Old 05-10-2004, 12:09 PM   #1291
ziggy12345's Avatar
Using 28mm Sato Seiki tyres on the front helps as well!!
ziggy12345 is offline   Reply With Quote
Old 05-11-2004, 01:52 AM   #1292
NiMo's Avatar
Originally posted by V1R racer
It looks lke the centre conversion give a big increase in drive ratio but using the mugen clutch bell and 29 pinion gears does the same for about 10% of the price!!
Hi let me know if the mugen clutch bell works there could be to fw05 at ashby
There's already 2 FW05R's at Aldershot, and I've just sold an FW05S to a new racer.
So that's 6 I know of in the UK where the car is not officially released.
NiMo is offline   Reply With Quote
Old 05-11-2004, 01:54 AM   #1293
NiMo's Avatar
Originally posted by GUNPOWDER
Who's selling them?
RC Union
Old 05-11-2004, 02:07 AM   #1294
ziggy12345's Avatar
Nimo you have PM
Cheers
Old 05-11-2004, 09:23 PM   #1295
Default FW-05R may be going to sale forum
I want to give you guys a heads up. I have had the car for a while but have never run it. No time what so ever. I have been reading this forum often, that is the reason why I got the car. Got a lot of tips from you guys. Anyway, things came up and I will have to sell it. I don't have time to list what is on there but if you email me, I will get you pics and more info. It has a LOT of hop ups. Never ran...period. New everything. I apologize because I know this is the wrong forum for this but I wanted to give you guys a chance before I list elsewhere. Thanks. Email for details at:
[email protected]
kalani is offline   Reply With Quote
Old 05-12-2004, 05:09 AM   #1296
dameetz's Avatar
Default Springs
I notice that most of the Kyosho pic posted in this forum using Blue springs, like Mugen one. What spring is this? Is it softer of harder? What is the part no for this if it is Kyosho's.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 05-12-2004, 05:49 AM   #1297
Send a message via Skype™ to JordanC
Default Re: Springs
They are Fantom Light Blue springs. They are softer!
JordanC is offline   Reply With Quote
Old 05-12-2004, 07:37 PM   #1298
esham's Avatar
Checking my FW05R today and I notice the front suspension is quiet limited. Can this be improve?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 05-12-2004, 07:48 PM   #1299
TOEBSTER2's Avatar
Does the FW-05R come with the carbon fiber top deck and a pipe?
Also are there different versions such as a rubber tire car and a foam tire car?
Crookid Creations
TOEBSTER2 is offline   Reply With Quote
Old 05-12-2004, 07:57 PM   #1300
jeffreylin's Avatar
R/C Tech Charter Subscriber
No pipe, but the 31582 kit comes with the carbon fiber top deck, front one-way, lightened chassis, as well as foam tires. 31581A is the rubber tire kit with front diff and regular upper deck and 31581B is the foam tire kit also with front diff and regular upper deck.
jeffreylin is offline   Reply With Quote
Old 05-12-2004, 08:11 PM   #1301
There is a new kit out. Code no is: 31582TRT and it comes with front one way, 7075 chasis, carbon upper deck, foam tyres, pipe and OS12 TRP Turbo engine. I've got this kit from Japan.
GUNPOWDER is offline   Reply With Quote
Old 05-12-2004, 08:13 PM   #1302
RichChang's Avatar
Default rear, lower arm mounts
Hi,
I am trying to figure out whether to buy the upper & lower position rear-arm mounts.
Does the car normally come with both the upper position and lower position rear-arm mounts? The car kit I purchased was used and it didn't come with any parts except what was on the car.
If the kit doesn't come with both, does it come with the arms in the upper or lower position? I am hoping it is in the lower position already because I can easily shim the blocks up and down as needed to adjust arm height, squat, etc. If it comes in the upper position then it looks like I need to buy the 3racing aluminum lower mounts (or does someone make the blocks in plastic/composit material?).
Thanks,
-Rich
RichChang is offline   Reply With Quote
Old 05-12-2004, 08:26 PM   #1303
Esham: What do you mean by limited?
JPRacing is offline   Reply With Quote
Old 05-12-2004, 08:27 PM   #1304
jeffreylin's Avatar
Default Re: rear, lower arm mounts
The kit comes with both the upper and lower rear A-arm mounts. you can get the mounts easily and cheap by getting the rear bulk head set. The arms are part of the parts tree.
Old 05-12-2004, 08:29 PM   #1305
RichChang's Avatar
Cool - thanks, Jeffrey.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
