Old 05-13-2008, 07:17 PM   #1
Default Serpent Impulse 2 speed clutch
I have an Serpent Impulse with a 2 speed in it that I am trying to get going for a friend, but I am having trouble with the clutchbell. Does anybody have instructions for the installation? I can only find ones for the single speed or for the centax cllutch on Serpent's website, and I don't understand what I'm missing? Does anyone have the proper bearing sizes for the clutchbell? When I try to put a bearing in the outside of the bell, it doesn't seem to reach the crankshaft, it will not seat any further. Either I have the wrong bearing size, or I am missing something, like maybe a brass sleeve, or even possibly a thrust bearing? The picture on serpents website doesn't show these things, but I am at a loss. Thanks for the help!
BCall is offline   Reply With Quote
Old 05-13-2008, 07:41 PM   #2
Trader Rating: 16 (100%+)
Sounds like you are using the Impulse PRO type 2-speed clutch housing. As long as you are sure it is not the CENTAX type clutch, all you need are 2 flange type ball bearing instead of the regular bearing without the edge...definitely NOT the thrust bearing (Thrust bearing is for centax type clutch...)
Here you should have a better look at the clutch
http://www.serpent.com/product/801020/
Download about the mannal
http://www.serpent.com/file.php?FileID=1085
http://www.serpent.com/file.php?FileID=1086
http://www.serpent.com/file.php?FileID=1087
Old 05-13-2008, 09:33 PM   #3
Thank you, that is indeed what I have. I had downloaded that manual before, but not printed it off, and the 2 speed instructions escaped me. I only saw the single speed until now. I think I have figured out the problem. My friend bought this used, and all of the parts were just in a bag. He did say the 2 speed had not come with it, it had been added later. I think I have the flywheel for the single speed, and it must be thicker than the 2 speed, because the clutchbell cannot come down the shaft far enough to have the outer bearing touch the shaft. I am assuming this, because the manual lists 2 separate part numbers for the fly wheels. If I am wrong, please somebody correct me. Thanks again for the help!
Old 05-14-2008, 11:41 AM   #4
OK...it is just way too long ago that I can't even remember it use 2 different flywheel. But here is a easy fix...
Take off your entire clutch parts....then add 0.5mm to 1mm shims onto your engine SG shaft...then place your gold color collet, then the flywheel. And see those shims will OFFSET the 2-speed used flywheel thickness...
Adjust the shim thickness accordingly....again, it was way too long ago and I can only think of this easy fix, worth a try...good luck
Old 05-14-2008, 03:38 PM   #5
Thanks, but I have the thick fly wheel, and I need the thinner one. I would think shimming would just move it further out, and I need it closer to the block. If I am misunderstanding, please let me know. I spoke with Phil(the guy I am working on it for), and he seems to think he has the other flywheel, so hopefully that will solve all of my trouble. Thanks again!
Old 05-15-2008, 11:05 AM   #6
OH ok....I am thinking the opposite, nevermind...good luck.
Old 06-30-2008, 11:50 PM   #7
Default Serpent USA Warehouse Clearance Sale
Take advantage of incredible prices on spare parts for the following models
http://www.serpent-usa.com/es12801024/index.htm
For more info and to order, e-mail [email protected] or call (305) 639-9665
Paolo M is offline   Reply With Quote
yamaha gt 80 dirt 4 speed clutch clutch bike 4 speed clutch cheap savage123 Other Items: For Sale/Trade or Wanted to Buy 8 08-10-2006 01:34 PM
Serpent Impulse 2-speed won't shift WeatherB Nitro On-Road 1 05-08-2005 10:29 AM
NIB Serpent Impulse 4-WD 2-speed kit + SX12 RE eirikr R/C Items: For Sale/Trade 0 03-19-2003 12:10 AM
Wanted Serpent impulse 2 Speed clutch bell Caesarsalad R/C Items: Wanted to Buy 0 03-08-2003 04:18 PM
Wanted CENTAX CLUTCH (SERPENT IMPULSE) Caesarsalad R/C Items: Wanted to Buy 0 01-12-2003 07:42 AM
