Like Tree2Likes
Kyosho FW-05R
Old 04-27-2004, 01:08 AM
  #1171
dameetz's Avatar
Default Diff Gasket
I m just servicing my car today and found out the rear gearbox was full silicone from the diff. I unassemble the diff and found the O ring gasket was torn apart. Now I m about to install the normal paper gasket from Evo Diff, it fit very well. Hopefully it will not leak anymore. Has anybody done this before? I just don't like the O ring gasket because its a bit harder to put and aligning it to the edge of thr diff case.
dameetz is offline
Old 04-27-2004, 01:14 AM
  #1172
ziggy12345's Avatar
So its the centre conversion from Kawahara that converts the drive ratio?
OK. Looks like i'll get that instead
Cheers
ziggy12345 is offline
Old 04-27-2004, 03:22 AM
  #1173
esham's Avatar
Default Re: Diff Gasket
esham is offline
Old 04-27-2004, 03:49 AM
  #1174
Bundy_Bear's Avatar
Originally posted by Joehwee
Bundy Bear: The Thunder Tiger starter box you have will not fit the 05R
Ziggy: the 0.8 module crown gear from Kawahara will increase the top end cos the internal ratio will be about 2.7 and not 3 (with 39t crown gear0
i do have a solid axle for my 05R, try it but don't really like the feel of the car, I prefer one-way or diff.
Joehwee: What starter box would you recommend?
Bundy_Bear is offline
Old 04-27-2004, 07:13 AM
  #1175
orangbaligila's Avatar
on the other hand,.. I like the o-ring style over the paper,.. when aligned perfectly,.. it's almost impossible to leak the oil (tip: wet the o-ring w/ some of the oil during install, and it wont leak for a long time,... mine survived 4 races already w/ no oil change or top-up,... changed the ring-gear twice already, but no oil leak)
orangbaligila is offline
Old 04-27-2004, 07:16 AM
  #1176
sorry to jump on this, but I'm using Q-world universal starter (all configurations from 1/10 on-road to 1/8 buggy) it has twin motor installed too...
Old 04-27-2004, 07:29 AM
  #1177
jeffreylin's Avatar
I tried both the XTM one and the Team Magic one. The Team Magic one works a lot better.
jeffreylin is offline
Old 04-27-2004, 07:44 AM
  #1178
juki's Avatar
have u already tried the front solid axle?i've thought it was a prototype...anyway, hi Joehwee...u'll remember me as Teddy Syah's team mate from Kyosho Indonesia right now i'm using FW and apparently Teddy will use it too..
juki is offline
Old 04-27-2004, 07:55 AM
  #1179
not waiting for V-One RRR?! hehe,... I'd like to know for you guys that run in JITC,... is the FW "nervous" on long sweepers?! I've only used mine on short track (Makro Bali),... might show up on GQ on May (if I'm good enough already, hehe...)
Old 04-27-2004, 08:32 AM
  #1180
ziggy12345's Avatar
Whats the effect of removing the rear droop on the FW-05? Some say no droop = more steering!!
Cheers
Old 04-27-2004, 08:42 AM
  #1181
jeffreylin's Avatar
Cheers
More droop in the rear will allow more weight transfer to the front during braking as it allow the rear to lift further. The more weight you have in front, the more steering you will have.
Old 04-27-2004, 08:53 AM
  #1182
ziggy12345's Avatar
so....
more droop = more steering??
or
Less droop = more steering??
Old 04-27-2004, 08:57 AM
  #1183
so....
or
I think,..
more rear droop = more off-power steering
less rear droop = less off-power steering
more front droop = less on-power steering
less front-droop = more on-power steering
correct me if I'm wrong guys
Old 04-27-2004, 09:38 AM
  #1184
coldeye's Avatar
Default hardened 39 diff gears
Does anybody know if tower hobbies sells the 39t gears. All I can find are the silver ones and I thought those were the standard ones. I thought we had a link on the earlier pages, but again all I found were the silver diff gears. Am I wrong in assuming the hardened ones are black? Guide me enlightened ones!
Mike P.
coldeye is offline
Old 04-27-2004, 09:41 AM
  #1185
ziggy12345's Avatar
Rc Mushroom has them. They are shown black but will be listed as steel gears. They do make the ally 39 gears though
