Old 05-12-2008, 05:08 PM   #1
Taylorm's Avatar
Default Centax maintenance......
Do you guys service your centax after every race meeting???........what is the best grease to use on the thrust assembly and what bearing oil for the clutch bearings???...............
Current stable... Team Associated SC8, Team Associated RC250 X 3
Tamiya F104X1...Tamiya F104W GP Edition...BMT/RC300 Frankenstein.....Edam Razor2
Checkers or Wreckers......................................................................................
Taylorm is offline   Reply With Quote
Old 05-12-2008, 05:17 PM   #2
Team Kamikaze's Avatar
Use a known good molydenum grease or Black grease for the trust bearing and use the Serpent bearing Lube #1682 for your clutch bearings.
Home of the Kamikaze Driver's Development Program = guaranteed podium finish
Kamikaze Toys and Hobbies Inc.
Follow us here on Facebook!
Team Kamikaze is offline   Reply With Quote
Old 05-12-2008, 06:24 PM   #3
Trader Rating: 15 (100%+)
I use the Associated black grease for the thrust washer and 30W Mobil One for the clutch bearings. Do both before the race day starts and both before the main.
THE DOCTOR is offline   Reply With Quote
Old 05-12-2008, 06:32 PM   #4
Trader Rating: 24 (100%+)
i use the associated black grease, works great
RANDY SMOOTH is offline   Reply With Quote
Old 05-12-2008, 06:54 PM   #5
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
I used to use the Associated black grease on the thrust bearing. Now I use the Mugen Super Grease. I never oil the clutch bearings. I don't want to get anything on the clutch parts. I haven't blown a clutch bearing in years..
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 05-12-2008, 07:34 PM   #6
s10dude's Avatar
i use high temp disc bearing grease from my truck..work's great and i've got enough to last to the 24th century..i don't oil my bearing's either..i change them once a month...from AVID Bearing's . com $1.00 ea. ( for any bearing )
Marc Richards / Xray NT1 / Matrix Tires / RB Motor's / Futaba
Fabricator and racer @ Speedworld Raceway & Hobby
s10dude is offline   Reply With Quote
Old 05-12-2008, 09:21 PM   #7
rcabj's Avatar
i too do not oil my clutch bearings, greased the thrust bearings esp. for races and before long mains
BLacK cRoW RaCiNg TeaM
JBRCC
TEAM ORANGE
RCCUTM
pemandu upahan ;)
rcabj is offline   Reply With Quote
Old 05-12-2008, 10:59 PM   #8
Suspended
Default centax
Take the clutch bell off after every race, clean the clutch shoe with denatured alcohol ( fuel and dirt get in there during fast pit stops or if you have a sloppy pitman ). Clean the thrust bearing after each day of racing to prolong its life, and Mugen Super Grease works great for the thrust bearing.
Team-Shepherd // XS Power // IDM Engines // TKO Bearings // Airtronics
00VIP001 is offline   Reply With Quote
Old 05-13-2008, 12:38 AM   #9
stefan's Avatar
Send a message via AIM to stefan
Regular grease on the thrust bearing will stick on the inside of your body after you pull the throttle for the first time.
I use this Trinity purple stuff (the really sticky one), or a graphite spray that will dry on and leave a thin film.
stefan is offline   Reply With Quote
Old 05-13-2008, 06:04 AM   #10
JRGTR's Avatar
Send a message via MSN to JRGTR
After every race, remove all the centax parts and clean with no clorinated brake parts cleaner, lubricate the bearing with boca bearings high temp oil,for the thrust bearing I use Syntetic grease that is normaly used to lubricate retainers pins for brembo brakes, work great. starting the race day I pust some of these grease on the thrust bearing ans I check the bearing before the main and still have grease, put some moore and ready!
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 05-13-2008, 08:06 AM   #11
Trader Rating: 93 (100%+)
Default Clutch
I too use associated black grease and no oil on the bearings. If you start to see sparks it's time to replace the shoe.
latemodel13 is offline   Reply With Quote
Old 05-13-2008, 10:35 PM   #12
Brazilct's Avatar
i use caster oil an thrust bearing and bearing it works great
BROOKLYN HOBBIES...
SERPENT AMERICA...
JP Racing...
MAXY's PRO RACING FUEL & MODIFIED MOTORS
Brazilct is offline   Reply With Quote
Old 05-14-2008, 12:26 AM   #13
Roelof's Avatar
Send a message via ICQ to Roelof
If I am using a thrustbearing I use Tri-Flow, it is a spraycan with a teflon oil, it works great on the bearing and CVD's.
Normally When the thrustbearing is broken I place a 10x5 brass ring between the 2 steel discs to make it a ball less bearing.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 05-14-2008, 05:23 AM   #14
lil-bump's Avatar
Trader Rating: 83 (100%+)
Every race day I grease with mugen super grease. I do not oil the bearings. just replace them every other meet.
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
ST-RR maintenance? LosiSuperTruck Nitro Off-Road 14 07-17-2008 01:21 PM
Zen and the art of RC maintenance..... Mabuchi540 Electric On-Road 69 03-31-2005 03:20 AM
Maintenance For Your Gp Car mop_iko Rookie Zone 8 06-10-2004 01:07 AM
maintenance? cHckbOY5 Nitro On-Road 2 06-08-2003 07:22 AM
maintenance nitrosaurus Rookie Zone 7 03-18-2003 08:42 PM
