Old 08-24-2009, 06:22 PM   #5401
Renault_Tech's Avatar
what pinion spur gear combos were you guys running for max top end??
Renault_Tech is offline   Reply With Quote
Old 08-25-2009, 01:48 AM   #5402
NiMo's Avatar
Biggest improvement to the car is to fit the Steel Diff Rings, I used the 37T ones which seemed to free up the drivetrain and gave a longer 1st gear, but then the JP motor had the torque to pull it.
my car was set up so at my local track I would use first gear every where and only second on the main straight, but then these were the Rubber days where to much power would spin the tyres. These days with Foam you may want to run a low first gear (I hated Foam IC racing, that is why I quit).
NiMo is offline   Reply With Quote
Old 08-25-2009, 04:47 AM   #5403
Cool
Yeah i couldnt get my hands on some 37's and had to settle for 38T gears.
Old 09-03-2009, 04:47 AM   #5404
Anyone know of any conical manifolds to suit the FW05R?
Old 09-04-2009, 02:09 PM   #5405
Hi guys, what you think about running the 38T gears with stock pinions, 21-26 in a medium-small track? that wouldnt be too long 1rst gear?
the engine is an OS CVR18 bump start......and a mielke torque pipe......
quote to renault, i think doesnt exist a conical manifold for the fw...
anto77 is offline   Reply With Quote
Old 10-16-2009, 07:13 AM   #5406
Hey hey....
Got a FW-05R fully race preped, but i need a new exhaust. I have a 12 JP racing motor in it now with an old beat up exhaust.
Any suggestions of exhaust for these, want to keep it race legal but. I will also need the manifold details.
Cheers in advance.
Just keep tellin her its cheaper than real cars.... safer too
Stangas is offline   Reply With Quote
Old 10-17-2009, 05:19 PM   #5407
Originally Posted by Stangas View Post
Hey hey....
Cheers in advance.
with a JP Eagle engine i would suggest the Novarossi 51608 that is also Efra legal.
i heard the kyosho pipes works better with Sirio Evo engines.
Old 10-18-2009, 05:06 AM   #5408
Hey hey....
Cheers in advance.
Do you need a pipe and manifold? I have a few used EFRA 2601 Novarossi pipes.
[KYOSHO] [NOVAROSSI] [TEAM MAGIC G4RS] [O.S SPEED T.Z SPEC II] [SPEKTRUM DX3R]
Old 11-26-2009, 10:53 AM   #5409
Hey guys, whats the different between the FW05R and the FW05RR ? Cause I would like to get one but just dont know which one is a good one that has more hopups availability. Thanks
NitroAddict82 is offline   Reply With Quote
Old 11-26-2009, 01:48 PM   #5410
It depends what fw05r version, anyway they are almost the same, the rr is the evolution of the r, with one way hub, different carbon deck and fron shock tower, all the rest is the same car and the hop ups fit on both cars
Old 11-26-2009, 02:49 PM   #5411
NiMo's Avatar
FW05RR has a different top deck to stiffen up the fron end to make it better for Foam tyres, but is more of a pain to work on as you have to dismantle the front diff housing to remove the top deck.
I would personaly go for the older Rubber based FW05R spec and then upgrade the rear hubs/upper arms to the V1RRR if you prefer Foam
Old 11-26-2009, 07:37 PM   #5412
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Top end
When i ran the car here in Florida , i ran mugen clutch, with red shoe 22/29 pinions,50/45 spurs 38t ring gear.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 11-26-2009, 10:48 PM   #5413
Thandks NIMO, i will get the FW05 then. apreciate it !!!
Old 04-27-2010, 01:02 AM   #5414
hey guys,
about to rebuild the FW05RR for the first time since ownership. Got the nova pipe.
Just want to get an idea of diff oil weights recommended.
With my electric i have a solid front, and very soft rear. Is this similar with nitro?
Same with springs and shocks? I run 2 grades harder on the front, and what oil rates for these?
Our track is a big fast 1/8th Nitro bitumen track. if that changes anything.
Any advice appreciated
Old 05-03-2010, 06:00 PM   #5415
[QUOTE=Stangas;7325468]
hey Stangas, for a big fast track i would go with front one way, rear 30.000 differential, for shocks try the stock front black and rear gold, or gold all around!!
FOR SALE - Mugen MBX5T ProSpec and Kyosho STR with chassis conversion and Kyosho big MattWells R/C Items: For Sale/Trade 5 04-28-2017 10:25 AM
1986 1/12 Kyosho Plazma MKIII With Kyosho LeMan 600E Motor Funkymojo R/C Items: For Sale/Trade 2 05-17-2012 11:11 AM
Custom painted Kyosho SP2 and Kyosho STRR bodies.... RC3 Graphics SWEET W/ PICS CRFXXXT R/C Items: For Sale/Trade 1 01-07-2008 07:38 PM
MACH. 28/NEW PS, KYOSHO MINI INFERNO ST/W/3NEW IB1400 8 CELL PACKS, KYOSHO 1./8 BUGGY newbie2 R/C Items: For Sale/Trade 5 11-18-2007 06:07 PM
Convert Kyosho Quick Start system on Kyosho QRC to Pullstart Morpheus2be Monster Trucks 0 02-16-2005 11:26 PM
