Old 04-11-2004, 01:24 PM   #946
InitialD's Avatar
Originally posted by Buddy_C
hi d, yeah i race in hk. the rr12 is rated at 1.6 ps/hp and higher rpm than that of ns and nsr!
Ah, that explains.
Yeah the RRL12 is higher rated than the NSR. I guess it's the pipe you're using then that is limiting the engine RPM.
I know somebody (Goldfinger) that uses both the Max and the RRL12 and says that the RRL12 is only very marginally slower than the Max.
Old 04-11-2004, 01:25 PM   #947
InitialD's Avatar
if i get good top speed, will definitely keep the car, if not, back to mtx3!
On the MTX-3, what gearing are you using?
Old 04-11-2004, 01:28 PM   #948
jeffreylin's Avatar
R/C Tech Charter Subscriber
buddy
Buddy, if you are in HK, go see Samuel of International Hobby in Wanchai. He is sponsored by Kyosho and runs a FW-05R himself. I don't think his car is slower than anyone else's out there.
jeffreylin is offline   Reply With Quote
Old 04-11-2004, 01:29 PM   #949
ziggy12345's Avatar
I'll try my Rossy Pixy Black in the car but I only have the JPL pipe so might get the same problem
Ill try the RR12L5 in the Evo with the other pipe to see how that goes as well
ziggy12345 is offline   Reply With Quote
Old 04-11-2004, 01:31 PM   #950
D that explains it....ok will try the pipe set before looking for a MAX.
do u know which exact size/combo to look for?
the mtx 3 i use to run was stock gearing with a polished turbo crack, much like m.speed's
buddy
Buddy_C is offline   Reply With Quote
Old 04-11-2004, 01:33 PM   #951
ziggy12345's Avatar
Originally posted by InitialD
Ah, that explains.
What car is he running it in and what pipe is he using?
Cheers
Old 04-11-2004, 01:34 PM   #952
ziggy12345's Avatar
http://rc-union.com/product_info.php...roducts_id=706
Try this pipe. I have just ordered it
Cheers
Old 04-11-2004, 01:36 PM   #953
ziggy, pls leave me with your testing/updates with you car!
thanks so much..
yes, i think i have met him before..he is great driver, have yet to have time to visit him for tips/tricks...should do so soon iff i can find the time...
buddy
Old 04-11-2004, 01:36 PM   #954
InitialD's Avatar
My appologies. No idea as I'm not too familiar with the piping for the FW05R. I'm told the test on the Max and the RR12L5 is done with a Novarossi inline pipe but I know that you cannot fit this on the FW05R !
That's funny... MTX-3 stock gearing is 7.42 and 5.43 for the 1st and 2nd gear respectively. If that is enough for your track, then 5.0 on the FW05R is definitely enough !
Old 04-11-2004, 01:38 PM   #955
InitialD's Avatar
A Novarossi 52607 inline pipe on a 710 !
Old 04-11-2004, 01:41 PM   #956
i believe it is the internal drive gear ratio that is holding it back from top end.....but then again....hmmmmmm engine? pipe?...what do i know....
buddy
Old 04-11-2004, 01:44 PM   #957
InitialD's Avatar
Internal drive ratio does not affect how much can the engine rev. Internal drive ratio is just part of the equation for top speed. You need to take into account the gear ratios or spur over pinion ratio (which gives you FDR) and tire diameter (which gives you tire rollout and top speed too).
So theoretically, a MTX-3 with a FDR of 5.0 ratio should have the same top speed as a FW05R with a FDR of 5.0... Taking into account that engine, pipe, clutch efficiency and tire diameter are the same...
Old 04-11-2004, 01:46 PM   #958
jeffreylin's Avatar
buddy
FDR take internal into account. It is not the internal. Go talk to Samuel. He will probably tell you to get the pipe too.
Old 04-11-2004, 01:47 PM   #959
ziggy12345's Avatar
I posted this earlier
The FW-05 with:
39 ring gear
45 Spur Gear
27 Pinion Gear
63mm Tyre Dia
40,000 engine revs
Speed = 59.38 mph
VoneRR Evo with:
44 Spur Gear
22 Pinion gear
63mm Tyre Dia
40,000 engine revs
No fast pulleys
Speed = 58.76 mph
My Pixy can rev out on the evo so will try it on the Fw-05
Old 04-11-2004, 01:50 PM   #960
thanks guys for the tip and about gearing/ratios. its too late for me to type on my pda at 4am to research this
i shall return in my noontime!......zzzzzzz
asleep buddy
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
