. I use the 10 amp Castle BECs.
ESWLFSE is offline   Reply With Quote
Old 05-30-2008, 06:00 PM   #3
charlesd's Avatar
10 amps for a receiver and that is ok? You cannot fry anything can you if you use more amperage but keep it at 6volts?
Sorry for all the questions but i really know nothing about rc electronics.
Old 05-30-2008, 06:50 PM   #4
s10dude's Avatar
Originally Posted by charlesd View Post
Hi,
thanks
you could email the company that sells the regulator and ask if it is rated for RX packs..
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-31-2008, 01:20 PM   #5
mcsquish's Avatar
I'm not trying to hijack the thread, but ESWLFSE, what voltage did you set your regulator for? I just picked up a Castle Link but I'm not sure if I want to go higher then 6 volts.
mcsquish is offline   Reply With Quote
Old 05-31-2008, 02:59 PM   #6
RayJ's Avatar
Losi makes a 6volt regulator that I believe is rated at 5amps. I've used it for the last few months and it works flawlessly. Novak also makes one that would work. It's amazing how more consistant the servos are from the beginning of the race until the end.
RayJ is offline   Reply With Quote
Old 05-31-2008, 07:05 PM   #7
charlesd's Avatar
I picked up a novak 5460 today. When i get the battery and charger next week i'll test it out.
This model has 3 amps at 6v. I'm guessing for an on road car, 3 amps should be more than enough.
Old 06-01-2008, 12:03 AM   #8
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I run that novak regulator on my RRR and my IGT car. I have a losi regulator in my Truggy.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 06-01-2008, 08:00 PM   #9
geeunit1014's Avatar
10A means it provides up to 10, the rx and servos only draw what they draw. the only reason they would pull more is if something were jammed in the servo, making the motor work ecesively hard.
mcsquish- i would probably set it a few tenths higher(6.2 or .3), since when a nimh pack puts out more than 6 when fully charged. or maybe higher if your trying to get performace out of junky servos
Mike Gee
Awesomatix USA/Pyscho Cells Racing/Tekin/Sweep Racing/RSD/180 Raceway/Johns Mobile Raceway/TQ Wire/Avid/Sanwa
geeunit1014 is offline   Reply With Quote
Old 06-03-2008, 03:15 PM   #10
duneland's Avatar
Geeunit, what are you doing on this nitro on-road thread?
Charlesd--what he said is exactly right. bec unit must be able to supply the current (amps) that the rx and servos demand. The bec and rx battery pack does not 'force feed' the rx and servos, merely supplies what is needed. One could have a bec rated too low, but not too high. If the bec had too low of a rating, it could over heat or burn out.
duneland is offline   Reply With Quote
Old 06-04-2008, 08:57 PM   #11
ive been known to to run nitro occasionally also, too add to what dune said, if your running spektrum and the bec is too low, it could cause a failsafe. i remember this happening when it first came out, and i had a hi power servo and a sport esc that had a weak bec.
Mike Gee
Old 06-07-2008, 12:53 PM   #12
razzor's Avatar
3 amp should be perfect for 1/10 but not for 1/8 or offroad.
Just for some security though there are a lot of 5 amp ones available.
I use VXR and Nosram 5 amp ones with no hassles in the 5 vehicles running them.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Looking for JR receiver and lipo pack baj2374 R/C Items: Wanted to Buy 1 05-08-2008 12:51 PM
Lipo receiver pack/regulator question thecman26 Nitro Off-Road 16 05-06-2008 02:56 PM
Receiver pack lipo or not Mike Elam Nitro Off-Road 7 03-18-2008 11:58 PM
Lipo receiver pack Question.. SCUBA STEVE Nitro On-Road 20 07-17-2006 01:51 PM
