Old 04-20-2004, 01:43 AM   #1141
ziggy12345's Avatar
The same article is on my site!
ziggy12345 is offline   Reply With Quote
Old 04-23-2004, 01:41 AM   #1142
ziggy12345's Avatar
This thread has gone a bit quite... Just keeping it alive!
Old 04-23-2004, 01:56 AM   #1143
esham's Avatar
Hope it not died yet.. I just started tuning my kit. Facing problem with oversteer entering corner and exiting corner. Seem like too much grip in front. Tought want to change front form tires from 37 to 40 shore but i don't want. Keep the 37 in front all around but probably work at other setting. ( Spring, droop and ride height )
Currently i'm using front diff with 50,000 wt and rear diff 7,000 wt + LSD. Does this affect the oversteer to my car?
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-23-2004, 02:05 AM   #1144
ziggy12345's Avatar
Seems like you have the opposite problem to everybody else! Check the toe in at the rear. Set to 3 Deg
What is the front roll bar setting?
Cheers
Old 04-23-2004, 02:38 AM   #1145
esham's Avatar
Current Front Anti roll bar - flat (Soft) and the rear toe in 2... emm..yea..maybe..
Old 04-23-2004, 02:42 AM   #1146
ziggy12345's Avatar
Same as mine so might be the shock oil in the rear too thick
Match the springs with the shock oil. Soft springs, Light oil. Hard springs, heavy oil
Old 04-24-2004, 06:38 AM   #1147
dameetz's Avatar
When you enter and exit the corner do you put on throttle? If yes I had the same problem too before, I think its because the car has too drastic acceleration( because of shaft drive) you just need too control your throttle input, just don't do it too abrupt. Another thing if you are not confortable with smooth throttle control try using 39t ring gear(preferbly the steel one) and use 22t 1st gear pinion. This will reduce the acceleration and you will gain top speed. This is what i did to mine.
Dudududududuuuuuu.....
dameetz is offline   Reply With Quote
Old 04-24-2004, 12:07 PM   #1148
juki's Avatar
that's my setup too 39 steel ring gear and 22 1st gear..but i also set my spring gap in the clutch bell for about 1,5mm..this should easy up the throttle input.
From what i think...this car had a tendency to go into the corner a little bit slow. but when the car is exiting the corner, it had spontaniously throttle input...in other words, slow in..fast out driving style..
juki is offline   Reply With Quote
Old 04-25-2004, 05:59 AM   #1149
dameetz's Avatar
Hey Juki your from Jakarta? Some of my friends are going there this june for the Futaba Cup at Twin Circuit. Unfortunately I m not going( No leave) but I ll be going for Femca race in Thailand this May will be going on the 4th.
Old 04-25-2004, 07:37 AM   #1150
KMac's Avatar
Take out almost all of your rear droop and see what difference it makes. Then adjust it to your liking.
KMac is offline   Reply With Quote
Old 04-25-2004, 09:26 AM   #1151
esham's Avatar
This great guys .. great approch. No time to run it again ... need to do it next week. Photo of mine
Old 04-25-2004, 09:27 AM   #1152
esham's Avatar
The chasis
Old 04-25-2004, 10:10 AM   #1153
juki's Avatar
hello dameetz..yes, i was from jkt.in fact, i was in 1st placed in 2001 Futaba cup and 2nd placed in 2002 Futaba cup....Unfortunately, i'm not going to attend Femca race in thai because the event is the same as our national series. But i will be going to world champ in brazil this end of year..
Old 04-25-2004, 10:12 AM   #1154
juki's Avatar
btw...where u from dameetz ?? maybe i'd known u before..
Old 04-25-2004, 06:51 PM   #1155
KMac's Avatar
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
