Old 01-02-2002, 08:35 PM   #1
got_speed?'s Avatar
Unhappy Steering would not throw 100%...
I'm wondering if any of you have had the same problem...
All of a sudden my steering would not throw 100% on either direction....I have an older FM Futaba....all the controls are mechanical....I have adjusted the Steering ATV to 100% but it still would not do it....
I recall it used to throw more than it does right now...because I even had to adjust the Left ATV so the tire would not hit the pipe.
The servo works fine...I tried using a different radio with it.
got_speed? is offline   Reply With Quote
Old 01-02-2002, 08:54 PM   #2
Is your servo horn stripped?
Sydewynder is offline   Reply With Quote
Old 01-02-2002, 09:20 PM   #3
got_speed?'s Avatar
The servo is fine....I unplugged the servo and hooked it up to a different RX & TX it works just fine.....
I've pretty much isolated it to the radio system....just could not tell if I'm missing anything other thant he ATV or ATL adjustment that's already set to 100%...
Old 01-04-2002, 09:26 PM   #4
If you set EVERYTHING back to factory - 100% then I would say your radio is bad. You mentioned that you used a different radio and receiver on the servo and the servo worked fine. Did you use the new radio with the old receiver? Last check to make sure it isn't the radio but maybe the receiver.
Exotek RC18 LONG THROW STEERING KNUCKLES? haulin79 Micro and Mini Scales 14 07-20-2008 02:10 PM
WTB: TC3 spares, throw as many as possible tt01-demon Australia Wanted to Buy 7 07-04-2007 07:13 PM
Unequal steering throw Iceracer Electric On-Road 15 12-19-2006 11:31 PM
Steering throw new92 Electric On-Road 2 02-11-2005 12:42 PM
How to get more steering throw out of a Ko Mars Radio. rcpilot Electric On-Road 5 10-05-2003 08:24 PM
