Old 04-01-2004, 12:38 AM   #736
ziggy12345's Avatar
Has anybody got a drive ration calculator for the FW05? I have one for the RR that will do calcs for ratio and speed dependant on the tyre and gear sizes
If not ill make one
Cheers
ziggy12345 is offline   Reply With Quote
Old 04-01-2004, 12:48 AM   #737
InitialD's Avatar
If not ill make one
Cheers
Ziggy, it would be nice if you made one. But my opinion is that it's not necessary.
Just makes sure that the front side and rear side pulleys are equal (say 20T). Then put the front diff pulley as 40T (or 39T) and the middle pulley as 13T. For the rear, put the brake pulley as 13T while the rear diff pulley at 40T (or 39T). Walla !
Old 04-01-2004, 01:00 AM   #738
jeffreylin's Avatar
R/C Tech Charter Subscriber
Hey D, what are you talking about? Are you in the right forum? There ain't no pulleys on a FW-05R. It's a shaft driven car!!!
Ziggy, I do have a gear ratio chart but do not take into account of the rollout. So yes, it sure would be nice if you made one.
jeffreylin is offline   Reply With Quote
Old 04-01-2004, 01:03 AM   #739
InitialD's Avatar
Jeffrey, I know there isn't any pulleys ! Improvise to get what you want.
Old 04-01-2004, 01:03 AM   #740
Manticore's Avatar
JL: what do you recommend on "must have" hop up for this car? I am considering to get one of the 05R !
Manticore is offline   Reply With Quote
Old 04-01-2004, 01:04 AM   #741
ziggy12345's Avatar
OK Ill see what I can come up with
Cheers
Old 04-01-2004, 01:15 AM   #742
Joehwee's Avatar
Manticore: The 39T Steel Crown gear should be the first must have option on the car. The next will be getting all the option available to lighten the car...hehe
Joehwee is offline   Reply With Quote
Old 04-01-2004, 01:15 AM   #743
orangbaligila's Avatar
Send a message via Yahoo to orangbaligila
Originally posted by snoopy
Yes, they are doing a car similar to FW-05.
It's actually a evolution of their LD3.
evolution, hehe... I like that word,.... masks the whole fishy part
HPI Racing Bali
Team HB Bali
orangbaligila is offline   Reply With Quote
Old 04-01-2004, 01:18 AM   #744
Manticore's Avatar
right, i will definitely get that. what do you think the kawahara 0.8 module crown gear ? any advantage?
you mean 39T for front end?
Old 04-01-2004, 01:18 AM   #745
jeffreylin's Avatar
First thing I would get is the steel ring gears. They are a lot stronger and freer than the stock aluminum ones. The next thing is some kind of front bulkhead upgrade since the stock one will break in a crash. 3Racing makes an aluminum one which is cheap at $15. Kawahara also have a front end conversion kit but quite expensive. Other than that, I would also get the graphite shock towers front and rear and universals for at least the front.
A lot of people feel this car is undergeared but the numbers show otherwise. I think it might be a combination between the pipe used (get a Kyosho pipe) and the rear diff not working right. I say this because when I switched to the LSD gears in the rear the car is clearly faster.
Old 04-01-2004, 01:20 AM   #746
jeffreylin's Avatar
I wonder how. The LD3 is a NTC3 copy, which is quite different from the FW-05R
Old 04-01-2004, 01:26 AM   #747
like what I'm trying to do currently
HPI Racing Bali
Team HB Bali
Old 04-01-2004, 01:29 AM   #748
Manticore's Avatar
Thanks,
JL : JH
what do you think about the kawahara conversion kit?
any advantage over the orientation on how they position the engine?
Old 04-01-2004, 01:31 AM   #749
Manticore's Avatar
LD3 is an evolution of TC3, there are may copy here and there in current car designs. but LD3 does carry some bad things from NTC3 such as fuel tank, exhaust system etc.
05R is just another shaft car but kyosho did that in a lot better way.
Old 04-01-2004, 01:47 AM   #750
jeffreylin's Avatar
Thanks,
JL : JH
I don't know. I only seen a small picture. However, whatever benefit it *might* gives you probably won't justify the price they will charge for it.
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
