Kyosho FW-05R
#5416
Went home for a week and found my old fw-05 r
oh how i miss that car, so much so that i decided to bring it back with me to montreal, the car and engine both have about half a gallon through them so its basically new and stock.
I keep hearing that everyone loves the kyosho pipe, i hated mine, so i got the vantage racing carbon fiber pipe, its pretty sweet!
cant wait to put it on a track!!
#5417
yeah have fun, i cant wait to break-in my new O.S. new engine and punt on the tarmac my new built fw05rr with pretty much tuning, and see how it runs
here is very hot i need to wait a fresh day first
fw05 rocks
@hecti why do you say you hated kyosho pipes?
fw05 rocks
#5418
#5419
nice kit..i got 1 fw05rr but i cant get all the part here as my diff gear worn out n i have to quit using it and go to v-1-rrr shimo..
#5420
but in between shaft drive and belt i still like to drive shaft..since its fast acc,and the easy to maintain..i just make some order from our lhs..wish this item come early before our race here..
#5422
steering
hey is there a specific way to fit the carbon steering plate??? the screw setup is different, so does that mean there is a specific screw set for this???
#5423
is yours a fw05r or t? becouse that i know the screw set to use with the carbon steering plate(that i have) with the R is exactly the same
#5424
3D clutch assy
anyone here has 3D clutch assy for fw-05r/fw-06? or anyone willing to sell theirs?
i badly need it for my fw-06. ( i have a brandnew Sirio S-12 XXX and was having a problem since the stock clutch isn't compatible. (
will the 3D clutch assembly for RRR fit in the Fw-06?
help please... (
** i'll just will sell my Sirio S12-XXX if i cant find a clutch assy that will fit. anyone interested?
help please... (
#5426
diff gear different 40/39
may i know what is the different both of them?as i use both front and rear using 40t,may i know if i wana have front bias from rear as i worn out the rear tyre mostly,
#5427
Hi, I haven't FW05, but difference is in tooths, if you use 39f and 40r you will have front overdrive and can use smaller front tires. If you have problems with rear tires, use 1 or 2 steps softer tires in front and 1-2mm smaller diameter starting mains. For qualification it is not needed. This is what i do with NTC3. Maybe some of FW05 guys can suggest something different, depends on setup and driving style.
#5428
Rear foams will always wear faster than front foams.
With 39f and 40r (or as I ran 37f 38r) you have overdrive to the front, with this overdrive you want to run the front foams 1.5mm smaller than the rear foams, having smaller fronts than rear evens out the wear balance between front and rear keeping the car more stable for longer.
#5429
Super Moderator
#5430
Anyone interested in brand new sealed in box FW-05RR? I bought it and figured there is no on-road nitro track around here to play.
http://www.rctech.net/forum/r-c-item...o-fw-05rr.html
I am not sure how much is one going nowadays. So if anyone knows please let me know how much it is worth. I will consider selling it for reasonable price.
Thanks.
Thanks.
