Old 08-05-2003, 08:31 AM   #1
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
Default screw threadlocked to chassis
well I went to clean up my NMT (yes I know its a "off road") but the topic will fit here and I will probably get more responses faster)
i got 3 of the 4 motor screws out but the 4th wond budge. the little bit that I can turn/twist the engine with that screw in shows that the screw isn't moving as the motor moved. so I guess it would be thread locked to the chassis. how do I get that off.
corvettecrazy is offline   Reply With Quote
Old 08-05-2003, 08:59 AM   #2
NitroNut's Avatar
Take a dremel of some sort and make a slit big enough for a flathead or a philips.
NitroNut is offline   Reply With Quote
Old 08-05-2003, 09:30 AM   #3
VenomWorldOrder's Avatar
Default Re: screw threadlocked to chassis
if 3 of the 4 come of, take the whole car apart leaving only the chassis and engine mounts and grab the engine mount that has the screw in it, nowturn it anti clockwise. it should loosen the screw....hopefuly.
always use allen head screws (hex) and replace when they show play.
VenomWorldOrder is offline   Reply With Quote
Old 08-05-2003, 09:37 AM   #4
Default Re: Re: screw threadlocked to chassis
i didn't want to go to that extreme but it looks like I will have to.
oh goodie another thing I have to buy
nitro nut: i dont get it
Old 08-05-2003, 10:10 AM   #5
sbmon's Avatar
nitronut solution is easier
basically just turn the motor screw into a flat head screw head
with a dremmel cutting wheel (you have a dremmel right,they should come w/ car kits along with that throttle return spring i mentioned)anyway by turning the screw into a flat head
you can use a large screw driver (more power)to free the screw, yes it will
ruin the screw but it is easiest
good luck and try not to dremmel any of your chassis inthe
process
sbmon is offline   Reply With Quote
Old 08-05-2003, 10:52 AM   #6
nope i dont have a dremmel.
dont have a return spring either
actually I dont have alot of things
Old 08-05-2003, 11:00 AM   #7
Manticore's Avatar
the above + use of heat to melt the thread lock !!!
Manticore is offline   Reply With Quote
Old 08-05-2003, 12:21 PM   #8
Default Re: Re: Re: screw threadlocked to chassis
yeah I read heat it with a soldering iron...the only thing I got out of that was a burned finger!!!! i would rather take everything off the rear of the car than burn my finger again.
Old 08-05-2003, 01:14 PM   #9
popsracer's Avatar
corvettecrazy;
Sounds like you used WAY too much Threadlock. A tiny drop on the screw threads is all you need.
If your Chassis is NOT countersunk, you can grab the Head of the Screw with the Jaws of some Side Cutters (wirecutters) and turn it out this way.
A Quality #2 Phillips Driver goes a long way here.
good luck,
popsracer is offline   Reply With Quote
Old 08-05-2003, 01:30 PM   #10
well too much is a very large possibility
and the chassis is counter sunk.
Old 08-05-2003, 08:10 PM   #11
lee82gx's Avatar
nail polish remover(esther) is the solvent for CA and threadlock(and many other stuff too).
try a few drops in and around the screw hole.
remember,it will melt plastic and anodizing too.
lee82gx is offline   Reply With Quote
cutting screw holes in chassis protecter film benben10 Electric On-Road 7 07-12-2008 03:03 PM
Getting out screws that are threadlocked HotrodHopkins Electric On-Road 12 06-27-2006 02:33 PM
stucked and stripped hex screw on chassis.. pinggoy Electric On-Road 9 04-14-2006 10:33 AM
WTB T3 SCREW SET coolguy5 R/C Items: Wanted to Buy 1 08-24-2005 10:14 AM
Does the TC3 Graphite Chassis Kit come with droop screw adjustment arms and chassis? ixlr8nz Electric On-Road 4 04-13-2003 10:34 PM
