Old 04-05-2004, 12:17 AM   #796
Racing4Evo's Avatar
Send a message via AIM to Racing4Evo
Switched to the 30,000wt oil in the rear and my car has plenty of on power steering. I did switch to the gold rear springs and found that it took some of it away so I went back to the stock black ones. I'm running 40shore all around.
Today was a good day for the car. I had it handling pretty decent. Just a slight off power push. Who has tips for this? I have all the caster clips behind the arm.
Racing4Evo is offline   Reply With Quote
Old 04-05-2004, 12:25 AM   #797
jeffreylin's Avatar
R/C Tech Charter Subscriber
Well, that's exactly what the local track owner told me. Switch to the heavier oil in the rear diff and it will take off power steering away but give you on power steering.
How do you like the smaller caster angle compare to the stock setup? What difference have you noticed?
Thanks!
jeffreylin is offline   Reply With Quote
Old 04-05-2004, 01:10 AM   #798
Racing4Evo's Avatar
To be honest I really can't tell you. It's been so long since I've driven the car let alone with a different set up. This was my first time with the car since early January. I had been driving the Evolution for that time. I think I will try a harder tire in the rear like your setup. I'll post my set up when I get a chance. Where are you driving the car?
Old 04-05-2004, 01:26 AM   #799
jeffreylin's Avatar
I am running the car in several places. I run it in KZ and Revelation occasionally and in parking lot races. I also run the car in Taiwan at a track called Silver Stone. The KZ track is hugh built for 1/5 really. Revelation is a medium size track for both electric and gas. Silver stone is in between KZ and Revelation with large flowing corners.
The car actually works pretty well in all three tracks. A little under geared for KZ but so are every other 1/10 GP seden.
Old 04-05-2004, 08:30 AM   #800
Joehwee's Avatar
Originally posted by jfc_tech
So joehwee, how much already u spent on those things?
jfc_tech: Quite a bit, but you should know where I got my money...hehe
Joehwee is offline   Reply With Quote
Old 04-05-2004, 08:48 AM   #801
Joehwee's Avatar
jefferylin: My setup is as followings;
Front:
Shock oil: Kyosho 350Wt with stock piston
Shock Length: 64.5mm
Spring: Rear Black
Shock position: Middle
Caster: Depend on track layout usually 1mm spacer behind arm
Camber: 2 degree
Toe out: 1 degree
Diff - 50,000wt
Track width: 198mm
Droop: +1mm
Ride height: 4.5mm Tyres at 63mm
Roll Bar: Flat
Rear:
Shock oil: Kyosho 450Wt with stock piston
Spring: Kyosho Blue
Shock position(Top): Inner
Shock position (Lower): Top hole using short ball end
Roll centre: Inner Lower / Outer Top
Arm holder: L Block
Camber: 3 degree
Toe in : 3 degree
Diff - 10,000wt
Track width: 199mm
Droop: +5mm
Ride height: 5mm Tyres at 64mm
Roll Bar: usually Black , when traction very high will used either gold or copper
What tyres to use depend very much on the traction of the particular track, I usually run between 37-40 shore, same shore front and rear.
Old 04-05-2004, 09:59 AM   #802
Manticore's Avatar
any one here has durability issue with this car?
Manticore is offline   Reply With Quote
Old 04-05-2004, 10:38 AM   #803
ziggy12345's Avatar
Yeah
The rear diff. I made sure it was shimmed but it still wore out the gears. This was after 1 day testing.
I have ordered the steel ring and bevel gears and will probably go for the ally diff housing and ally diff casing if they do one
Cheers
ziggy12345 is offline   Reply With Quote
Old 04-05-2004, 10:41 AM   #804
Manticore's Avatar
Originally posted by ziggy12345
Yeah
Cheers
i think this is a design fault as every one here is complaining about the stock ring gear.
how about arms and front gear box?
Old 04-05-2004, 10:50 AM   #805
jeffreylin's Avatar
Yeah
Cheers
I disagree. I used and abused my car for maybe 20-30 tanks without any noticable wear. I do have the steel ring gears now and they are as new after 10 tanks.
Old 04-05-2004, 10:52 AM   #806
jeffreylin's Avatar
Never broke my arms. I did break front bulkhead and the shock tower. But that was a major crash at about 40MPH into the wall (I had no idea that the walls can move LOL).
Old 04-05-2004, 10:59 AM   #807
Manticore's Avatar
that happens at any track. pay attention to the racers that you race against with !!
Old 04-05-2004, 11:47 AM   #808
coldeye's Avatar
Default jeffreylin
Haven't seen you at the RC HEAT races lately. I'm track designing for this program now so you know I kee the gas cars in mind. YOu have to check out the layout at Castle Park. The FW05R smokes!!!. Only about 1 second behind pro electric mods, not bad for a parking lot circuit. A good driver could probably get closer.
As far as durability goes, I was buying new front shock towers and bulheads after every crash. Then I stopped crashing and the problem went away. As far as diff gears, I am running O.E.M. gears and haven't seen much wear at all. Guess I'm lucky.
coldeye is offline   Reply With Quote
Old 04-05-2004, 11:54 AM   #809
jeffreylin's Avatar
Default Re: jeffreylin
Hi Mike, good to hear from you. I didn't make the RC Heat race because I've been in Taiwan for business. When is the next race? I will be back at the end of April and I hope to make the next one. Meanwhile, I have been running another FW05R at a track in Taiwan and learning more about the car. Will be racing it on Thursday night if weather permits.
Old 04-05-2004, 02:14 PM   #810
Im2lazy's Avatar
Well, this sunday, me and one other guy, we both chipped off a couple of gears from the cast bevel gear. (he used 39 tooth, and I had 40 tooth gear) We both had them perfectly shimmed and everything. I hadn't even crashed when it gave out (indeed I hadn't crashed that whole qualifier) and the teeth just chipped! The rear diff bevel gear is perfectly fine... go figure.
Oh well, hardened bevel gears here I come.
Im2lazy is offline   Reply With Quote
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
