Old 04-05-2004, 08:03 PM   #811
esham's Avatar
Anybody have a proper gear ratio for this kit? I tried to download from one of the earlier posted but couldn't manage to view it. Anybody thanks? Seem like the steel bevel ring is very popular now and it is out of stock in my LHS and rcmodel too..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 04-05-2004, 08:12 PM   #812
jeffreylin's Avatar
R/C Tech Charter Subscriber
Try this
jeffreylin is offline   Reply With Quote
Old 04-05-2004, 08:14 PM   #813
jeffreylin's Avatar
You might need to update your Acrobat reader with japanese fonts before you can view it. if it still doesn't work PM me with your email address and I will send you a jpeg version (too big to post here).
Old 04-05-2004, 08:58 PM   #814
esham's Avatar
Originally posted by jeffreylin
Try this
Yes Jeff thanks.. I manage to download the Japanese version of Acrobat Reader instead. And then I manage to view it. Thanks again.
Old 04-05-2004, 10:05 PM   #815
Manticore's Avatar
Originally posted by Im2lazy
Well, this sunday, me and one other guy, we both chipped off a couple of gears from the cast bevel gear. (he used 39 tooth, and I had 40 tooth gear) We both had them perfectly shimmed and everything. I hadn't even crashed when it gave out (indeed I hadn't crashed that whole qualifier) and the teeth just chipped! The rear diff bevel gear is perfectly fine... go figure.
Oh well, hardened bevel gears here I come.
dont worry, you are not alone !
Manticore is offline   Reply With Quote
Old 04-05-2004, 10:59 PM   #816
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
Originally posted by dino.tw
Hi,
According to IFMAR Rules 1.8; They don't limit the material but metal is heavier than aluminum. Also aluminum has better cooling ability. Cooling effect is very important,if the pipe is too hot the gasket will be roasted. Good luck.
Rule #1.8
A muffler of approved double chamber design, including silencer chamber must be fitted having the following dimensions:
Tail pipe maximum internal diameter* 5.20mm.
Tail pipe minimum length 10.00mm.
The tail pipe must be oriented on or below the horizontal.
* This dimension includes a tolerance to account for manufacturing variations in commercially available tubing
thx dino, gotta fit a smaller tail pipe then...
indeed, the pipe is a bit hotter (when chromed), bit I'm currently using heat-resistant black paint (normally used for turbo intercoolers and piping), solved the heat problem.
I can use richer setting to achieve same performance (as leaner carb w/ kyosho pipe) with the last pipe I designed, good for very long mains.
two more question, does IFMAR regulate on noise too? and lastly, will STS D5 be good on tight and winding track? (will fit one on my FW)
thanks Dino
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
Old 04-06-2004, 01:38 AM   #817
Manticore's Avatar
yes it is
Old 04-06-2004, 02:59 AM   #818
Originally posted by Manticore
yes it is
thx Manti
HPI Racing Bali
Team HB Bali
Old 04-06-2004, 03:00 AM   #819
Manticore's Avatar
thx Manti
i use OS turbo 7 with my D engine with better result over novarossi plug. try it.
Old 04-06-2004, 07:01 PM   #820
hehe, quite funny,... for my OS .12 TR(P)T, Nova plug works better than the OS one, hehehe,... can apply less aggresive carb setting w/ same power output. well, now I find the use of my OS P7 the D5, hehehe...
HPI Racing Bali
Team HB Bali
Old 04-06-2004, 08:27 PM   #821
How long have you been running that engine for? I bought one recently and tried it first time last weekend. Maybe because I wasn't expecting too much performance but I was really impressed with it. It was very easy to tune too.
GUNPOWDER is offline   Reply With Quote
Old 04-06-2004, 08:36 PM   #822
which one? TR(P)T?! since I bought the FW 2.5 gallons ago , but had beenusing TR(P)Ts in other cars previously,.... not the best engine for long tracks, but a beast for tight-mid track,... long lifetime too,... and yes, easy to tune
what fuel do you use for it anyway, I found that 25% Tornado fuel to be the best fuel for it,.... medium wear, good for races,... never heats the engine,.... switched to Gammalube currently and the temp strikes up to 135C with less performance (normally 105C max. with Tornado fuel)
HPI Racing Bali
Team HB Bali
Old 04-06-2004, 08:52 PM   #823
Thanks.. I was on a mid-tight track and as you described, it is a beast... Especially during initial accelaretion it's amazing...
I'm using 25% Hot Stuff which is probably the only fuel I can get... (There is actually one more brand around here but I forget what it was, not Tornado though...)
Old 04-06-2004, 08:54 PM   #824
Default Gear set 39T vs 40T
Hi All,
A question re: gear sets.. What kind of difference can I expect between 39T or 40T gear sets and which one comes standard in the kit?
TIA..
Old 04-06-2004, 09:12 PM   #825
jeffreylin's Avatar
Default Re: Gear set 39T vs 40T
Hi All,
TIA..
Other than the gear ratio, many people think the 39T free up the transmission a bit. The kit comes with 40T aluminum gears. The best thing is to get the new steel reinforced ring/bevel gears, 39T or 40T. They are expensive but greatly free up the drivetrain.
Look a few posts back for the FW-05R gear ratio chart to see the difference between 39T & 40T ratios.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
