Like Tree2Likes
Kyosho FW-05R
Old 02-26-2004, 12:39 AM
  #571
jas
jas's Avatar
Default Re: FW05 v V1RR
[i]
Just thought I'd share, since Kyoshos in the US aren't that common or at least in my area. [/B]
I used to live in Grand Prairie, TX. I had Kyosho Spider Mk2 which I brought over from HongKong. You are right that Kyoshos aren't that common in that part of the country.
jas is offline
Old 02-26-2004, 03:55 AM
  #572
Tom G's Avatar
Default Re: Re: FW05 v V1RR
One thing has changed, kits/parts for the Kanaii buggy are pretty easy to find now. Especially wiht the off raod tracks; Indy RC, Wild Bill's and Johnny Cool Guy [very nice track].
^5
Tom G is offline
Old 02-28-2004, 04:47 AM
  #573
Default Hi Guy's.
Hi, Im Robyn. and I'm really thinking about getting a Fw-05r. Im currently racing a Mugen Mtx-3 but would like to try something diffrent. I hear great benifit's with having a shaft drive as to a belt drive. My question is, Is driving a shaft driven car more difficult than driving a belt driven car? What are some of the carateristic's that are diffrent from the two? Any help will be greatly appreciated.. R.
freefallgirl is offline
Old 02-28-2004, 06:45 AM
  #574
Tom G's Avatar
Thumbs up Driving style
It's all about driving style.
Acceleration and deceleration will be different, you'll see a quicker response, or at least that is my experience with shafts. Can't vouch for the Mugen, since I'm only familiar.
There's a V1RR thread that they touched on this same subject a few days ago! You might, could check it out. One of the replies gave a good extensive post.
It's really a matter of your particular driving style and preference. That's what it really boils down to.
T&T in Plano is running on the 7th [concrete, temp track] and you could see for yourself. Some are running drive shaft-cars but the FW05, or any other Kyosho road car, aren't really popular down here.
RCFiles.com has the link(s) for T&T. It's the Texas version of rctech.net.
Tom G is offline
Old 02-28-2004, 09:58 PM
  #575
boy2rc's Avatar
Hi all shaft drive lover, let me introduce myself, I race 1/10 for 6 years, from Impulse switch to MTX3 and then plus a 710 recent, I love both, last month my friend told me he will get a FW05R, after I try it what a fantastic experience, great! So I own a first shaft drive car now, FW05R (I don¡¦t like NTC3), a litter tips, I use Kyosho option, front one-way, and steel ring gear front 39T, rear 40T to local small track. Kyosho blue 1.8 spring F & R.
I use TCD gear also, I feel that I drove faster that who not use with it, local track more than 20--05R car now!!
boy2rc is offline
Old 02-28-2004, 10:56 PM
  #576
Tom G's Avatar
Thumbs up Very nice!
The graphite upper plate part of the kit or an add on?"
Tom G is offline
Old 02-28-2004, 11:24 PM
  #577
B
that version of the kit comes with the carbon upper deck
B is offline
Old 02-29-2004, 05:34 AM
  #578
Tom G's Avatar
Cool, tanx!
Tom G is offline
Old 02-29-2004, 07:27 AM
  #579
orangbaligila's Avatar
sweet,... I think I should upgrade now,... mine looks quite dated already,... (the first foam-version,... all stock 'cept foams and shorter rear bones)
btw, a bit OOT,... what makes a pipe legal,... I'm making my own currently,... did 2 single-chamber prototypes already, based on OS' left-side pipe (will post pics soon), low-to-mid punch (torque) is boosted, but loosing a bit of top-end (I normally run on a small-mid local track, using taller gear-ratio... low traction surface)
things that I doubted was, the regulation on size (mine is really fat (62mm) but kinda short (91mm), compared to the Kyosho' pipe for the FW (52mm) mine's well hung, hehehe... oh,.. and it's rather loud as well (115+ db at 5 meters),... it's made of sheet metal (love the tone actually, has "rrriiinggg" sound between the deep-warbling tone on-throttle) .... I have another proto w/ silencer pipe manufactured currently (like full-size 2-stroke pipes) not tested yet, maybe next weekend...
if you're in the know about reulations, please educate and share otherwise I'll consider the pipe as an outlaw one-off pipe, hehe...
cheers folks
orangbaligila is offline
Old 02-29-2004, 03:11 PM
  #580
Tabushi's Avatar
Francesco Tironi just won the preworlds with a FW-05R ... look my last posts on the yokomo gt4 thread ...
cya !
Tabushi is offline
Old 02-29-2004, 07:37 PM
  #581
apmk's Avatar
Default Harden pinon
Hi guys, anybody know of any harden 0.8 module pinon
that fit the kyosho centax clutch.
apmk is offline
Old 02-29-2004, 07:53 PM
  #582
B
check out team active ones
www.active-hobby.com
I believe those are hardened
B is offline
Old 02-29-2004, 08:47 PM
  #583
racer x 1's Avatar
Trader Rating: 27 (100%+)
if your new to shaft drive you'll need to get used to the acceleration because their is less drag .have fun with it and don't forget to buy the one-way.
racer x 1 is offline
Old 03-01-2004, 02:18 AM
  #584
jeffreylin's Avatar
Hi there, I wonder why you have 39T in front and 40T in the back? wouldn't that make your front wheels rotate faster than the rear? What does that do to the handling of your car?
The other question I have is the TCD gear set. What difference does it make compares to the stock diff?
Thanks!
jeffreylin is offline
Old 03-01-2004, 03:08 AM
  #585
InitialD's Avatar
I think it's a great idea to overdrive the car by this method because before this, there would not be a way to change the front and internal drive ratios of a shaft driven car besides playing with tire diameter which affects the geometry of the car.
InitialD is offline
