Old 07-30-2003, 06:28 AM   #1
alvinm's Avatar
Default Mtx 3 bumper warping,limiting suspension,any fixes?
I have the long bumper and after a while it starts to dip at the ends limiting suspension travel.I installed a graphite brace along the top but it still bows a little bit.Should I just cut it shorter or any other ideas?
alvinm is offline   Reply With Quote
Old 07-30-2003, 08:58 AM   #2
eddiethefish's Avatar
Send a message via ICQ to eddiethefish
Default Re: Mtx 3 bumper warping,limiting suspension,any fixes?
use the smaller one that comes w/ the kit.
eddiethefish is offline   Reply With Quote
Old 07-30-2003, 09:44 AM   #3
Send a message via ICQ to nizee
Everynow and then, before every race, i would just bend the warping side upward with my hand, to avoid getting close to the ground. The plastic upfront is soft, i guess the idea is to absorb as much impact as possible, and end up warping the bumper.
hmm...Maybe i should try the smaller one.
nizee is offline   Reply With Quote
Old 07-30-2003, 10:20 AM   #4
My fix might not be pretty but it works for me. I drilled a small hole at each end and tied it to the body posts using fishing line. It maintains it with a small curvature upwards.
Jose
joseviejo is offline   Reply With Quote
Old 07-30-2003, 12:49 PM   #5
Francis M.'s Avatar
just use the smaller bumper since the foam bumper should
absorb most of the impact. and will not affect ground clearance
as related to the chasis clearance.
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-30-2003, 07:38 PM   #6
alvinm's Avatar
Thanks,the fish line idea is an origional
Old 07-31-2003, 02:56 AM   #7
theRED5's Avatar
R/C Tech Charter Subscriber
I took mine off a couple of weeks ago while I worked on the car. I took the bumper and bent it so that it would fit in the drawers of my (tackle) toolbox, after a half hour it was re-shaped so that it no longer dragged the ground.
I [I]AM [/I]the Driver !
Murnan Modified Motors
Mugen MRx4
Rocket Science Fuels
Auto Racing, Mountain climbing, and Bull fighting are the only true sports, all the rest are just games.
theRED5 is offline   Reply With Quote
Old 07-31-2003, 04:38 PM   #8
Send a message via Yahoo to hicheef
Default WOW Sounds like the MRX issue
What I do, is heat it in hot water(boil it). Take it out, stick it in a vice and flex the wings up while it is still hot. ALSO, if you stick a couple washers between the top if the chasis plate and the bottom of the bumper it'll buy you a few mm's as well. Never had the prob with the MTX but man did I have it with the MRX.
hicheef is offline   Reply With Quote
Old 08-04-2003, 06:18 PM   #9
kevink2's Avatar
Default Re: WOW Sounds like the MRX issue
Yeah boiling the top and bottom plate works, just straightened out my whole front end. I wouldn't say it's an "issue". Hit the wall, something's going to give. Thankfully this technique will get more useable life out of these pieces.
kevink2 is offline   Reply With Quote
rc18t ft shock fixes? TZona Micro and Mini Scales 14 09-27-2006 07:32 PM
Mini Inferno Servo Fixes RoostAZ Micro and Mini Scales 4 09-03-2006 02:27 PM
WTB LRP 7.1 CURRENT LIMITING CHIPS tazz888 R/C Items: Wanted to Buy 5 10-12-2005 03:06 PM
LRP 7.1 Current Limiting Module MadMikeB Electric On-Road 2 06-16-2005 06:06 AM
Rim Warping fatdoggy Electric On-Road 13 11-21-2003 08:13 PM
