Old 04-16-2004, 12:58 AM   #1066
InitialD's Avatar
Originally posted by ATOMIC
I guess a better way to say it would be that a thicker rear sway bar usually gives more steering entering and more forward acceleration exiting due to the fact that the car is flatter during the exit (keeping the rear of the car more level which in turn gives the tires more contact patch).
More forward bite ! Sway bars are all about shifting the available traction given on the car given from the tires. Harder rear sway bar shifts to the front traction and vice versa. Also the same with the front sway bar.
If you do not have enough wieght transfer to the rear of the car under power though the car will get loose.
Of course, there is always limits to everything.
Old 04-16-2004, 01:10 AM   #1067
ATOMIC's Avatar
Front to rear wieght transfer is controlled by the shocks and droop for the most part. Side to side by sway bars for the most part if they are introduced. It will always very front to rear though depending on the relative stiffness between the front and rear sway bars. I believe it comes back to roll , if the rear sway bar is stiffer than the front than there will be more roll in the front (as far as sway bars are concerned). Shock spring must also be concidered though. This is why I was suggesting to add steering in the front of the car with shock set-up before using the rear of the car to do this . It is always better to work on the end of the car that seems to be lacking rather than the other .
ATOMIC is offline   Reply With Quote
Old 04-16-2004, 01:10 AM   #1068
ziggy12345's Avatar
Esham your exhaust manifold is a lot shorter than mine. I am having trouble with top speed. Have you always used this length or changed from a longer one?
ziggy12345 is offline   Reply With Quote
Old 04-16-2004, 01:13 AM   #1069
InitialD's Avatar
It looks like he forged that manifold on his own !
Old 04-16-2004, 01:14 AM   #1070
ziggy12345's Avatar
When I first built my FW-05 i had loads of steering. I then stripped it down and found I diddnt install the rear stiffener that connects the throttle servo to the upper deck and the upper deck to the chassis. Instead I just connected the servo to the upper deck.
When I installed this I lost a lot of steering. I havent tried removing it again yet but will do to see if I get the steering back.
Cant see why this should be, still worth a try!
Cheers
Old 04-16-2004, 01:15 AM   #1071
InitialD's Avatar
I agree with you but wouldn't it be a faster way and less cumbersome way of tackling the problem by adjusting the sway bars or even change tires?
I guess different people have different ways of sorting out problems...
Old 04-16-2004, 01:15 AM   #1072
ziggy12345's Avatar
Thats what I was thinking but was trying to be diplomatic!! LOL..
Old 04-16-2004, 01:16 AM   #1073
esham's Avatar
Initial D, do have any photos of yours ( FW05R)
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-16-2004, 01:18 AM   #1074
InitialD's Avatar
Still waiting for someone to donate !
Old 04-16-2004, 01:20 AM   #1075
InitialD's Avatar
That's a good one !
It looks like esham bent that manifold from an old one piece pipe that he was not using.
Ehsam, mind telling us how you "got" that short manifold?
Old 04-16-2004, 01:32 AM   #1076
esham's Avatar
It is correct as Initial D mention before it is modified. Ordered RD Logic and Five Star manifold but it not arrive till now so no choice I convert my left pipe to right and bend the manifold! That was not easy my friend
Not test the kit yet but i believe i will have problem with the top speed there..
Old 04-16-2004, 01:35 AM   #1077
esham's Avatar
Talking
Old 04-16-2004, 01:36 AM   #1078
InitialD's Avatar
Yes of course it's not easy ! It looked like you did some aluminum soldering job too. Did you do it yourself or did you go to the welding shop to do it?
I don't think you'll have problem with top speed if you did the manifold correct. Besides, what is it to worry? Most tracks over here are small and more technical in nature.
Old 04-16-2004, 01:38 AM   #1079
InitialD's Avatar
Ummm, I don't know much about pipe designs but I believe there is a reason why manifolds should come as a separated unit from the main pipe. Vibrations?
Old 04-16-2004, 01:39 AM   #1080
EVOLUTION's Avatar
Who said you have to own a car (FW05R) to show that you are an expert on setting it up, rattling off ratios and other info which can be generated by the click of mouse and posting gerneric info which can be found all over the internet?
Two and half years in RC today is more then enough for talented people to become experts on all makes and models.
EVOLUTION is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
