Old 05-29-2008, 04:35 PM   #1
Default Gas Engines
Why can't companies just make scaled down, 2-stroke gas engines to replace the nitro ones?
This would eliminate the need for glow igniters (-> spark plugs) and starter boxes (-> built in pull start), the fuel would be cheaper (although on the rise, it is still way cheaper than nitro), and the engines themselves would be cheaper because gas engines are used in many other applications.
They would also sound more realistic too. Not as high-pitched and whiny as nitro engines.
lemansracer is offline   Reply With Quote
Old 05-29-2008, 04:55 PM   #2
Suspended
first of all, nitro engines run at around 35,000 - 45,000 rpm, where as gasoline engines run at less than 1/4 of that speed.
and secondly, it would be difficult to make a gasoline engine small enough for 1/10 and 1/8 cars, and even if they did it would be much heavier than a nitro engine.
when you miniaturize something, there comes a point where going any further would make it not work effectively or efficiently.
Hope this helps
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 05-29-2008, 06:01 PM   #3
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
But if you were to do it with Desiel fuel, it could be done. I remember reading somewhere about it about 3 years ago where a Russian was building conversion kits to do it, but I don't know much more about it. Let me see if I can find something:
Here: http://davisdieseldevelopment.com/gallery/closelook.htm
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-29-2008, 06:08 PM   #4
rcfoolz's Avatar
On another thought, Audi built a race car that ran on Desiel and it was "TOO FAST FOR ITS OWN GOOD."
Read about it here:http://www.leftlanenews.com/audis-di...-own-good.html
The power that the desiel fuel provides with the lubrication will extend the life of a nitro motor ran on desiel 33 times longer!
Old 05-29-2008, 06:13 PM   #5
rcfoolz's Avatar
also, check this out.....http://davisdieseldevelopment.com/home.php
Sorry for spelling diesel wrong
Old 05-29-2008, 06:32 PM   #6
tomkelley's Avatar
Not to mention, i think gas is more toxic and lower flash point compared to nitro. A much safer fuel in the pit area.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
Old 05-30-2008, 12:12 AM   #7
Roelof's Avatar
Send a message via ICQ to Roelof
Oh yes, I have seen small engines (.40ci) running diesel and normal unleaded petrol on base of selfcombustion or small spark plugs. The problem with these fuels is that they can not follow the high revs we need and the concept of a glowplug is giving a pre-ignition on higher revs while with an electronic ignition you have to devellop some kind of motor management.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
