Old 04-25-2004, 08:07 PM   #1156
Originally posted by GUNPOWDER
Hi All,
My FW-05R (Foam Tyre version) came with Front One way as standard. I'd like to get the Front dif. parts now. Could anyone list the parts I'll need? So far I've the following in my list:
VS002 - Ring Gear Set (40T)
VS003 - Differential Joint
Cheers,
Anyone?
GUNPOWDER is offline   Reply With Quote
Old 04-25-2004, 08:53 PM   #1157
apmk's Avatar
Originally posted by esham
The chasis
esham, get a smaller fuel filter, it give your engine more cooling.
apmk is offline   Reply With Quote
Old 04-25-2004, 09:11 PM   #1158
KMac's Avatar
you mean air filter?
KMac is offline   Reply With Quote
Old 04-25-2004, 09:20 PM   #1159
esham's Avatar
I believe so that what he means.
Another question - Is it possible to use 0.1 spur or 0.8 RR evo spur on this kit? I believe the drive shaft is abit smaller in diameter perhaps I could get a correct bearing size. Anybody try before?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-25-2004, 09:36 PM   #1160
esham's Avatar
Default Suspension mounting
Anybody have a clue what this suspension mounting variety for?
When should we use the high mounting and when we should use the lower one
Old 04-25-2004, 09:41 PM   #1161
apmk's Avatar
Yes, air filter thats wat i meant.
Old 04-25-2004, 09:49 PM   #1162
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Use them depending on traction. If you need more traction, you use the lower mounts and vis versa. It is the same principal when you change the rear camber link position but this is a more drastic change.
Racing4Evo is offline   Reply With Quote
Old 04-25-2004, 10:26 PM   #1163
juki's Avatar
if u need more traction,wouldn't u use the high mounts?because it would rise the suspension arms and lower the chasis so it could lower the center gravity and giving it more traction in the rear..
juki is offline   Reply With Quote
Old 04-26-2004, 01:16 AM   #1164
Racing4Evo's Avatar
Here is a good article I just found on the Serpent website.
http://www.mytsn.com/publ/publ.asp?pid=9986
Old 04-26-2004, 06:37 AM   #1165
Bundy_Bear's Avatar
Hey Guys
I have a Thunder Tiger / AE Starter box will this work with the FW05R?
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 04-26-2004, 09:07 AM   #1166
ziggy12345's Avatar
Whats the parts you need to use the MTX 0.8 gears for the FW-05? Will they add extra top end?
Cheers
ziggy12345 is offline   Reply With Quote
Old 04-26-2004, 09:23 AM   #1167
ziggy12345's Avatar
Also does anybody do a solid front or rear axle for the 05?
Old 04-26-2004, 10:19 PM   #1168
Joehwee's Avatar
Bundy Bear: The Thunder Tiger starter box you have will not fit the 05R
Ziggy: the 0.8 module crown gear from Kawahara will increase the top end cos the internal ratio will be about 2.7 and not 3 (with 39t crown gear0
i do have a solid axle for my 05R, try it but don't really like the feel of the car, I prefer one-way or diff.
Joehwee is offline   Reply With Quote
Old 04-26-2004, 11:31 PM   #1169
B
i
I have heard from an experienced driver that the Kawahara crown gears set works very well, and that the car is much faster
B is offline   Reply With Quote
Old 04-27-2004, 12:26 AM   #1170
InitialD's Avatar
Cool. So the crown gear is 35T then? That would give a FDR of 4.5 with the tallest 2nd gearing and about 6.9 for the highest 1st gear FDR.
Have you tested them out yet?
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
