Old 05-19-2008, 03:09 PM   #1
Default solid wheels for foam tires on a ntc3
does anyone know where I can get the solid wheels for a ntc3? any information would be greatly appreciated
joeyb19 is offline   Reply With Quote
Old 05-19-2008, 03:59 PM   #2
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
why would you want solid wheels. You can buy Nitro shoes, but here is a link for the solid ones.
http://www.rchobbies.org/cars_jaco.htm
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Old 05-19-2008, 04:02 PM   #3
i think he means dish wheels
rampage21 is offline   Reply With Quote
Old 05-19-2008, 04:12 PM   #4
rcfoolz's Avatar
The link has both, nitro shoes and the dish wheels
Old 05-21-2008, 08:39 AM   #5
thats the ones i was talking about. i run nitro shoes, but just want the solid wheels that will fit the ntc3. i couldnt find them at the local hobby store. also, will the wide tires down on the lower right hand side of that page fit my car? the only ones i can find like that at the store wont fit the car. thanks again for the information.
Old 05-21-2008, 12:19 PM   #6
rcfoolz's Avatar
If you do decide to use those, you will need the adaptor made by Cobra for those to work. The adaptor is here: http://www.philshobbyshop.com/tek9.a...ific=jqkrmpjng These will let you bolt those WIDE tires right on, but I would only use that on the right rear. This is also the same adaptor that you would use to run a CAP tire.
If you are SERIOUS about going FAST, and end up going to an oval track that is banked, look into buying BSR cap tires for touring cars. They make them for 1/10 sedans. You will not find a better tire for grip. I would suggest using reds or greens on the inside and a pink on the right front and a red on the right rear. They are all the same width, which is a good thing for getting a consistant run. You might want to go with a blue on the right front too, but I would stick with the Pink, it is a better tire for grip and durability. just make sure that you go with the kavlar belted ones. The cap tires are good for concrete, not asphalt, IF YOU ARE RUNNING A FLAT TRACK, but if you get to go to a banked track, you would not want to run anything but the cap tires, weather it a asphalt or concrete.
Horizon does carry them, so any hobby shop can order them for you, but here is a link for information on them: http://www.bsr-racing.com/cap/touring.html
The web site doesn't have that much information, but it will soon.
F/S EIGHT SETS OF FOAM TIRES AND WHEELS FOR M18 XRAY $15 speedemall R/C Items: For Sale/Trade 0 06-04-2008 11:02 AM
WTB used foam 1/10 touring car wheels/tires cherrypop R/C Items: Wanted to Buy 1 10-04-2006 01:49 PM
NTC3 with foam tires, need advice sergrc Nitro On-Road 2 01-30-2006 11:23 AM
Another NTC3 w/ 2 engines,parts,foam/rubber tires TambokGT R/C Items: For Sale/Trade 0 06-19-2002 09:20 PM
Tires wheels and foam inserts stangracer Nitro On-Road 5 06-17-2002 12:51 PM
