Old 05-19-2004, 05:47 PM   #1396
ojo
Can someone help me out with wat 2 get 2 convert to mtx-3 hub?
1. do i need to get different size bearings?
2. do i have 2 change 2 mugen's dog bone & wheel shaft?
3. did i miss out anything?
Thank you very much.
ojo is offline   Reply With Quote
Old 05-19-2004, 09:20 PM   #1397
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
Default Re: gears
Originally posted by mikecatts
hi guys,
went to the track today to try a few things...short work day..
39 ring front, 40 ring rear, 22/50 , 29/45.
jp ns3 worlds (not too many of these babies around, i have 2).
kyosho pipe and header..........................
man does this car go.........our rear straight is at least 120metres long wth a sharp 90 degree bend at the end.
this car just keeps pulling........the car is twitchy at high speeds...i think due to trying a new radio as well...ex-10 helios........i blew second gear...on closer inspection i seen that the mesh wasnt 100%...out with the dremel and widened the engine mounting holes...now i got the mesh right...a quick run and no probs....now i need to work on the set-up...ran out of daylight...race day sunday......ill try a few things..
mike
are you using the oneway or diff in the front?
Old 05-19-2004, 10:43 PM   #1398
dameetz's Avatar
U need the following items:
Mtx 3 hub (rear upright)
Outer smal bearing ( the inside one is the same size as Kyosho)
Wheel shaft
Pillow balls together with original hex fitter ( the one with black plastic spacer)
Wheel hex
and the spacers at the top of the hub.
You dont need mugen dog bone the kyosho one will fit.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-19-2004, 11:06 PM   #1399
Suspended
hudy's Avatar
I have a question on the FW05R does it come with carbon fibre deck shock towers one way etc etc or is all that seperate hop ups?
hudy is offline   Reply With Quote
Old 05-19-2004, 11:17 PM   #1400
Nitropimp's Avatar
Hudy- I think there's a kit that has carbon fibre deck. I'm not sure aobut the one way.... Are you looking at a FW05 now??? I'm still debating.
Nitropimp is offline   Reply With Quote
Old 05-19-2004, 11:32 PM   #1401
ojo
dameetz,
thanks for d detail listing.
Old 05-20-2004, 12:04 AM   #1402
jeffreylin's Avatar
R/C Tech Charter Subscriber
Hudy, I answered this question on page 44 of this thread. take a look.
jeffreylin is offline   Reply With Quote
Old 05-20-2004, 12:10 AM   #1403
mikecatts's Avatar
Trader Rating: 18 (95%+)
Default marcos
marcos...im using the one way....
http://smg.photobucket.com/albums/v223/mikecatts/
mikecatts is offline   Reply With Quote
Old 05-20-2004, 12:32 AM   #1404
Suspended
hudy's Avatar
nitropimp yes i am currently contemplating about purchasing the FW05R im just not sure if it comes with all the goodies I went to my LHS today and saw it very nice car indeed iys just that jeffreylin confused me even more the one i saw today was in a red box and said it was the FW-05R <Sponge Tire Version> i really did not pay close attention to the numbers
the kit was $334.00
please help is there other version of the fw05r im not aware of i though it was only one please dont flame im a noob at this thx for your help
Old 05-20-2004, 01:10 AM   #1405
jeffreylin's Avatar
the kit was $334.00
Hudy, the one you saw was probably the 31581B kit, which does not come with the oneway nor carbon upper deck.
Old 05-20-2004, 01:38 AM   #1406
mikecatts's Avatar
Default check this site out
hi guys,
check this site for info and prices///
out of japan they call the car "the pro kit".
its got the one way, carbon deck and the upgraded chassis....not bad value..
http://www.rcmart.com/catalog/
Old 05-20-2004, 01:41 AM   #1407
Nitropimp's Avatar
Hudy-what part of California are you from?? This is the post about the kits
31582 kit comes with the carbon fiber top deck, front one-way, lightened chassis, as well as foam tires. 31581A is the rubber tire kit with front diff and regular upper deck and 31581B is the foam tire kit also with front diff and regular upper deck.
Old 05-20-2004, 01:53 AM   #1408
mikecatts's Avatar
Default look at this
take a look.
Kyosho (#KY31582) FW-05R Chassis Kit Hop Up edition USD$379.90
Order quantity:
Product 41/42
FW-05R Chassis Kit
1:10 Scale Controlled .12 Engined Powered Touring Car Series
Unaffected by the size of the load placed on it and able to maintain low stress throughout, the 4WD shaft-driven system is now ready for action with full battle racing specs in the PureTen size. Entered as the "R" class in the Kyosho Cup from its inception, and also the JMRCA All Japan National Championships, a new wind is now sweeping through this globally accepted size. Kyosho's long heritage of innovation and development of racing technology have been concentrated in the FW-05 R. With its ultra-low center of gravity, a 3D clutch and 2-speed automatic transmission etc., the FW-05R is ready for racing battle right from its debut! With winning performance as the dominant theme in its design, the new generation 1/10 pure touring machine has arrived!
Newly developed shaft-driven 4WD drive train responds intelligently and lightly when power is put ON or OFF.
Double wishbone suspension with ball-connect system has multiple points of adjustment for a wide scope of settings.
Equipped with high performance components such 3D clutch with shoe mechanism, and a 2-speed transmission at a very competitive price.
Precision 0.8 module gears for minimal loss.
4 bevel gear diff has wide scope for setting selections with different viscosity silicone oils.
Long span suspension arms on both front and rear (longer than V-One).
Design delivers low center of gravity with low-height engine mount and small diameter flywheel etc.
Equipped with center-connect type front stabilizer and piano wire type rear stabilizer.
Direct throttle linkage eliminates any play in throttle control bypassing any relay links.
Many optional upgrade parts designed for the V-One can also be used on the FW-05 R. Body mount positions are also the same as the V-One.
Design allows engine's full power to be extracted through non-restrictive manifold shape.
Globally accepted size can be entered in the JMRCA 1/10 GP Touring Car All Japan Championships among others.
This product was added to our catalog on Wednesday 12 May, 2004
Old 05-20-2004, 02:39 AM   #1409
ziggy12345's Avatar
Wheel shaft
Wheel hex
Have you got the part numbers?? Who has them all in stock?
ziggy12345 is offline   Reply With Quote
Old 05-20-2004, 07:12 AM   #1410
Taylor-Racing's Avatar
ziggy,
This should be what you need.
Mugen T0229 F/R axle shaft 1
Mugen T0230 F/r drive shaft 1
Mugen T0139 Rear up right 1
Mugen D0105R king pin 1
Mugen J0110 adjust nut 1
3 Racing mtx3-008 wheel adaptor 1
10 x 15 ball bearing 2
6 x 13 ball bearing 2
Taylor-Racing is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
