Old 04-08-2004, 07:52 PM   #841
cyba888's Avatar
I got a question regarding using longer fuel line from the tank to the pipe. Care to explain whats the purpose?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 04-08-2004, 07:54 PM   #842
jeffreylin's Avatar
R/C Tech Charter Subscriber
Originally posted by cyba888
If it doesnt rain ill be there on Sunday for sure. This time earlier Did you run your car at night, dont you need your infrared goggles? j/k
Nope, but I sure need a lighter color body!
jeffreylin is offline   Reply With Quote
Old 04-08-2004, 08:00 PM   #843
cyba888's Avatar
Make sure you save me a seat on Sunday
Futaba 4PX
Old 04-08-2004, 08:03 PM   #844
jeffreylin's Avatar
Folks, I have a push that's no going away. I have pretty much stock set up at the moment except that I have about 18000 (30000+7000) weight oil in the rear diff. The car turn in ok but would just go wide if I apply throttle and I couldn't get the tail out if I tried. Current set up:
Front:
Tire 37
Shock oil kyosho 50W
Spring stock black
Shock position middle using the optional graphite shock towers
Caster stock (20 degrees?)
Camber -2
Toe 0 degree
One-way
ride height 5
Rear:
Tire 40
Spring stock gold
Shock position inside using the optional graphite shock towers
Camber -3
Toe -2 degree
Diff oil kyosho 18000 (30000+7000)
Ride height 5.5
Any suggestions?
Old 04-08-2004, 08:07 PM   #845
KMac's Avatar
What's your front droop? ...and do you have a sway bar in the rear?
KMac is offline   Reply With Quote
Old 04-08-2004, 08:14 PM   #846
cyba888's Avatar
Front:
Tire 37
Spring stock black
Camber -2
Toe 0 degree
One-way
ride height 5
Rear:
Tire 40
Spring stock gold
Camber -3
Toe -2 degree
Ride height 5.5
Any suggestions?
for the front try using lighter weight oil, softer springs or make your sway bars softer.
Futaba 4PX
Old 04-08-2004, 08:32 PM   #847
jeffreylin's Avatar
The front droop is 2mm above the bottom of chassis (2 using hudy droop gauge). I do have sway bay front and rear. Rear in stock setting and front is set flat (the softest setting). Thanks!
Old 04-08-2004, 08:33 PM   #848
jeffreylin's Avatar
Yea, I can do that but I want to see what I can do with other settings before I rebuild my shocks.
Old 04-08-2004, 08:44 PM   #849
Taylor-Racing's Avatar
Reduce front droop to limit weight transfer to the rear under acceleration.
Taylor-Racing is offline   Reply With Quote
Old 04-08-2004, 08:45 PM   #850
cyba888's Avatar
Try lowering your roll centers.
Futaba 4PX
Old 04-08-2004, 09:10 PM   #851
jeffreylin's Avatar
I had 1 before and I already increased it to 2 (less droop). If I increase it much further there wouldn't be much suspension travel left.
Old 04-08-2004, 09:22 PM   #852
InitialD's Avatar
I guess as opposed to increasing it to 2, you should be decreasing it to 0 or -1. Under acceleration when weight transfers to the rear anyhow, you still have suspension travel that the front tires stay in contact.
Try less rear toe in to say +1.5 or +1. Try a stiffer rear diff combined with more caster (more laid down). Increases on power steering.
Old 04-08-2004, 09:24 PM   #853
KMac's Avatar
get rid of the front swaybar.
Old 04-08-2004, 09:27 PM   #854
InitialD's Avatar
Yup. Loose the front or get a harder rear sway bar.
Old 04-08-2004, 09:30 PM   #855
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
I read that you're using a one way, right? when you need extra oversteer,.. why not try to stiifen the rear diff (use heavier oil),.. only one thing to mess with,... cos IMO, with a front one-way 18,000 in the rear is far too light,... try 30,000 (I'm using front diff with 50,000 oil, so I think 30,000 will still be in the light side w/ a front one-way) it'll surely give you plenty of power to whip the tail,....
note: smoother steering input will be needed
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
