Old 05-24-2008, 02:45 PM   #1
Default NTC3 Steering Problem
Hey guys, so fired up my car this morning, ran fine for the first 1/2 tank or so, brought it in cause I wanted to adjust the needles and it shut off. Idle was too low. While I was adjusting the idle screw and double checking everything was still okay the wheels went all the way to the right. When steering left the servo tried to get back to LEFT but only got to the middle. When trying to go right it hit my chasis plate as it was already extreme right. I tried unplugging the battery from the RX and the TX and firing it back up, worked for a little bit then it jumped back. Also tried unplugging the RX connections to hopefully "reset" it, again worked for a little then went back. I adjusted the st. trim on the TX and even tried a different battery pack. Can anyone help please?
SDNitroGuy is offline   Reply With Quote
Old 05-24-2008, 03:14 PM   #2
RAP66's Avatar
Two possibilities come to mind: stripped servo gear or wrong servo horn.
Rich Pedro
[email protected]
www.rcracing.com
RAP66 is offline   Reply With Quote
Old 05-24-2008, 03:52 PM   #3
Team Kamikaze's Avatar
Sounds like you have a Bad Servo.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-24-2008, 03:58 PM   #4
I picked up this car yesterday from another RCTech member and it was running fine when I got it and also ran fine this morning.
Do servos just go nuts and die like that out of the blue?
Old 05-24-2008, 04:43 PM   #5
RAP66's Avatar
tuff to say because there are many scenarios that could cause a problem... move the steering by hand, you might feel a dead spot in the servo gears. In that case u need to at least replace the gears. OR upgrade the servo.
What servo is do you have for steering??
-Rich
Rich Pedro
[email protected]
www.rcracing.com
Old 05-24-2008, 04:51 PM   #6
Roger's Avatar
change the servo.
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 05-24-2008, 05:46 PM   #7
goodtunes1978's Avatar
Send a message via AIM to goodtunes1978 Send a message via MSN to goodtunes1978 Send a message via Yahoo to goodtunes1978
i had the stock servo in mine and done the same as well i changed it to a futaba brushless and didnt have the problem anymore put the servo on aknown working receiver and it done it again so i just threw the servo out was dead to me lol
http://sadkermit.com the day is almost apon us to engage our second amendment rights
http://www.youtube.com/watch?v=SmVAWKfJ4Go rip ole man
http://www.youtube.com/watch?v=g0bZtf5MCzY nin done a great job
goodtunes1978 is offline   Reply With Quote
Old 05-24-2008, 06:08 PM   #8
Hey guys went to the LHS and they figured out the problem. The servo arm screw had wiggled loose and vanished. So they popped off the arm, centered the servo and put the arm back on and supplied me with a new screw. All for free, woo. Brought it home and ran right around 2 tanks through it. What a blast! Now to clean it up for the next run. I want to loctite the servo arm screw but need to know how to remove my upper deck, any tips? Also, I think I need to recenter my servo because my TX trim dial is all the way left and it still pulls right a little. Thanks Guys for all the input
Old 05-25-2008, 10:34 AM   #9
RAP66's Avatar
go to the associated website and download the manuals. For the adjustment I would swap out the linkage to something with a turnbuckle
Rich Pedro
[email protected]
www.rcracing.com
Old 05-25-2008, 01:35 PM   #10
By linkage do you mean the servo arm? Sorry, very new to this. And you're referring to my request to re-center the servo? I went to AE website and got the kit manual, I think I know how all of it secures down, now to do it
Old 05-26-2008, 01:07 AM   #11
kidsid99's Avatar
Trader Rating: 53 (100%+)
Top deck should come off by taking 6 screws out 4 on top and 2 underneath the chassis. The linkage referred to is the adjustable link that goes from the servo horn to the steering linkage that mounts to the chassis. It looks like one of your front turnbuckles that go to your steering knuckles except shorter. You can get your servo as close to center as possible then take out the rest by adjusting the turnbuckle. Look at the manual and it will show you how this is done.
kidsid99 is offline   Reply With Quote
Old 05-27-2008, 02:52 AM   #12
I dont have a manual since I bought the car used but can you point me in the right direction of what page its on / section. I know where to find the NTC3 manuals on AE. So I can "recenter" the servo by adjusting the turnbuckles I dont need to take it apart and reinstall the horn, etc? That's great news
Old 06-13-2008, 09:33 AM   #13
poochy's Avatar
you have to suffer and go through the painful stages of learning your car. it takes time but if you can figure out how to remove the upperdeck (which is simple when you have done it once before) then you have learned a lot about the car. Do you have the plastic tools and allen wrenched that comes with the car?
poochy is offline   Reply With Quote
TC4 steering problem mnapp69 Electric On-Road 4 12-25-2007 05:20 AM
Steering Problem jmdv Nitro Off-Road 8 06-28-2007 08:23 AM
Steering problem... joe of loath Micro and Mini Scales 5 03-21-2007 01:24 PM
MI2 Steering problem brakkie Electric On-Road 6 02-13-2006 07:01 PM
