Old 04-09-2004, 10:37 AM   #886
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by Joehwee
Jeffery: Try running the rear black spring in front and run slight lighter oil in the front.
is the rear black longer? does that make it slightly softer than the front black? What about the shock position? I was thinking about laying my front shocks down one position before I change the spring/oil of the shocks. Thanks.
jeffreylin is offline   Reply With Quote
Old 04-09-2004, 11:12 AM   #887
Joehwee's Avatar
Jeffery: Yes, the balck rear spring is longer and will be softer than the front black. As for the shock position I thought you have used the inner hole, if not mounting it to the inner hole - laying the shocks down should help.
Joehwee is offline   Reply With Quote
Old 04-09-2004, 04:15 PM   #888
Sp Racer's Avatar
I'm a little confused!
Are you getting undesteer going into the corners off power, or does it undesteer when you get back on the juice coming out of the corner.
It's all about weight transfer..
10 yrs on RC tech ! wow....
Sp Racer is offline   Reply With Quote
Old 04-09-2004, 07:48 PM   #889
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
Originally posted by jeffreylin
Yea, I don't know what they are thinking, but I end up buying the titanium adjustable connecting rods instead.
As for the front spool, I would just put really heavy oil in the front diff or glue the front one-way dead, but what a waste!
about the front locked-diff,... I tried using 100,000 wt Kyosho oil, locked tight enough to push the car. only good in a very big track tho' (according to my driving style)
in accordance w/ the earlier post about push situation, it actually depends on your driving style,... I myself (if using a one-way) will add some more steering (by EPA or D/R or caster setting),... and I always brake when the car is still going straight, slow in, fast out,... I hope this helps. Messing too much w/ spring rate & shocks will get you even more confused (at least me) affects the whole handling of the car, instead of one specific area
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
Old 04-09-2004, 08:06 PM   #890
esham's Avatar
My FW-05R now 2 weeks delay progress due to busy...busy...busy...argh!!!!
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-09-2004, 08:07 PM   #891
jeffreylin's Avatar
Coming out on power. Thus the discussion re: droop to limit weight transfer.
Old 04-09-2004, 09:04 PM   #892
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Last night was one of my most productive test sessions with the car thus far. After a second coat of VHT being layed down at around 5 to 6pm, the bite was extremely good. Here's my setup. It still pushes a little, though not as pronounced as before. It's very much manageble.
FRONT
Camber: -2 deg.
Caster: Shims all in front of arm
Toe: 0 deg.
Spring:Gold
Shock oil: 600wt
Position: middle
Diff: One way
Ride Height: 4mm
Droop: 0
Swaybar: 45 deg.
Trackwidth: 198mm
REAR
Camber: -4 deg.
Toe: -2.5 deg.
Spring:Gold
Shock oil: 600wt
Position: bottom
Diff: 35,000 (I added a little dab of 50k to it)
Ride Height:4mm
Droop: 6mm
Swaybar: Black; 3mm exposed
Rear arm Carrier: Low
Camber Link Position: Bulkhead; bottom , Upright; Upper
Track width: 200mm
Body: Protoform Mazda 6
Optional Parts: Graphite Shock towers and upperdeck, 3 Racing Aluminum Front Arm carrier, 39t ring gears, 22 and 27t pinions
This setup is not perfect. I was just happy that the car could handle this good. It was a real motivation booster to keep on with the search for a respectable setup.
Racing4Evo is offline   Reply With Quote
Old 04-09-2004, 09:13 PM   #893
Racing4Evo's Avatar
I forgot to add that I was using 40shore tires all around. The track was Revelation Raceway in Montclair, CA.
Does anyone know how much shipping would be from Ishiimokei to the US (California) for say a Kyosho Evolva? I see their postage list and $100 for EMS would have me running to the LHS instead.
Old 04-09-2004, 09:21 PM   #894
jeffreylin's Avatar
About 60-80 bucks. However, it usually works out because their saving is significant and covers the postage and tax/credit charges. The best thing to do is get 2 or 3 at the same time with your friends to split the shipping costs. That's what I did with the TRF415.
Old 04-10-2004, 12:55 AM   #895
Bundy_Bear's Avatar
Where are all the blue alloy bits coming from? Are they after market bits or standard? If so who makes em?
Also,
What springs do you recoomend for the car? An can someone help me with my bearing question please...
BB
Bundy_Bear is offline   Reply With Quote
Old 04-10-2004, 01:02 AM   #896
B
They are standard
B is offline   Reply With Quote
Old 04-10-2004, 01:47 AM   #897
Bundy_Bear's Avatar
Originally posted by B
They are standard
Thanks....
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Old 04-10-2004, 01:52 AM   #898
ziggy12345's Avatar
What is the Kawahara KF-104 Front conversion set for FW05R? It looks like it gets rid of the plastic cover that goes over the diff housing. Anybody tried it?
Cheers
ziggy12345 is offline   Reply With Quote
Old 04-10-2004, 01:58 AM   #899
Bundy_Bear's Avatar
Cheers
I am curious to know how all the Kawahara conversions go... What differences they make too the car etc...
Frnt... Centre and Rear...
BB
MissMooRC Racing
Old 04-10-2004, 07:34 AM   #900
KMac's Avatar
Flatten your front sway bar or get rid of it altogether. If that doesn't do it, try 35 shore on the front. The difference will be very noticeable.
KMac is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
