Old 04-11-2004, 12:58 PM   #931
InitialD's Avatar
Originally posted by jeffreylin
What is Max? Is that an OS12TR? If so, that is one fast engine too.
NovaMax? I believe your friend cyba888 has one on his car...
The OS12TR is much of a bottom end engine too and lacking top end. So you'll end up with the same problem...
Old 04-11-2004, 01:00 PM   #932
i meant max power. i dont think the os can come close to the novas, unless it is a tight techie track. i guess, i'll need to try a max power engine and see if there is that much of a diff. thanks guys for the info regarding the fdr, so at least i dont have to swap spurs to figure out my problem
buddy
Buddy_C is offline   Reply With Quote
Old 04-11-2004, 01:02 PM   #933
jeffreylin's Avatar
R/C Tech Charter Subscriber
Duh!
His car is very fast. But I have yet to run against him again since I had the engine tuned properly...
jeffreylin is offline   Reply With Quote
Old 04-11-2004, 01:03 PM   #934
InitialD's Avatar
Is it so difficult to change the spurs? At least that beats the hell out of buying a new engine ! Cheaper too from what I recall.
Anyway, the fastest gearing on the FW05R with the 39T is with 21/27 pinions and 51/45 spurs.
Old 04-11-2004, 01:05 PM   #935
InitialD's Avatar
Oh yes ! But tell him that power is nothing without control !
Old 04-11-2004, 01:07 PM   #936
jeffreylin's Avatar
LOL, I was a witness to that statement last Sunday. Sorry Derek.
Old 04-11-2004, 01:10 PM   #937
well, of course not, but if it states that the 2nd gear ratio is 5.0 being the lowest, it just shows you that it won't get any faster on the top end dept...
also another question....the pinions are 0.8m but the spurs are 1.0m....? coz i've seen vonerr evo, and their spurs look true 0.8, unlike the 05r's
buddy
Old 04-11-2004, 01:11 PM   #938
jeffreylin's Avatar
buddy
One last thing, what fuel are you using vs. the Max guy? That could make a difference too.
Old 04-11-2004, 01:12 PM   #939
ziggy12345's Avatar
Hey Jeffrey, thanks for the reply! I am newbie here! I run an RR12 longstroke 5. I am using an aftermarket one piece pipe, i think JPL. Are the kyosho ones that much better? the engine seems to be revving and super strong on out of the corners, but seems like it's not going on overdrive. Any suggestions my friend? Yes I have the 2 speed working great, first i had it shifting too early and when i went down the straight, it took longer as it was redlinning already. But after i tightened it up abit, it shifted later with enough boost prior. Just the straightaway i'm gettin eaten up by Max's
Thanks!
Buddy
Hi
You have exactly the same problem as me! I have the FW-05 with RR engine and JPL pipe and I cant get the engine to revo out. I get blown away down the straight.
What fuel and plug are you running?
I was going to try another engine to see if it was the engine or the car is dragging at high speeds.
Let me know if you solve it
Cheers
ziggy12345 is offline   Reply With Quote
Old 04-11-2004, 01:13 PM   #940
i am using 25% tornado fuel.... the should be the same or 30 at the most...
buddy
Old 04-11-2004, 01:14 PM   #941
InitialD's Avatar
If the Kawahara ring gears are lower than 39T, it could be possible to bring up the internal drive ratio and hence the FDR to lesser than 5.0 with the existing spurs and pinions... Then, you could even use your RR12L5 engine.
I just think that it's just such a waste to ditch the RR12L5 engine...
Old 04-11-2004, 01:15 PM   #942
jeffreylin's Avatar
Originally posted by ziggy12345
Hi
Cheers
If you cannot get the engine to rev out, it might be the pipe. Try the Kyosho pipe. Works great for me.
Old 04-11-2004, 01:16 PM   #943
InitialD's Avatar
Hey Buddy_C, mind me asking which track are you running? You seem to come from either in the UK or from the Asian region...
Old 04-11-2004, 01:17 PM   #944
hi ziggy, it's either the pipe or the engine i would guess by now!
next time i'll dump in a max power (new or used) engine and gotta see for myself! if i get good top speed, will definitely keep the car, if not, back to mtx3!
buddy
Old 04-11-2004, 01:20 PM   #945
hi d, yeah i race in hk. the rr12 is rated at 1.6 ps/hp and higher rpm than that of ns and nsr!
buddy
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
