Like Tree2Likes
Kyosho FW-05R
Old 04-01-2004, 03:09 AM
  #751
Manticore's Avatar
Originally posted by jeffreylin
I don't know. I only seen a small picture. However, whatever benefit it *might* gives you probably won't justify the price they will charge for it.
price is going to be equal to that of a kit's price. but it does "look" great !
Manticore is offline
Old 04-01-2004, 03:46 AM
  #752
ziggy12345's Avatar
Where can I get the machined bevel gears for the diffs?
Cheers
ziggy12345 is offline
Old 04-01-2004, 03:59 AM
  #753
jasoncsc's Avatar
Default Kawahara bevel drive gear set
Just received the Kawahara bevel drive gear set. I must say the quality is in line with the high quality of Kawahara parts. Compare to the Kyosho steel gear, the Kawahara set is better value (Kyosho 2 sets = 7600yen list, Kawahara 11000yen list). However, unlike the drawing as released by Kawahara before, the set on sale does not include engine mount and the two clutch pinions for change of drive ratio. What the set contains as follows:
45T 0.8 pitch front crown gear
46T 0.8 pitch rear crown gear
17T 0.8 pitch drive gear X2
Metal dogbone cup X2
Drive gear support bearings with spacers X2
One thing that is very interesting is that instead of using two small bearings to support the drive shaft, Kawahara uses only one flanged bearing with a big spacer to go into the inner part of the gearbox, and this completely does away the use of the two small bearings to support the drive shaft. I wonder if this configuration is enough to support the torque from the mid dogbones.....Anyway as I install the set I will find out, but all in all quality of the parts are top notch. I can't wait to go to the track and try, but today still is raining like cats and dogs....
jasoncsc is offline
Old 04-01-2004, 04:31 AM
  #754
Manticore's Avatar
Default Re: Kawahara bevel drive gear set
i saw that kit at LHS and it does worth the money.
Old 04-01-2004, 05:47 AM
  #755
ziggy12345's Avatar
How many teeth are on the bevel gear that drives the ring gear on the diff? Mines in the car so cant count it
Can you get different sizes?
Cheers
Old 04-01-2004, 06:34 AM
  #756
ziggy12345's Avatar
Ok
The FW-05 with:
39 ring gear
45 Spur Gear
27 Pinion Gear
63mm Tyre Dia
40,000 engine revs
Speed = 59.38 mph
VoneRR Evo with:
44 Spur Gear
22 Pinion gear
63mm Tyre Dia
40,000 engine revs
No fast pulleys
Speed = 58.76 mph
I am working on the spreadsheet to work out drive ratios ect....
Old 04-01-2004, 06:36 AM
  #757
orangbaligila's Avatar
I just hope that it'll be at least lighter than the original chassis (so dang heavy)
orangbaligila is offline
Old 04-01-2004, 06:49 AM
  #758
Super Moderator
Marcos.J's Avatar
Trader Rating: 201 (100%+)
how does this car compare to the NTC3 ans far as how smooth the drive-train is?
Marcos.J is offline
Old 04-01-2004, 07:42 AM
  #759
jeffreylin's Avatar
It's as smooth if not smoother as the NTC3 if you install the steel ring gears.
jeffreylin is offline
Old 04-01-2004, 07:43 AM
  #760
Super Moderator
Marcos.J's Avatar
thanks !
Marcos.J is offline
Old 04-02-2004, 01:11 AM
  #761
Manticore's Avatar
Thumbs up
Originally posted by ziggy12345
Ok
The FW-05 with:
39 ring gear
45 Spur Gear
27 Pinion Gear
63mm Tyre Dia
40,000 engine revs
Speed = 59.38 mph
VoneRR Evo with:
44 Spur Gear
22 Pinion gear
63mm Tyre Dia
40,000 engine revs
No fast pulleys
Speed = 58.76 mph
very good information.
Old 04-02-2004, 01:24 AM
  #762
Default steel gears
Could someone tell me where to get the steel ring gear sets? I just got this kit and my local shop doesn't carry them.
alexstjo is offline
Old 04-02-2004, 01:35 AM
  #763
jeffreylin's Avatar
Default Re: steel gears
That's a tough one. They were release merely a month or two ago and not yet in wide distribution outside of Asia. I got mine directly from Japan (Ishii Mokei, www.ishiimokei.com). FYI the part number is VSW018 for the 39T and VSW019 for the 40T.
Old 04-02-2004, 01:47 AM
  #764
Manticore's Avatar
Default Re: Re: steel gears
you can order them from shops in HK
Old 04-02-2004, 01:49 AM
  #765
border r/c's Avatar
Default 3-racing option parts are in for the FW05-r
just to let you know there in and much more..
coming soon the option parts from K-factory and Kawahara
http://shop.the-border.nl/customer/home.php?cat=494
border r/c is offline
