Old 05-21-2004, 09:15 AM   #1441
ziggy12345's Avatar
Im trying that first on Sunday. Good thing is i now have 2 clutch bells so very quick to change gear ratios!
ziggy12345 is offline   Reply With Quote
Old 05-21-2004, 09:21 AM   #1442
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Old 05-21-2004, 09:29 AM   #1443
InitialD's Avatar
I don't know if it's true but I'm told that changing spurs or pinions is a pain in the a$$ regardless if you have them on the clutch bells already. You need to take out the engine mounts etc. Is this true?
Old 05-21-2004, 09:35 AM   #1444
Trader Rating: 25 (100%+)
Originally posted by hudy
Ok I just came from ultimate hobbies and I looked closely at the box and its the Kyosho FW05R No.31581B POWER TYRES GRP FOAM TYRE VERSION im guessing this is the one with all the goodies lightened chasis upper carbon fiber deck one way etc etc please correct me if im wrong guys
vadn1 its going for $334.95 for the FW05R I just mentioned on top
No Hudy, this version is the one that comes with foam tires instead of the European version that use to come with rubber tires. No lightened or carbon stuff here.
Responding to your comments about the FW-05R being slower on the straights compared to the belt driven cars I must tell you that is not true. I have personally raced against 710, MTX-3 and I must tell you, no clear advantage here. We all are toe-to-toe on the straights taking into consideration that most of the people running on the B and A mains (on the track that I race) are using powerfull motors such as Mugens X-12, Murnan Mods, NovaMegas MS, Rody Roems and JP Blacks (using it myself). The 05R has a unique feature which is it's flexibility to change the internal ratio of the car. By changing to 39 T bevel gears (part No.VSW018) you will be able to squeeze more MPH for bigger tracks (straights with more that 200 feet)
madness is offline   Reply With Quote
Old 05-21-2004, 09:50 AM   #1445
InitialD's Avatar
What's the length of the track you race on? Not saying that shaft cars suck on high speed tracks but the FW05R is just short of gearing out of the box or with Kyosho options.
Old 05-21-2004, 10:09 AM   #1446
The straight is about 185 feet. I am still using the factory bevel gears (40T) which I think is O.K. for the track. I would not want to install the lower ratio (on my track) because the car would not be able to make full RPM which, in my opinion is not good (the cars with the correct ratio will get me at the middle of the straight, got it) In other words, given my track scenario my motor will take longer to get to the "sweet spot" (peak HP) than the other cars.
here is a picture of the local track:
Old 05-21-2004, 10:11 AM   #1447
another look at the track:
Old 05-21-2004, 11:39 AM   #1448
ziggy12345's Avatar
If thats the track you run on your engine must rev to about 120,000 RPM!! I get max revs 2/3 the way along our straight and its around 130ft long.
For about a 150ft straight the max gearing ratio you have will not be enough. thats 45t spur. 27t pinion and 39t bevels. You will need to go to 28 pinion or even 29. This brings you to the same gearing as an MTX-3
Old 05-21-2004, 11:40 AM   #1449
ziggy12345's Avatar
Yup. but at least you dont have to fart about unscrewing them from the bell.
Old 05-21-2004, 12:11 PM   #1450
NiMo's Avatar
Aldershot is 150ft, I use 26/45*39 for the heats, and may use 27/45*39 if I want to try a 10 minute pit free run, but there again I run on rubber so my wheels stay larger at around 61/63mm.
NiMo is offline   Reply With Quote
Old 05-21-2004, 01:09 PM   #1451
Ziggy: I am not 100% with you Ziggy. I am writing using only what I have experienced racing against MTX-3 with both, stock gearing and "revised" combinations with no apparent advantage on either side. After all, winning is attained in the infield not in the straights! To give you a better scenario, my engine runs in a average temp of 220-230 after a 15 minute race.
I raced the exact same gearing combination as in my 05R on my NTC3 at the 2003 Winternationals in Ft. Myers, FL and let me tell you, the NTC3 was ripping!!! pleanty of go-juice in the straights and good torque on the infield. I do not know if you have ever been to Ft. Myers but the straight is very loong! Well, maybe we need to take into consideration the Roll Out fo the car. We use foam tires over here.
I guess I am going to put my 05R to the test next month at Full Throttle SpeedWay in FL for the Region Four Race. I have heard that track is HUGE! I will let you know then!
Peace!
M. Daumont
San Juan, Puerto Rico
Old 05-21-2004, 01:16 PM   #1452
Madness: You've got PM
MonoTuning
monotuning is offline   Reply With Quote
Old 05-21-2004, 01:38 PM   #1453
Suspended
hudy's Avatar
thx madness for your help so the kit im looking for is the PURE TEN GP FW05R CHASSIS KIT SPONGE TYRE (31582)
also your keeping up with 710, MTX-3 with the stock kyosho gearing you just have a really good engine on your car or did you modify the gearing
hudy is offline   Reply With Quote
Old 05-21-2004, 02:14 PM   #1454
jeffreylin's Avatar
R/C Tech Charter Subscriber
Peace!
M. Daumont
Hi Madness, what kind of pipe/manifold are you using?
jeffreylin is offline   Reply With Quote
Old 05-21-2004, 02:23 PM   #1455
Super Moderator
Marcos.J's Avatar
Peace!
M. Daumont
hey i just picked up my fw-05r today and i will be running it at the region 4 at full throttle!! by the way that track in P.R. looks awesome!!
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
